RE: Reaction 54 Jet Kit    Gallery
Logged in as Guest
    Search This Thread
Printable Version
MBA Tornado V3
Seller:  Modellbau USA
Details:   $380.00   |  5/11/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: Reaction 54 Jet Kit
Page: <<   < prev  17 18 [19] 20 21 22 23 24 25 26   next >   >>
Login
RE: Reaction 54 Jet Kit - 5/24/2005 3:25 PM
rcguy!
Score: 108
Last Login: 5/18/2013
Status: offline
quote:
ORIGINAL: john agnew
Dave
Which of your P60's flamed out? Was it the one that was causing you trouble? Did Jetcat find out the problem yet?
Glad to hear your damage was minimal, going out to fly the Intro today as it's warm (60o F!!) and sunny with 8 knots straight down the strip.
John
John and all,
Yes it was the P60 that JetCatUSA had. It was NOT the turbines fault. It starts and runs perfectly now. I ran the UAT dry and she quit from fuel starvation. See my post on RCU on air in a UAT. Since I got the P60 back she miss started the first time due toair in the fuel lines. Since then I'm 6 for 6 on the starts. The R54 is one real tough bird! Enjoy todays flying!
Dave Rigotti
Hide Signatures
(in reply to john agnew)
       Post #: 451
RE: Reaction 54 Jet Kit - 5/24/2005 6:58 PM
BruceTharpe
Score: 100
Last Login: 5/17/2013
Status: offline
Dave, I told you this type of airframe testing is not recommended by BTE Glad it was repairable.
Dean and company. Sounds like you all had quite a weekend of flying, the kind that sticks in your memory. I'm jealous!
Others might be interested to know that both Dean and his friend John W. (camo R54) had come to the conclusion that the R54 lands better with something less than the full 60 degrees of flap deflection. Dean is using 35 degrees, but he also uses spoilerons (ailerons popped up about 1/4") for a solid approach and no-float landing. This is something I will be testing thoroughly when my next R54 is done. Just thought I'd pass that on for others who might like to experiment.
I hate to make it sound like the R54 is untested - it went through a rigorous flight test. But as I have made clear in the past, the flaps (and ailerons) for the kit were enlarged to hopefully overcome a bit of floatiness in the prototype. So far, it sounds as though the larger flaps are doing their job! Thanks for the input, Dean.
Bruce
BTE www.btemodels.com
_____________________________
BTE - Home of "Quality-Minded Model Aircraft Kits"
Hide Signatures
(in reply to rcguy!)
       Post #: 452
RE: Reaction 54 Jet Kit - 5/24/2005 7:08 PM
rcguy!
Score: 108
Status: offline
quote:
ORIGINAL: BruceTharpe
Bruce
Bruce,
I agree with Dean on the flaps. I use 30 degree almost exclusivly. I only use full flap (60 degrees) IF i'm hot on the approach and only then apply them when over the threshold. With full flaps I seem to "almost" run out of up elevator for the flair.
Dave Rigotti
Hide Signatures
(in reply to BruceTharpe)
       Post #: 453
RE: Reaction 54 Jet Kit - 5/24/2005 7:42 PM
tschuy
Score: 111
Last Login: 5/20/2013
Status: offline
I've been using about half flaps on base leg and go to full flaps on short final on mine. Bit of a learning curve but at my field I have to do short field type approaches and then set her down on an asphalt runway that is 40' wide and 300' long. The R54 handles it with no problem and I usually end up using only 150' during my landing roll without tapping on the brakes. If I use brakes the distance would be about 70' since the CompactUniBrakes stop this airplane with authority. They have a good deal of holding power and it's only when I have the engine spooled up past 40% power that they are not able to overcome the thrust of my FTE T-500 turbine. Makes for nice sling-shot style take-offs.
Cheers,
Tim Schuy
tschuy@comcast.net
Hide Signatures
       Post #: 454
RE: Reaction 54 Jet Kit - 5/24/2005 7:44 PM
tschuy
Score: 111
Status: offline
BTW...Bruce start watching your mailbox within the next few days. I've sent you a copy of the newspaper that had my R54 on the front page....
Enjoy Buddy....You deserve it...
Cheers,
Tim Schuy
tschuy@comcast.net
Hide Signatures
(in reply to tschuy)
       Post #: 455
RE: Reaction 54 Jet Kit - 5/28/2005 8:05 AM
TommyWatson
Score: 100
Status: offline
My Kevar tank arrived today from Gary. I am impressed. I got him to install the BVM fittings. The feed pipe just screws in and the breather is glued in at the top corner.
It will hold exactly 2 litres. Thats 1/2 litre more than the dubro tank.
Regards
Click to see fullsize image.
Click for fullsize
Tom Watson
Sydney Australia
Hide Signatures
       Post #: 456
RE: Reaction 54 Jet Kit - 5/29/2005 1:15 PM
TommyWatson
Score: 100
Status: offline
Well Guys,
Another great flying weekend in Sydney Australia.
Weather was perfect and the "Australian R54" flew twice on sunday.
I even did a "touch and go".
Has anyone tried raising the ailerons during landings?. If so how much and with with how much flaps?.
My R54 lands beautifully but sometimes takes a little while to settle on the runway.
any other landing tips?.
Tom Watson
Sydney Australia
Hide Signatures
(in reply to TommyWatson)
       Post #: 457
RE: Reaction 54 Jet Kit - 5/29/2005 2:19 PM
TREADSTONE.
Score: 102
Last Login: 3/29/2006
Status: offline
Tom,
Photographs.... SVP
We shall require a substantially new manner of thinking if mankind is to survive.
Albert Einstien.
Hide Signatures
       Post #: 458
RE: Reaction 54 Jet Kit - 5/29/2005 2:29 PM
TommyWatson
Score: 100
Status: offline
Guys,
I was too busy flying, and I did not have my photographer with me.
The touch and go was sort of an accident. I bounced about 2 feet into the air on the first landing and I did not think I could land and stop before the end of the runway, so I opened the throttle full and in about two seconds I was away again. Lucky the thing will fly on very low thrust.
I did some very nice figure eights with the gear and flaps down. The circles were really small and slow about 100 ft in diameter.
All the jets that my friends have seen fly are the Kangaroo type model with 30 pound thrust engines. My little R54 really opened their eyes.
It can fly straight up (with a high speed approach) and do a beautiful split "S".
Can't wait to build my next one.
Regards
Tom Watson
Sydney Australia
Hide Signatures
(in reply to TREADSTONE.)
       Post #: 459
RE: Reaction 54 Jet Kit - 5/31/2005 11:01 PM
nitrovmaxer
Score: 100
Last Login: 6/19/2006
Status: offline
Here is a video clip of Dean's Reaction 54.
http://rowdy.homedns.org:8080/sharefile/server2005_5_30_14_15_10_593/Reaction54.wmv
Rowdy
Hide Signatures
       Post #: 460
RE: Reaction 54 Jet Kit - 6/1/2005 7:27 PM
afterburner
Score: 110
Last Login: 5/21/2013
Status: offline
Rowdy,
I can't seem to download the video.
marty
Hide Signatures
(in reply to nitrovmaxer)
       Post #: 461
RE: Reaction 54 Jet Kit - 6/1/2005 9:50 PM
nitrovmaxer
Score: 100
Status: offline
Try this mirror http://www3.telus.net/rowdyrotorhead/Reaction54.wmv
Hide Signatures
(in reply to afterburner)
       Post #: 462
RE: Reaction 54 Jet Kit - 6/1/2005 10:04 PM
afterburner
Score: 110
Status: offline
Thanks, that worked. Man that plane just crawled in for a great landing. I think I've found my plane for my jump into turbines.
Marty
Hide Signatures
       Post #: 463
RE: Reaction 54 Jet Kit - 6/2/2005 2:53 PM
rcguy!
Score: 108
Status: offline
Off to Bardstown, KY jet rally. Any other R54 pilots going to attend?
Dave Rigotti
Hide Signatures
       Post #: 464
RE: Reaction 54 Jet Kit - 6/2/2005 3:30 PM
tschuy
Score: 111
Status: offline
Won't be there until Sunday due to a local Fun-Fly for our club. Was planned long before Frank made his announcement for the Bardstown Jet Rally. Wish he would pick a day and stick with it annually.
Tim Schuy
tschuy@comcast.net
Hide Signatures
       Post #: 465
RE: Reaction 54 Jet Kit - 6/2/2005 3:44 PM
rcguy!
Score: 108
Status: offline
quote:
ORIGINAL: tschuy
Tim,
See you on Sunday! (I'm thirsty!)
Dave Rigotti
Hide Signatures
       Post #: 466
RE: Reaction 54 Jet Kit - 6/2/2005 6:09 PM
tschuy
Score: 111
Status: offline
Can we get a count as to who is all going down to the Bardstown Jet Rally for a group R54 picture?
Cheers,
Tim Schuy
tschuy@comcast.net
Hide Signatures
       Post #: 467
RE: Reaction 54 Jet Kit - 6/2/2005 6:10 PM
BruceTharpe
Score: 100
Status: offline
Tim and Dave - hope you have a great time at Bardstown. Believe me, I'd love to be there!
Rowdy - Excellent video! What a nice airplane
Dean - Superb flying and a smooth landing. Just too easy!
Tommy - I tried raising the ailerons and did not see much effect. However, Dean says he is popping the ailerons up about 1/4" with his along with 35 degrees flap for spot landings. Check out the video... The R54 flaps are designed to drop up to 60 degrees, but some are finding that to be too much. I think there's a heavy interaction of pilot expectation/preference, aircraft weight, and idle thrust involved here, making it difficult to settle on a "perfect" flap/aileron setup. Thankfully, the R54 is a forgiving design that allows you to experiment without getting into trouble.
Hide Signatures
       Post #: 468
RE: Reaction 54 Jet Kit - 6/2/2005 6:11 PM
tschuy
Score: 111
Status: offline
quote:
ORIGINAL: rcguy!
quote:
ORIGINAL: tschuy
Tim,
Dave Rigotti
Will have the ice-chest full of cool ones for ya...
Cheers,
Tim Schuy
tschuy@comcast.net
Hide Signatures
       Post #: 469
RE: Reaction 54 Jet Kit - 6/2/2005 6:19 PM
afterburner
Score: 110
Status: offline
Anyone flying this plane off of a small grass field yet? Just curious to hear how that might be working out.
Marty
Hide Signatures
       Post #: 470
RE: Reaction 54 Jet Kit - 6/2/2005 7:17 PM
fast jets
Score: 100
Last Login: 9/30/2012
Status: offline
I have flown mine off a 350' grass strip twice. On both flights only half of that distance was used up. On the frist few flights it would be nice to have more but after that 300' to 350' grass strip should be fine.
John
Hide Signatures
       Post #: 471
RE: Reaction 54 Jet Kit - 6/2/2005 8:24 PM
Gary Szetlak
Score: 100
Status: offline
I have put about 25 flights on mine off of our grass field. It takes about 200'
Gary
Hide Signatures
(in reply to fast jets)
       Post #: 472
RE: Reaction 54 Jet Kit - 6/6/2005 5:34 AM
rcguy!
Score: 108
Status: offline
quote:
ORIGINAL: tschuy
quote:
ORIGINAL: rcguy!
quote:
ORIGINAL: tschuy
Tim,
Dave Rigotti
Cheers,
Tim,
Enjoyed the "cool one" with you on Sunday. I rec'd alot of compliments on how well the R54 flew. Lew McFarland thinks it looks alot like his SHARK 45 stunter from the 60's! Recorded flight #42 on Sunday.
Dave Rigotti
Hide Signatures
       Post #: 473
RE: Reaction 54 Jet Kit - 6/6/2005 4:00 PM
tschuy
Score: 111
Status: offline
Dave,
It was great to meet you in person and looking forward to the next time. for the rest of you R54 owner's in this area, Who's all going to the Heart of Ohio Jet Scramble ? Dates ar August 26, 27 and 28. Additional info can be found here: http://www.torks.com/JS-Flyer2.html . It be cool if we can get a bunch of us together.
Also talk to Lew McFarland and we starting the initial leg work to see if we can host a 2 day event here in Campbellsville. Tentative dates are for October 8th and 9th. Focus will be for us new guys to turbines and those who want to join the turbine world. We have a small airport here with new taxiways and tarmac which will be great for flying R/C off of. Additional information to follow as this develops.
Cheers,
Tim Schuy
tschuy@comcast.net
Hide Signatures
       Post #: 474
RE: Reaction 54 Jet Kit - 6/6/2005 11:16 PM
rcguy!
Score: 108
Status: offline
Folks,
I've had 2 flameouts due to the UAT being sucked low or dry with plenty of fuel remaining in the main tank. I checked my system for air leaks and found none. I could run the turbine at WOT on the ground without getting any air in the UAT. I would then fly for a few minutes and afterwards, the UAT would have a significant amount of air in it. I'm using a Jet Tech tank that was built to my specifications and holds 72oz's. I'm convinenced the forward facing clunk is getting exposed during flight. I DO fly alot of split s's, rolling and looping manuvers. The last flameout was at 1/4 tank on take off and climbout after a touch and go just after the wheels hit the wells.
I'm not saying Bruce's 50oz tank setup is bad. Quite the contrary. He has many more flights than I do. Others have not had this problem either. Is it specific to the volume of the 72oz tank? I really can't say. Bruce has done a wonderful job with this aircraft and all that fly mine are impressed with its flight qualities.
Anyway.....I've switched the tank around to have a rear facing clunk. All other fuel components stayed the same, the pump and valves, etc. I cut a hole in the LE bulkhead to allow the tank tubes to pass through. I routed the overflow out the bottom just in front of the leading edge as before and the pickup line gets routed to the rear mounted UAT. I've got 10 flights on this setup and am happy to report that the MOST air in the UAT does not even get to the cap. I'd say 1/15-1/20th. I flew this at Bardstown, KY with alot of airport runway at my disposal if needed. I'm comfortable with it now. I did need to install the tygon tubing after the tank was installed.
Below are some pictures of MY setup. Again...On MY R54 I found this necessary to do. Yours may be different.
Dave Rigotti
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by rcguy! -- 6/8/2005 2:58 PM >
Hide Signatures
       Post #: 475
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.078RCU1
