WestCoastFlyer -> RE: Goldberg Extra 300 (7/19/2009 12:43 AM)
My neighbor came home and he brought over a cool little plastic angle gauge. It's articulating, probably used for drafting. We took turns holding two straight edges and also used the carpenters sliding bevel. And I hope Gray Beard is sitting down, the right thrust, according to our crude measurement process of eyeballing with straight edges, is a whopping 4 degrees. But his could be wrong information. From my first measurement with the sliding bevel it's 3 degrees right thrust. Down thrust is 3 degrees, which is 2 degrees more than the factory suggests. Goldberg has it Right 2, Down 1. Without measuring properly, which I admit, it's safe to say mine is Right 3-4, Down 2-3. You know what to do about the gear, but I should mention the cowl because taking mine off yesterday I've developed a few more lengthy cracks behind the spinner that weren't visible with the spinner on. My cowl is a bear to get off/on due to my cutout and the Enya, the valve cover has to come off. The ABS cowl that comes with the kit needs to be glassed, not entirely, although it'd be a good idea, but the inside front of the cowl definitely needs to be heavily glassed. Over the years my cowl was also burning/melting where my straight pipe runs (not touching the cowl but hot enough) and over the years I'd glassed that length of cowl several times. The glassing that finally worked was when I glassed in a couple layers of aluminum foil that run the length of the cowl with the straight pipe. You should consider doing a build thread when you build yours. You'd get a lot of backseat drivers in that build bugging you [;)] but I think the Goldberg Extra deserves the attention and I know you will love your airplane.
