RE: Zeroli P51 Build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Zeroli P51 Build
Page: <<   < prev  1 2 3 4 [5] 6 7 8   next >   >>
Login
RE: Zeroli P51 Build - 12/3/2005 1:29:47 AM
Metalmorphous
Status: offline
Artin your Mustang project look fantastic. Some day I would love to build one so I am going to say with this post untill you finish her. A Metal-Morphed Mustang would look great in our stable Our process of Seamless Alunimum plating is very durable and will not scratch but unfortunitly its not a DIY process.
Ron Randall
www.metal-morphous.com
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Metalmorphous -- 12/3/2005 1:39:13 AM >
_____________________________
(in reply to Skyflying1)
       Post #: 101
RE: Zeroli P51 Build - 12/3/2005 2:02:59 PM
eugene
Status: offline
Skyflying 1,
I used this trim scheme on my TFGS, it is documented as RED DOG X11. Glassed and painted with Chevy Impala Silverstone metallic, then clear coated.......If you would like a photo, send your Email address I am not sharp enough on this machine to scan the pics..
       Post #: 102
RE: Zeroli P51 Build - 12/3/2005 4:36:23 PM
Skyflying1
Status: offline
quote:
ORIGINAL: eugene
Skyflying 1,
eugene,
Please send them here: waderussell@gmail.com Thanks! ~ Wade
(in reply to eugene)
       Post #: 103
RE: Zeroli P51 Build - 8/22/2006 3:31:25 AM
Hello82
Status: offline
Hello
I'm new to this forum and getting back into R/C for the first time since
the 80's and my youth! Built a bunch of planes back then and now I'm
excited to build the dream giant P-51 I've always wanted.
Just ordered the Ziroli plans and scouring for as much info as I can about
what to expect in happy surprises, minor problems, and or changes to be
made from the plan, building choices etc.
I love building from balsa so I'm pretty sure I'll do the whole kit that way.
I have not received the plans yet...I feel like a kid anticipating x-mas!
Love to see more pictures of the P51 build ArthurK ..is it done yet? ....and more of what you guys are all doing...they look great
the ones that are up. Some great tips!
Mat
       Post #: 104
RE: Zeroli P51 Build - 8/23/2006 4:16:32 AM
chippy05
Status: offline
Hi i really want to build a WWII fighter which would you recommend for a 12 year old that has some building experince
mick reeves 1/4 spitfire, ziroli p-51, or the ziroli p-40. and if i build and of them do you think the quadra-aerrow Q70 eletric egnition
also how do you make a 3 piece wing because i'm building a eletric mirco f-16 with speed 380 motor i want to pratice panel lines and 3 piece wing on the micro f-16
(in reply to Hello82)
       Post #: 105
RE: Zeroli P51 Build - 9/11/2006 8:47:12 AM
turbinelover
Status: offline
Hi,
Come on guy's I need more pic's, I just started my Ziroli P-51 and I need help!!
All my parts were cut by hand and in 3 days I built the fuse but I am not going to sheet it till
my wings are framed and the tail is built. I will show you pic's in the morning when I have good light out side.
Regards,
Dan
(in reply to Metalmorphous)
       Post #: 106
RE: Zeroli P51 Build - 9/12/2006 8:59:38 PM
Skyflying1
Status: offline
OK Dan...the scoop. I'd work on the wing first and then hit the scoop last. You'll need the wing
sheeted in the saddle to properly fit the scoop as it attaches to the bottom of your wing skin as
well as the fuse. I made some ply-wood brackets for the scoop and epoxied them in place. I
shimmed the outer edge of the scoop on the fuse to get a smooth fit from the fuse to the scoop.
Let me know if there are other pictures I can help you with. ~ Wade
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Skyflying1 -- 9/12/2006 9:01:02 PM >
(in reply to turbinelover)
       Post #: 107
RE: Zeroli P51 Build - 9/12/2006 10:52:05 PM
Hello82
Status: offline
Hello
Recieved the plans a few weeks back and have them on the wall while I finish up my H9 P-51 1.5. . Plans l ookgreat...still deciding which kit builder to go with?
Not to take away from this killer site and forum, but if you want some more building shots, check this out - it's in German though but lots of pics.
http://www.jahraus.de/Home/Modellflug/Modelle/Mustang/Zirolimustang-1/zirolimustang-1.html
best,
Mat
       Post #: 108
RE: Zeroli P51 Build - 9/12/2006 10:53:32 PM
turbinelover
Status: offline
Skyflying1,
Thank's, That will help me fine. Please post wing and tail pic's and firewall pic's
also I am using 1/5 scale gear not the Robart off set gear so I will have to do some mods to the
gear blocks on the wing.
Regards,
Dan
       Post #: 109
RE: Zeroli P51 Build - 9/13/2006 3:00:23 AM
Skyflying1
Status: offline
quote:
ORIGINAL: turbinelover
Skyflying1,
Regards,
Dan
Here is earlier construction showing the rudder and elevator.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 110
RE: Zeroli P51 Build - 9/13/2006 3:05:18 AM
Skyflying1
Status: offline
Here is the wing in stages, I used carbon cloth in the main stress areas.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 111
RE: Zeroli P51 Build - 9/13/2006 3:11:14 AM
Skyflying1
Status: offline
I used the wood given in the kit for the firewall and added dowels to pin this in place. Also
I added carbon fiber cloth to the front that wrapped around the gas box. I wrapped this area twice,
once from the sides and once from the firewall back.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 112
RE: Zeroli P51 Build - 9/13/2006 3:15:55 AM
Skyflying1
Status: offline
And for the landing gear I used 1/4 ply wood laminated with carbon on top and bottom.
The wing had to be dug up a lot to make this modification however it's really strong.
The mains are from Sierra Precision.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 113
