RE: Reaction 54 Jet Kit    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: Reaction 54 Jet Kit
Page: <<   < prev  114 115 116 117 118 119 [120] 121 122 123   next >   >>
Login
RE: Reaction 54 Jet Kit - 6/28/2012 8:39 AM
Legnum
Score: 100
Last Login: 5/22/2013
Status: offline
hi there,
had a kit sent to NZ a couple of weeks ago and its under way. mate has Anthony s from Christchurch, flew it our Anzac meet, good fun jet, so now there will be 2 wood kit R 54s down under. will have Intairco retracts, kevlar tank glassed and painted,going use some of mods made on this forum, mainly the duct set up by Bobparks2. had to alter the retract mounts, fairly simple mod. changed the nose mount, had trim 10mm from the nose leg. will join the wing together tomorrow.
Grant
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Legnum -- 6/28/2012 9:18 AM >
Hide Signatures
(in reply to JustFlyIt)
       Post #: 2976
RE: Reaction 54 Jet Kit - 6/29/2012 2:24 AM
afterburner
Score: 110
Status: offline
Has anyone used a JC Rabbit(19lbs) on the Reaction?
Marty
Hide Signatures
(in reply to Legnum)
       Post #: 2977
RE: Reaction 54 Jet Kit - 6/29/2012 3:41 AM
ww2birds
Score: 105
Last Login: 5/21/2013
Status: offline
Not sure if it helps but I have a Wren 100 (about 22#) on mine .. I replaced a Wren SuperSport (18#) and the difference was quite noticeable .. flew fine with the SS, but LOTS more fun with the 100 .. the airframe takes the power easily and it's a pleasure to fly. I am sure it would be great with the Rabbit too. My plane is 20# dry.
Dave
Hide Signatures
(in reply to afterburner)
       Post #: 2978
RE: Reaction 54 Jet Kit - 6/29/2012 4:08 AM
afterburner
Score: 110
Status: offline
Thanks Dave. I've been flying mine for about five years now with a P-60 and although it's still fun, I think the extra thrust would boost the fun factor and make it feel like a new plane.
Marty
Hide Signatures
(in reply to ww2birds)
       Post #: 2979
RE: Reaction 54 Jet Kit - 6/29/2012 4:15 AM
PaulD
Score: 105
Status: offline
Go for it. The Reaction I had originally had a 14 lb'er on it and I put a Wren SS on it when I bought it. The original owner said it made the jet go from yawn to yeehaw.
The extra thrust is a great addition even up to 22 lbs. If u are putting more jamb in, find a way to squeeze in more fuel so u can fun for more than 5 min.
PaulD
_____________________________
If it''s too LOUD - You''re too OLD
Hide Signatures
       Post #: 2980
RE: Reaction 54 Jet Kit - 6/29/2012 4:19 AM
causeitflies
Score: 120
Status: offline
I flew mine for two years (six years ago) with a P-60. Brought it out of retirement last year with a Wren SS and it's a ball to fly on 18lbs. Would love to fly it on 22lbs but I fly it pretty hard so maybe I'll stick with the SS
Mark P
An Expert has made every mistake - A Master has made every mistake twice
Hide Signatures
       Post #: 2981
RE: Reaction 54 Jet Kit - 6/29/2012 6:03 AM
bobparks2
Score: 100
Last Login: 4/7/2013
Status: offline
I started out on mine with a Wren 54 mk 3, about 14 lbs thrust, then recently changed to a Jets-Mund VT-80, about 18 lbs, but also lighter than the Wren, and the fuel consumption is only a bit higher. Quite a nice improvement. I have a 75 oz JetTech (Gary Mueller) tank plus a 6 oz header, and set my TX timer for 6 minutes of flight time over 30% throttle.
Bob
Hide Signatures
(in reply to causeitflies)
       Post #: 2982
RE: Reaction 54 Jet Kit - 6/29/2012 10:14 PM
Legnum
Score: 100
Status: offline
hi all,
wings are joined, going for a trail fit to fuselage to day.everything has lined up well so far, nicely cut kit. have ordered a Jet Cat 100 RX to power it, simplified wiring harness and the specs show a kilo lighter than some of the other Cat Turbines being installed, should make it interesting. supply is about 6 weeks away, that should give me time to glass it and fit Bobparks2 duct design.
Grant
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to bobparks2)
       Post #: 2983
RE: Reaction 54 Jet Kit - 6/29/2012 11:46 PM
Square Nozzle
Score: 105
Status: offline
Legnum, I have built two R54's and I see something in your wing that troubles me. You have eliminated the triangular brace blocks at the plywood sandwich on rib W6 in favor of small traingular pieces of plywood. I suggest that this is a poor idea since the reinforcing blocks add a great deal of support for the gear mount. I have had my share of hard landings and runs off the paved runway. The first area to fail is that area. With the gear loads you will want as much support in that area as possible.
< Message edited by Square Nozzle -- 6/30/2012 2:33 AM >
John
Hide Signatures
       Post #: 2984
RE: Reaction 54 Jet Kit - 6/30/2012 2:57 AM
Legnum
Score: 100
Status: offline
john,
that pic was taken before i had finished the mounts, all ply is aircraft grade 5 ply, base has the retract set in, with 2 more layers to fasten the retract to. hopefully this should be enough.
Grant
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Legnum -- 6/30/2012 3:18 AM >
Hide Signatures
(in reply to Square Nozzle)
       Post #: 2985
RE: Reaction 54 Jet Kit - 6/30/2012 8:09 PM
SPLIT S
Score: 109
Last Login: 5/11/2013
Status: offline
Doing paint work on a friend's Reaction....
Dan
Click for fullsize
Hi Dad, Doing anything? Want to go to the field?
Hide Signatures
       Post #: 2986
RE: Reaction 54 Jet Kit - 7/1/2012 3:08 AM
Square Nozzle
Score: 105
Status: offline
Legnum, I still see the potential to pull the retract mount plate and wing skin away from the W6 rib sandwich. There doesn't appear to be enough contact surface to hold that skin/gear mount plate to the rib. The load that the gear puts onto that system wants to pull the retract assembly to the rear and will take your current mount arrangement with it unless you put the triangular blocks in where the W6 rib meets the gear mount plate. The triangular blocks should be in the kit and are shown on the plans. I think the blocks are 3/4" triangular sticks the you will need to cut into segments to fit.
John
Hide Signatures
       Post #: 2987
RE: Reaction 54 Jet Kit - 7/1/2012 3:42 AM
Legnum
Score: 100
Status: offline
have bolted wing to fuselage, need to sheet top of wing, will have another look at the retract mounts, have the 3/4 triangle strip, noted where it fits. then sanding, glassing, painting.
Grant
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Legnum -- 7/1/2012 4:04 AM >
Hide Signatures
       Post #: 2988
RE: Reaction 54 Jet Kit - 7/2/2012 3:15 AM
JohnVH
Score: 160
Last Login: 5/19/2013
Status: offline
Just put 4 more flights on mine this weekend, put crow into it, that is definately the hot ticket, takes some float out, also, put the brakes on while in the air so when it touches it sticks. Ill have HD vid soon of a flight hopefully from a buddy.
[quote]ORIGINAL: jefflangton
Time to bend over and let your head pop out!!!![/quote]
Hide Signatures
       Post #: 2989
RE: Reaction 54 Jet Kit - 7/3/2012 3:57 AM
JohnVH
Score: 160
Status: offline
Video proof I still remember how to fly, this was shot this past saturday at a local field. Enjoy!
Bobs old well used R54, JetcatP70, JR DSM2, Crow with brakes set in the air before touchdown, very light headwind, Thanks Ken for taking the vid!
Hide Signatures
(in reply to JohnVH)
       Post #: 2990
RE: Reaction 54 Jet Kit - 7/3/2012 4:41 AM
BruceTharpe
Score: 100
Last Login: 5/17/2013
Status: offline
Fantastic flight, John, I like your style! Looks like a tiny runway, and you only used half of it. I'd say you proved you're a GREAT jet pilot.
BTW, excellent camera work, tell Ken I'd like to know his secrets
BTE - Home of "Quality-Minded Model Aircraft Kits"
Hide Signatures
       Post #: 2991
RE: Reaction 54 Jet Kit - 7/3/2012 4:43 AM
JohnVH
Score: 160
Status: offline
Thanks! I think that was my 7th flight on the R54 since I got it. Crow and brakes on is the hot ticket to super short landings on this tiny field. They are not all that good, but it works! Great job on a fun jet!
I think the runway is 225' or less, field is 400'ish
Hide Signatures
(in reply to BruceTharpe)
       Post #: 2992
RE: Reaction 54 Jet Kit - 7/3/2012 4:52 AM
PaulD
Score: 105
Status: offline
Nice smooth flying John, hope we see you at Whidbey and/ or Princeton.
PaulD
Hide Signatures
       Post #: 2993
RE: Reaction 54 Jet Kit - 7/3/2012 5:22 AM
JohnVH
Score: 160
Status: offline
Ill try, but doubtful Paul, all the jet events are planned on top of local stuff I have to attend, sadly.
Hide Signatures
(in reply to PaulD)
       Post #: 2994
RE: Reaction 54 Jet Kit - 7/3/2012 9:34 PM
bob1393
Score: 100
Status: offline
Hi John - thanks for posting the video. It's really nice to see one of my "old" planes fly!!! I was amazed at how fast you were able to stop after landing. I thought you would be using the grass runway for landings. Thanks again!!
Bob
AMA CD/Leader Member, JPO Dist XI VP
Hide Signatures
       Post #: 2995
RE: Reaction 54 Jet Kit - 7/3/2012 9:43 PM
JohnVH
Score: 160
Status: offline
Normally I do use the grass Bob, but this one just felt good! If I didnt have the brakes set in the air I probably would have ran off the end of the runway. Having fun with the bird, most at my club have never seen one fly there, so they get a kick out of it, plus its sooooooo easy! Bruce designed a hell of a fun short field machine!
Hide Signatures
(in reply to bob1393)
       Post #: 2996
RE: Reaction 54 Jet Kit - 7/4/2012 6:51 AM
bob1393
Score: 100
Status: offline
Some people who get started into turbines want scale or something fast or sexy. The R54 is just a fun airplane to fly and more people should start out on one to learn all about turbine flying. FYI, Dean Wichmann had another R54 built (he sold his 1st one) by Paul D. so he could just have a fun plane and buddybox people on it.
Bob
Hide Signatures
       Post #: 2997
RE: Reaction 54 Jet Kit - 7/9/2012 8:52 PM
bobparks2
Score: 100
Status: offline
I was flying at the club airshow over the weekend, and a photographer there some good photos of my R54.
Photos by Kelly Collin, P51 Girl Photography
Its pretty neat how the heat shimmer of the exhaust shows up in the first approach photo.
Bob
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 2998
RE: Reaction 54 Jet Kit - 7/9/2012 9:47 PM
Woketman
Score: 105
Status: offline
Bob.... the afterburner ring WOW!!!! VERY sweet!
Hide Signatures
       Post #: 2999
RE: Reaction 54 Jet Kit - 7/9/2012 10:03 PM
Legnum
Score: 100
Status: offline
hi Bob,
nice pictures, amazing what you see when you really look!! missed the mods to rudder and elevator on previous posts, very clever.
Grant
Hide Signatures
       Post #: 3000
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.750RCU1
