RE: NEW: Tensor 4D - Building & Flying!
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Tensor 4D ARF
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> Electric Aircraft Universe >> 3D Electric Flying! >> RE: NEW: Tensor 4D - Building & Flying!
    Page: <<   < prev  11 12 13 14 15 16 17 [18] 19 20   next >   >>
    Login
    RE: NEW: Tensor 4D - Building & Flying! - 4/13/2005 3:42:55 AM
    Devin McGrath
    Status: offline
    Not sure on the thrust on the 2204 but it only weighs 24g and on thee cells it pulls a tensor strait up like a missile. I know this is way beyond the ratings for this motor but I have not had a problem yet .... On a 9x4.7 on three cells it draws 9.5 amps. full throttle is rarely used.
    _____________________________
    Devin McGrath
    www.devinrocks.com
    (in reply to tylerman)
           Post #: 426
    RE: NEW: Tensor 4D - Building & Flying! - 4/13/2005 4:40:18 AM
    Y N C
    Status: offline
    The AXI 2204 puts out 10oz of thrust and the 2208 17oz.
    (in reply to Devin McGrath)
           Post #: 427
    RE: NEW: Tensor 4D - Building & Flying! - 4/13/2005 2:27:59 PM
    tylerman
    Status: offline
    10 ounces --If I tried to hover my plane it would fall on the ground-or am i getting the wrong idea here??
    When they say "10 ounces of thrust" does it mean that that is what it is capable of pulling or is it the the weight of the plane you should pull with.
    I dont think that ia m getting this
    ...Of course I meant to do that
    (in reply to Y N C)
           Post #: 428
    RE: NEW: Tensor 4D - Building & Flying! - 4/13/2005 6:14:50 PM
    Shadrack
    Status: offline
    That is the thrust that the motor is putting out with a certain prop. That will change if you use different props. Need more information to put a thrust number on a motor. You want more thrust than the complete weight of your plane if you want to hover, at least 1.5 to 1 or greater.
           Post #: 429
    RE: NEW: Tensor 4D - Building & Flying! - 4/13/2005 9:26:45 PM
    jackmccomas
    Status: offline
    Just went out and bought my Tensor for my son today, I want the awesome setup, Horizon sugessts the Park 370 Outrunner Brushless, 1360Kv, 7.4V 860mAh 2-Cell LIPO,JST & the 10 x 4.7 Slow Flyer Prop, is this really the best setup? I fly only outdoors. Any help would be greatly appreciated!
    (in reply to Shadrack)
           Post #: 430
    RE: NEW: Tensor 4D - Building & Flying! - 4/13/2005 9:31:28 PM
    Shadrack
    Status: offline
    I fly outdoors with that setup, with one change. I use a TP 2S 1900 battery because I wanted more run time and more weight. Works great, added just under an ounce, but in light wind, you want that weight.
    (in reply to jackmccomas)
           Post #: 431
    RE: NEW: Tensor 4D - Building & Flying! - 4/13/2005 9:36:42 PM
    jackmccomas
    Status: offline
    Hello,
    I was thinking of using the same setup, how did it turn out?
    Best regards,
    Jack
    (in reply to AU flyer)
           Post #: 432
    RE: NEW: Tensor 4D - Building & Flying! - 4/13/2005 10:18:43 PM
    Shadrack
    Status: offline
    Well, being in winnipeg, I haven't had tons of time to try it out, but I did have one perfect night, light wind. Flew for about 15 minutes getting used to this plane (learn to use rudder, or learn to watch your plane going straight in a knife edge) and landed. Then some people came by and their kids wanted to see it fly so I landed my formossa and put the tensor up again for at least 10 more minutes. After getting it home, I still had around 500ma in the battery.
    I find with the extra weight it fly's more like an airplane than a box kite. It had no issue with the light wind, sank at a decent rate for landing, and still had plenty of power to pull up out of a hover (my version of a hover anyways). With this battery though, plan your weight. If you look back at the pictures, you can see how I mounted my battery, and by enlarging the slot so I can shift the weight back, I can drop to a 1200 2S and shed over 1/2 ounce right there. AUW is under 11 oz with the 1900 pack, and 10.4 with the 1200. If I drop to a 730, I'm sure I'd be close to or under 10.
           Post #: 433
    RE: NEW: Tensor 4D - Building & Flying! - 4/14/2005 5:03:31 AM
    tylerman
    Status: offline
    On my tensor we decided to not cut out a slot for the batt. for fear of it causing a weak spot in the airframe--
    Instead we put the Rx. and the ESC on one side so we could put the batt. on the other side and get it all balanced.
    With this setup i can lay a peice of velcro across the fuse to adjust the C.G. easily-- If you cut out a big hole and want to change your CG you are forced to make the hole bigger and that means that it would make it that much weaker.
    jackmccomas-I am running an AXI 2208/34-it is great, Some people are also running a AXI 2204/54. but if you go with that motor you will definately have to build light- i like lots of power and for some reason the 2204 doesnt seem like enough.
    Just my opinion
           Post #: 434
    RE: NEW: Tensor 4D - Building & Flying! - 4/14/2005 5:18:22 AM
    Y N C
    Status: offline
    Tylerman I'm sorry it's for plane up to 10oz. Not 10oz of thrust.
           Post #: 435
    RE: NEW: Tensor 4D - Building & Flying! - 4/14/2005 2:09:47 PM
    Shadrack
    Status: offline
    Tylerman.
    I thought of that too with the battery, but if you look at the picture, I put a rod of CF over the top where the slot was cut out for the battery for strength. There is enough left over from the kit when you finish to do it. The slot isn't that thick with a 2S battery so I noticed no difference in strength at all.
    (in reply to Y N C)
           Post #: 436
    RE: NEW: Tensor 4D - Building & Flying! - 4/14/2005 3:28:59 PM
    Y N C
    Status: offline
    Shadrack. Where do you fly in winnipeg? would you know Dennis W and Len C.
           Post #: 437
    RE: NEW: Tensor 4D - Building & Flying! - 4/14/2005 3:43:07 PM
    Shadrack
    Status: offline
    I usually fly at an open field near Lipset Hall, grant and keneston. About 4 soccer fields in size and a few blocks from my house. I don't know those guys, I do know a Len, but his last name starts with G, and he is into large jets last I checked. Don't belong to a club, with electric, I found that I didn't have to leave town to fly. I deal a lot with the guys at Cellar Dwellar, the only real hobby store here. Have been to a few fun fly's. Do you know Jim at Cellar Dwellar, he rented a place for an indoor fly a few weeks ago that he said went pretty well. No tensors there though, I should have brought mine, but had the kids that night. Where do you fly out of?
    (in reply to Y N C)
           Post #: 438
    RE: NEW: Tensor 4D - Building & Flying! - 4/14/2005 4:40:25 PM
    TManiaci
    Status: offline
    Shadguy,
    Tyler is flying 3S 11.1V batteries, TP730 & TP1320. Not 2S, which are much thinner. The cutout would completely sever the fuse because they are too thick.
    This thing SMOKES with the AXI 2208/34 and 10x3.8 on the 11.1V. Overpowerd, no doubt. He like that
    TMan
           Post #: 439
    RE: NEW: Tensor 4D - Building & Flying! - 4/14/2005 4:52:30 PM
    Shadrack
    Status: offline
    Ok, yes, you would cutout another chunk, probably right to the edge. But then again, with CF, you can keep it strong there, and I noticed no strength loss once I used CF, just wanted to keep the battery centered since it weighs more than my speed control and receiver.
    (in reply to TManiaci)
           Post #: 440
    RE: NEW: Tensor 4D - Building & Flying! - 4/14/2005 5:05:45 PM
