regis
[QUOTE]I hope that everyone understands that if 424 was to be run at the nats with the current wording, you could see Nelsons, Jetts (if they choose to produce a un-piped muffler) and composite airframes. Which to me says that if I was competing at a local level with my predator and TT40, I need to go buy the fast stuff to win. I don't want this to happen. It is supposed to be an entry level event without all of this other stuff (that is what 428 is for). [/QUOTE] Everybody, please re-read the current AMA 424 rules. Several years ago, a NMPRA team spent more then a year "[COLOR=seagreen]unifying[/COLOR] " the the rules and that is what we have now . 424 has picked up since then. AMA can not make a list. (keep in mind that there is a two year rules cycle .) The predator and TT40 are as competitive as your abilities - against any other [COLOR=red]AMA legal [/COLOR] 424 plane/engine combination (bar none). Composite airframes have no advantage over a well crafted woodie. The single most effective restriction is the 16.5K rpm limit. Remove (or even modify it) and "Katey bar the door" - forget 424. Are the 424 rules perfect? Are the 428 rules perfect? Are any rules perfect? (Well maybe the ten commandants!) The current rules can support 424 at the nats and should be used just as they are. Just put enough shims in the head to preclude exceeding 16.5K (on the pinch). Don't weld your stock non-tuned muffler closed and make sure the stock carb is legal and use whatever .40 engine you desire. If you want to spend $300 dollars on an engine and $400 on a composite plane, fine with me. I am confident that my TT40 woodie (in the right hands ) will be just as competitive. Remember, we are talking about AMA Nationals - not local racing. 16.3.3.b. provide the rule variations that work well for local racing (and are AMA sanction-able) - thanks to the NMPRA team's efforts. Finally, if RCPRO has done nothing for you, then I guess you haven't been using this forum or any of the informational pages Don has authored. In the past year, Don through PylonWorld's web site has done more to promote pylon racing then any one else. P.S. Mike, Are you saying that your wooden plane are not competitive against the composites?
_____________________________
Regis 0o
