extra 300
Joined: 1/21/2004 From: BeirutBeirut, LEBANON Status: offline
quote:
ORIGINAL: ViperOneNL I fly with a P70, which is in my opinion the best combo with a Boomer (can only talk about JtCat Though) We also have a Boomer with the P80 flying, but lots of butchering needed to fit that one For the P70 no real changes are needed other than making sure it does not touch the bottom so you need to remove some material from the formers under the engine, not much just a little. Cheers, Mick. Mick, Thanks for the reply, I have also noticed that P-70 brackets do not fit in place, did you trim the wood or mount to have it fit. What about CG have you been able to cheive without adding weight in the nose? Do you have any photo of your installation? Thanks. Regards. Dany
