bob27s
OH, USA Status: offline
Hi Kelley Looks like that project has progressed nicely. Sharp looking aircraft. The end exhaust exit fitting in the header is shrunk fit (interference fit), and sealed with a high temp loctite 'glue'. Similar process used to assemble the jett mufflers. It is unlikely you will be able to remove it, other than by cutting it free from the header. I do not entirely follow this... quote:
The pipe consists the header with a .625” rise and a 12” length of straight .875” tubing with a 3/8” plug in the end. After receiving the engine and exhaust I have come up with “Plan B” for the exhaust. Rather than use the 12” tubing I am going to remove the 3/8” plug and reinsert it into the header. It sounds like you wish to make the header shorter, and then reinstall the outlet piece ? Is that correct? If so, you would have to cut the header to the length you desire, then cut the outlet free from the scrap piece. If this is your intension, you may want to drop Dub an email directly for advise on how to best complete this process. As for outlet and tube size. I believe it was understood you were using 3/8" flexible tubing, as commonly used for exhaust diverters/extensions. Hose/tube is defined by inside diameter. The end outlet is sized around .5" so the 3/8 material would stretch and secure properly over the outside of the exit. One of the keys here is that the exhaust system extention has to be larger in inside diameter/cross section than the exhaust exit. The .355 outlet exits into a .375 tube, which is what you want at a minimum. Plus, Dub sizes exhaust exits to obtain the correct flow and back pressure in the exhaust system. If you were considering solid 3/8 tube, then that would be an issue. Solid tube is sized by the OD (outside diameter). In which case, you would want to use closer to .50" tubing (.062 wall gives you .38 inside dia), and couple the header to the tube with a length of silocone coupler material. I understand where you are going with this installation. But if this were my installation, I'd simply rout the exhaust out the bottom of the plane, making that extention tube as short a possible. If I missed something here, please let me know and I will try to help further. Bob
_____________________________
Bob Brassell Jett Engineering - Engine Mfg Support Forum Host
