grayle
MN, USA Status: offline
Hi, everyone, its been a while and I finally have the balls to try and maiden my nobler. I went to the field last night to fly my gasser 4 star and after getting it fueled up and ready to go, I found out the receiver battery was completely dead. Luckily enough I brought my nobler. Well the dead battery must have been a sign. So I fueled up the nobler, started the engine, and adjusted the needle. The OS 46AX ran perfect. Now comes the bummer. I try taxi under a little power and I can tell the tail seems a little light. We have a grass field and the rear just kept bouncing. I didn't get to far and the thing nosed over! So I tried again, and nosed over again. The third time the right wheel shaft turned ninety degrees, and found out the set screw let loose up on the retract mechanism. I tightened it down and checked the other side just to be safe. I taxied out again brought the power up a little more and bam prop hits the ground and kills the motor. So much for that, I gave up. I have it balanced at about 3.75" back and I think I'll try to move it to the rear most CG like Jimcork to me to. I might also try to angle the retracts a little forward with washers under the trailing end of the retract mechanism. I was using an APC 11x6, but I think I'll try to gain some more clearance with a 10x6. How's it going for everyone else? Grayle
_____________________________
Goldberg Eagle II,GP Super Skybolt,GP Reactor EP 3D Top Flite Nobler,Sig 4*120,E-Flite Blade CP+
