racer8297
Joined: 3/31/2003 From: Macungie, PA, USA Status: offline
John, I am using 1/4" of crow and it seems to help. One thing that I read somewhere (can't remember where) is that when on final, you don't want to be able to see the top or bottom of the airplane. If you see the top, you are to fast. See the bottom, you and you are to slow. My CG is at the rear limit. My elevator is set to Bruce's recommended throws and I run 40% expo up and 15% down. Once over the threshold, at about 10 feet AGL, I wipe the throttle. Then I feed in up elevator and bring the nose down but I try to keep it off the ground as long as possible. Then it touches down and rolls out about 20 feet. Another thing. I installed a Prolink front strut from Dreamworks with a 2.25" wheel. This lets the nose sit lower a little. I think that it totally eliminated the tendency for the airplane to take of again if I touch down a little fast. My feeling is that it lowered the wing's angle of attack when on the ground. I see that you live in Connecticut. You should try to make our jet event in October and Farview. I will have my R54 and there were 3 others here last year. The invitation goes out to everyone, by the way! www.farviewflyers.net Jim
