RE: Zeroli P51 Build
Tower Hobbies
Logged in as Guest
  Printable Version
Hangar 9 P-47 D Thunderbolt - 150
Seller:  ace123jim
Details:   $1,475.00   |  7/8/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Zeroli P51 Build
Page: <<   < prev  1 [2] 3 4 5 6 7 8   next >   >>
Login
RE: Zeroli P51 Build - 12/20/2004 5:01:42 AM
Arthur K
Status: offline
Well guys now its day seven and I could not work on the fues untill I get my hands on another control rod for the rudder so I broke out the ribs and started on the Wings
can you see that I hate loose ribs
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Artin
rafko@rogers.com
(in reply to gary9648)
       Post #: 26
RE: Zeroli P51 Build - 12/22/2004 3:53:38 AM
Arthur K
Status: offline
Day 8&9 were spent mainly on the wing. After sheeting the top of the wing I decided to take a look at the flaps and ailerons and I got a major migrain.
Nick sorry man but there must be a easier way to do this, I meen cuting triangles in to the wing and 1/8 balsa trailin edge shaping the leading edge of the flaps hinges way on the base of the flap OUCH it;s a nightmare.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Artin
rafko@rogers.com
(in reply to Arthur K)
       Post #: 27
RE: Zeroli P51 Build - 12/22/2004 3:59:18 AM
Arthur K
Status: offline
I also managed to glue the retract plate
Notice how I have not sheeted the top wing directly above the retract I will sheet this portion after the instalation of the gear door
Click for fullsize
< Message edited by artin -- 12/22/2004 5:51:38 PM >
Artin
rafko@rogers.com
       Post #: 28
RE: Zeroli P51 Build - 12/23/2004 4:47:15 AM
IFLYRC-RCU
Status: offline
Arthur..
Tried several times to fax the 9 page building guide.. won't go through.
Says a poor line connection ??
Send your address, I made a copy for you..... If you still need them. Or, give me some insight into your fax situation ??
Good Day.
JIM
IFLYRC - IMAA
       Post #: 29
RE: Zeroli P51 Build - 12/23/2004 5:04:46 AM
Arthur K
Status: offline
Hi Jim you can send it to Arthur Krikorian 252 Bearing Av. Toronto Ontario Canada M8Z 3A3
Artin
rafko@rogers.com
(in reply to IFLYRC-RCU)
       Post #: 30
RE: Zeroli P51 Build - 12/24/2004 4:39:21 AM
Arthur K
Status: offline
today I worked on the second half of the wing tomorow I will try to join the wing halves and shim it up and to place the proper washout and sheet the bottom
Click for fullsize
Artin
rafko@rogers.com
       Post #: 31
RE: Zeroli P51 Build - 12/24/2004 6:25:12 PM
IFLYRC-RCU
Status: offline
Arthur..
Mailed the instructions today .. US Mail. Who knows how long to Canada, Eh ?? lol
Have a happy Holiday.. Keep Building !
JIM
IFLYRC - IMAA
       Post #: 32
RE: Zeroli P51 Build - 12/25/2004 2:21:57 AM
ramcfarland
Status: offline
Whats the finished spec's on your Ziroli P-51? I like the build sequence thus far.
Merry Christmas!
Fast Richard
       Post #: 33
RE: Zeroli P51 Build - 12/29/2004 11:10:36 PM
Capt G
Status: offline
A very intimidating project! I have been following along with great interest. You have finally motivated me to start mine. It will be a little different since i've got the f-glas fuse but I thought I would start with something relatively easy like the rudder. here it is roughed in.
Click for fullsize
       Post #: 34
RE: Zeroli P51 Build - 12/30/2004 2:32:58 AM
timothy thompson
Status: offline
If Anyone comes across a p-51 called death Rattler it was silver and had a checkered tail. The pilot Harry Tope died in the plane doing aerobatics. His wife, also a pilot, owns an AT6 SHE REQUESTS NO ONE MODEL HER LATE HUSBANDS AIRCRAFT. tHEY WERE FROM mt pLEASANT mICHIGAN!
The aircraft shown here is not the one!
       Post #: 35
RE: Zeroli P51 Build - 12/31/2004 9:23:33 PM
Capt G
Status: offline
A rainy day so here we go with the elevators - 1/2 done. I decided to use robart hinges and I moved the control horn blocks so I can mount the elevator servos in hatches in the bottom of the stab.
Click for fullsize
(in reply to timothy thompson)
       Post #: 36
RE: Zeroli P51 Build - 1/1/2005 5:26:15 PM
Jahna
Status: offline
Hi
It's interesting to follow the progress on your P51 Artin. I am sure it will end up with another nice Stang in the sky!
Does anyone know here of someone who modified the Ziroli P51-D to a P51-Version?
Would like to know all about it as it is my goal to build the B-Version on Ziroli base. Hope to get your feedback soon, thanks!
André
(in reply to Capt G)
       Post #: 37
RE: Zeroli P51 Build - 1/18/2005 4:29:57 AM
lightningman40
Status: offline
Hi Art, How is the P-51 going? I love this plane, I have two of them that I am building at the same time. I have not worked on them for awhile now but I am going to get back on them this week now that I got laid off and have lots of time to work on them. I also am going to build a Ziroli P-38, I have the plans and should have the kit for it by the end of the week.The wife will sure be proud of me for getting another plane and getting laid off. Well nuf of that, good luck with the stang. I will check back to see how its going.It sure looks good so far.
       Post #: 38
RE: Zeroli P51 Build - 1/19/2005 2:32:25 AM
IFLYRC-RCU
Status: offline
Were's Art ? He seems to have dropped off the face of the earth in late Dec ????
Did the instructions I copied and sent to you get there OK ??
Hello ????
Hello ????
Allo Allo ' ??????
IFLYRC - IMAA
(in reply to lightningman40)
       Post #: 39
RE: Zeroli P51 Build - 1/26/2005 7:35:15 PM
