Goldberg Extra 300
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Kit Building >> Goldberg Extra 300
Page: [1] 2 3 4 5 6 7 8   next >   >>
Login
Goldberg Extra 300 - 12/5/2004 8:45:28 PM
bigcam
Status: offline
I am just about to start a Goldberg Extra 300. I would appreciate any comments or ideas on improvements to make in the construction. What should I use for power? I was thinking about a YS 110 but if this is not available due to supply constraints; what would you suggest? I am going to use a TNT landing gear and Fiberglass Specialties Cowl and Canopy although I have not purchased them Yet. Looking for ideas!
Bill
       Post #: 1
RE: Goldberg Extra 300 - 12/5/2004 11:09:36 PM
powellrc
Status: offline
I and several friends use to fly them with Super Tiger 90. Flew GREAT! Add a little re-inforcement under the fuel tank support.
(in reply to bigcam)
       Post #: 2
RE: Goldberg Extra 300 - 12/6/2004 12:30:51 AM
BankYank
Status: offline
Try an OS1.08 with a 14X8 APC prop. I did nothing to mine exept enlarge the lightining holes in the fuse a little bit and use the duel aileron servo setup. I have not flowen it yet but have seen this combo and man what a performer!
_____________________________
I tell ya she turned me into a newt she did
(in reply to powellrc)
       Post #: 3
RE: Goldberg Extra 300 - 12/6/2004 5:44:53 PM
loser
Status: offline
The YS 1.10 would be perfect. I built the 300 about ten or twelve years ago and put in one of YS's first 4 strokes...the f-1.20. It was an awesome combo. That was absolutely my favorite plane to fly before I got one of the patrick 1.20 size ultimates five years ago. I wish I still had the extra.....I do still have the plans.....Mmmm .....winter is just starting here.......Mmmmm.
(in reply to BankYank)
       Post #: 4
RE: Goldberg Extra 300 - 12/8/2004 2:46:07 AM
plasticjoe
Status: offline
I just put a Goldberg Extra 300 on order, already have the SuperTiger 90 to put in it. I would also be very interested in any upgrades or mods to the kit to make it better. Also what would be a good size fuel tank and prop to use on this ? Not looking for 3d, just nice aerobatics.
(in reply to loser)
       Post #: 5
RE: Goldberg Extra 300 - 12/10/2004 8:25:52 PM
bjw4072
Status: offline
If you will be flying from thick grass, I suggest that you try moving the landing gear forward
about an inch or so. I have no trouble on hard surfaces or very short grass, but it is very difficult
to taxi on thick grass without nosing over.
I replaced the stock landing gear with a carbon one.
Have Saito-150 in it that is excellent.
       Post #: 6
RE: Goldberg Extra 300 - 12/11/2004 7:57:04 PM
bigcam
Status: offline
Now I am getting confused. Looks like ys 110's won't be available for several months. Considering OS 1.08 2C or 120 Surpass III 4C with pump. Did any one put a larger tank in their plane? Plans call for a 12 oz tank and I don"t think that is large enough for the 1.08 2C. I will be flying off grass so the LG comment is appreciated. I plan on using a TNT Al gear. Any comments are appreciated. I just got back from knocking the LG out of my Ultra Stik 40 due to a sudden gust on landing. Maybe this is the last flight till spring. This weather reallu s--ks!
(in reply to bjw4072)
       Post #: 7
RE: Goldberg Extra 300 - 12/11/2004 9:04:00 PM
Redrata
Status: offline
Hi. I am building my second Extra. It is almost ready to cover. I angled the LG base, so when LG is sitting on the base, is a little forward. My first Extra nose over all time. Also I enlarged the rudder a lot and the ailerons. While flying my first Extra, I noticed that having more rudder would be better, so I did. I am using for power a Saito 180, the engine/plane is a nice combo, I mean, really good. I have available a YS 110, but not interested on use it here, dont think it would be fun at all. If someone would like some pics of the rudder and LG modification I will post them.
Click to see fullsize image.
Click for fullsize
       Post #: 8
RE: Goldberg Extra 300 - 12/11/2004 9:11:12 PM
bigcam
Status: offline
What size tank did you install and do you have to do any mods to install it?
(in reply to Redrata)
       Post #: 9
RE: Goldberg Extra 300 - 12/11/2004 10:13:00 PM
donkey doctor
Status: offline
Hello; I built one of those 10 years ago too, I still have mine but haven't flown it for 6 years or so. Let's see, I bought aluminum landing gear for it after the first year. Then I bought a fiberglass cowl and wheel pants the second year. I flew it with a Saito 120 for the first two years but put an OS 91 in it and liked that better, after that. I put two aileron servos in it, and covered it like the box cover. I cartwheeled it on a down wind landing and kind of mushed the wing tips up a bit. I flew it quite a bit back then but never did get around to fixing teh wing tips. It hangs in my bedroon mow, it still looks pretty good.
       Post #: 10
RE: Goldberg Extra 300 - 12/11/2004 10:14:39 PM
Redrata
Status: offline
I found a Graupner square 500 cc thank that fits perfect without any modification. I will post some pics tomorrow, my camera is not here. I will show you also the rudder and the LG platform I did. I am using the TNT aluminum LG.
If not Graupner, I think you can find any other brand, but square, that is the trick.
       Post #: 11
RE: Goldberg Extra 300 - 12/12/2004 3:24:18 AM
plasticjoe
Status: offline
Is that the 13 ounce graupner tank ? I have one of those in my Showflyer. I was seriously thinking of the Aluminum gear. My Goldberg Ultimate Bipe had the wire gear in the kit, didn't even try putting those on. Got a set of aluminum and love em. Any suggestions on the setup of the radio equip ? Flaps, pull pull rudder, dual elevator servos ? What are some of the setups you have used or seen used on this plane ? Any Ideas would be great. All I have decided so far is adding aluminum gear if it does not come with fiberglass cowl and pants, then getting somea those, and using a Supertiger 90 in it.
       Post #: 12
RE: Goldberg Extra 300 - 12/12/2004 8:50:23 AM
Redrata
Status: offline
Hi. My digital is an old version so pics are not that great for details. I made a new hard wood plywood LG base and glued it at certain angle so the LG is a bit forward to avoid nose over. Inside you will have to make the appropriate reinforcement with hard wood triangle stock, etc. Then you can see my gas tank, is a 500 cc!, but fits perfect into the original designed tank compartment. Last, you can see my rudder vs the original one (old plane), it actually looks more elegant and I hope that it will work much better. As for servos, I am using pull pull in rudder (90 oz), two elevators at the back of the fuse (51 each), two ailerons (around 60 oz each).
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to plasticjoe)
       Post #: 13
RE: Goldberg Extra 300 - 12/12/2004 8:54:01 AM
Redrata
Status: offline
Fuel tank, rudder.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 14
RE: Goldberg Extra 300 - 12/13/2004 1:55:56 AM
plasticjoe
Status: offline
That rudder looks like my Ultimate Bipes' rudder. I may seriously consider that mod as well. One can never have too much control surface !
