CA, USA Status: offline
Stupid Build Question please. The Manual calls for the side force generators to be positioned in the holes closest to the trailing edge of the bottom wing but there is only three holes and one small one. In order to have it positioned correctly do you need to cut one slot for the hole closest to the trailing edge??
Joined: 1/27/2004 From: Pretoria, SOUTH AFRICA Status: offline
Yikes this thread is long! The Tensor finally made it to my country and I had to try one out for kicks. I'm a shockflyer fanatic but this thing is too darn cute to not have one! Guys can anyone do a lazy bum a favour and if there is any just point out areas of concern regarding the construction? I tried scanning through the thread but on my slower than dial up connection it's a bit of a headache.
I found the bits about supporting the tail so I will look into that. I have some old shockflyer skeletons at home so I can snatch the carbon off of them to stiffen up the tail. Or I could do the mod the new shockflyers have with the triangle depron running between the horizontal and vertical fuselage pieces?
I am going to use my AXI 2208/34 with a 2S 910 Kokam. Also have some JR sub micro servos and a 610 rx. Pretty std stuff.
If I'm asking too much then so be it! But if someone is bored and wants to help me out...please?
Spacey- The build is very straight forward-The only thing that may get you is when you are trying to square the horizontal fuse. to the verticle fuse. We got ours straight as an arrow by using a table for a 90 degree angle and pushing the two pieces flat against it, You will enjoy this plane very much.
jackmccomas--You should not have to cut any holes. Or at least we didnt have to.. Just examine the plane carefully and try to figure it out.
A couple of days ago my dad dropped an electric screwdriver on my plane- It put a fat gash down the side force generator, and ripped the aileron linkage out of the aileron. Lucky for my dad I took my time and laid the peices that were ripped out back in the places they came from. It acually doesnt look bad at all-and you cant even tell unless you are up close. It did not change the way it flew in the least bit either--Depron is a great thing
AL, USA Status: offline
I just got back from SEFF and had a really good time! 25mph winds made it impossible to even get the Tensor out of the SUV! I met a bunch of really fine folks there but I just got to tell you all about one of the nicest, most approachable, humble guys there, George Hicks. In my mind George is a giant in our hobby, yet to meet him is to meet what feels like an old friend, that's a very rare thing!
p.s. Always wear a hat or sunblock when attending outdoor functions!!! (man it burns!)
< Message edited by harrymcwilliams -- 4/25/2005 4:33:43 AM >
quote:
ORIGINAL: tylerman
Thats pretty cool--It looks as if he signed your planes wing. Too bad it was too windy to see him fly.
If you dont mind me asking-What is SEFF?
Yeah, he signed it "Happy Hovering" and his signature. A true good guy!
What is SEFF? You must be new to electric flight!!! SEFF stands for Southeastern Electric Flight Festival It one of the biggest Electric shows/funflys in the world! Here's a link: http://www.rcgroups.com/forums/showthread.php?t=361983
quote:
ORIGINAL: tylerman
Dang you are a long ways away!!!
Thanks buddy! I got it in the air on Saturday. The build was easy enough although I have to admit handling this one takes alot of care. Only negative thing about the Tensor is it's strength that is for sure, not so much when dorking it (I avoid that as far as possible) but just carrying it around was a mission..LOL Do not take it out of the car in gusty winds!!!
It flies magically! I am still moving my CG around as I think I'm too far to the back, when I do rolling harriers I have to fight the nose down and that messes with my brain too much. After I mixed out some of the coupling it sure is a breeze to handle. Very stable in all aspects. One problem I have though is a slight lack of power, but if I keep things controlled it is ok and managable. Tail authority rocks although I need to get my ailerons more efficient. I don't have enough rons to oppose the coupling sometimes but I'll figure it out. Two thumbs up from me! Very welcome change in from my shockflyers! I love it!
Spacey--I am also flying a 2208/34 and my plane has power up the butt. I dont see why your plane would be slightly under powered. Just one question-- If you are running a Jeti or a Castle creations Pheonix ESC both of them recommend you run AXI motors in something called "hard timing". If you have one of these ESC's you might still be in soft timing...Hard timing is kinda like advancing the timing in a car engine--When you get up to a certain rpm it starts to advance the timing of the electrical pulses--Wich in turn makes the rotor turn faster--Hard timing is only recommended for outrunner motors(external rotor). I belive that there is almost a 20% increase in power when you change this.
tylerman,
I am using a Modelmotors 8A ESC at the moment but it is part of my problem yes. I am also using the 'newer' Kokam 2S 910 cells which have a little higher discharge rate than the old ones but this whole combination causes my esc to cut if you bump the throttle to full. So I had to limit the top end EPA untill I can find a slightly bigger esc. I don't know if my Tensor is a little on the fat side, it is possible. The Modelmotors esc doesn't have the option to adjust timing like the TMM/CC and so on controllers. I should get a 12A TMM for the setup but the spare cash is a little limited right now. Also one has to bare in mind that I am very high above sea level. I think it was around 4800feet so that makes things worse. I would also like to try a CC controller but I haven't seen them around here for affordable prices, will have a look out though when I get the money together to maybe go for something like that and see if the hard timing helps at all.
At the moment there is enough power to pull out of a hover but it crawls vertical so it's a little frustrating. Doesn't get out nearly as fast as my shockflyer does but o well. The Tensor is a bit of a gas bag either way so I guess it all stays in relation in some way LOL
You may want to look at the efliteesc as they are very affordable and I run one on my tensor currently. Good to 20A and about 2/3 the price of the equivilant CC.
Thats weird that it would cut you off like that because i am running a Jeti 8 amp. ESC and it never shuts off the throttle. I am also running much bigger batteries with much higher discharge rates--such as a TP 3s 1320 mAH.
If you read through the manual you might find that you can switch to hard timing as well.
Thanks tylerman I will check it out. We flew one of the tensors this weekend with a 3S 910 Kokam and it was much better. Actually easier to fly outdoors with this setup. I think it might be worth the extra weight to have the needed power as well. I will check into the Eflite speed controllers as I know the LHS has some of them for good prices. Might be worth it.
I would highly recomend a Jeti or a pheonix speed controller. I have not heard if the e-flight ESC are any good but these two controllers are a very good choice---Just my opinion
