Which pylon plane will do over 150?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pylon Universe - RC Pylon Racing >> General Racing Discussion >> Which pylon plane will do over 150?
Page: [1]
Login
Which pylon plane will do over 150? - 12/14/2001 6:13:30 AM
JohnVH
Status: offline
But is very low cost? must have landing gear on it and be conventional.
_____________________________
---AIR VH---*FURY FLYER* www.3DFoamy.com
       Post #: 1
Which pylon plane will do over 150? - 12/14/2001 6:01:54 PM
MMallory
Status: offline
John,
when it comes to pylon planes, it's more about your engine and prop than the plane when it comes to speed. The Racer II is an inexpensive plane that will fit your use. http://www.pylonworld.com/rc_pylon/q-500/planes/q-500_planes_racer_ii.htm
(in reply to JohnVH)
       Post #: 2
Low Cost Racer - 1/5/2002 10:57:59 PM
kevin4hsrcm
Status: offline
The plane is normally the least expensive part of a pylon racer unless you are into the composite racers. Any Quickie 500 pylon racer will do over 100 mph. As said above, it is the engine, prop, and exhaust system that makes the difference. A Scat Cat or Dodger kit can be purchased for $35 - 40 USD. With a stock BB 46 and a 9 x 7 APC, stock muffler will run over 100 MPH (approx 120 MPH). Many areas are running a modified AMA 424 class with K&Bs, TT 46 PRO, and OS 46FX.
You can purchase the Lanier RC Dominator for about $50 USD, or if you prefer an ARF, you can go with the Viper or Predator. I personally don't care for the ARFs, though that is personal preference and you building skills. You can run a Mac header and tuned pipe and get 140 - 150 MPH out of a stock BB 46. The whole key is to build light and strong (as with all planes). You can put a JETT Quickie 500 motor on a Quickie 500 racer with a pylon racing prop (8.75 x 7.0) and get 160 - 180 mph. If you are just looking for speed, look for a Hyper. I have one with a Sport Jett 46 with a Jett mini-tuned pipe that hits about 200 mph (what a thrill!). A friend of mine is running a Nelson Quickie 500 (AMA 428 Class) with a hand carved prop that has been clocked at 220+ mph. A Hyper kit is only about $40.00 (foam delta wing).
Hope that this helps you out in some way.
       Post #: 3
The Racer II - 1/8/2002 11:58:19 AM
Bill Vargas
Status: offline
Mark, thanks for the kinds words about The Racer II,,, for some reason, I can t seem to keep enough kits Ready for shipment
Bill Vargas
NMPRA 41C
< Message edited by Bill Vargas -- Jan 8 2002 7:00AM >
If it ain't leaking oil, then something's wrong,,, USMC, RETIRED!
       Post #: 4
Dominator 500 - 1/15/2002 5:57:38 AM
jethead
Status: offline
I also need a cheap plane to do 150mph to get my turbine waiver. I have a JETT 50 and was thinking of getting a Domiantor 500. Any thoughts on this how fast and what prop. Rick
       Post #: 5
Dominator and Jett 50 - 1/15/2002 10:08:22 AM
daven
Status: offline
A Jett 50 on the Dominator will put you pretty close to 150 mph, maybe a little higher with the right prop and weather.
The Arf version of the Dominator would get you in the air quicker. Its called a Predator 500 and I saw one fly about 2 weeks ago with a Sport Jett .46 and the plane held up well. The Predator needs a little bit of modification for strength, but is a good overall value.
Dave Norman
klasskote.com
supertrc.com
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.438RCU1
