RE: NEW: Tensor 4D - Building & Flying!
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Tensor 4D ARF
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> Electric Aircraft Universe >> 3D Electric Flying! >> RE: NEW: Tensor 4D - Building & Flying!
    Page: <<   < prev  11 12 13 14 15 16 17 18 19 [20]
    Login
    RE: NEW: Tensor 4D - Building & Flying! - 9/16/2005 5:24:44 PM
    RAZhamatis
    Status: offline
    in my tensor i dont have enough moving on the ailirons! what can i do to get mor movement??
    (in reply to Shadrack)
           Post #: 476
    RE: NEW: Tensor 4D - Building & Flying! - 9/17/2005 12:55:52 AM
    Shadrack
    Status: offline
    You need to lengthen the control horns on your aeleron servo. Either buy longer ones for it, or find a way to make longer ones by added pieces from another control horn and using thread between the holes and some CA to make sure they are glued.
    (in reply to RAZhamatis)
           Post #: 477
    RE: NEW: Tensor 4D - Building & Flying! - 11/29/2005 1:31:39 AM
    B. Bishop
    Status: offline
    Hey, guys, I just ordered the Tensor 4d, pretty excited cause its coming on wednesday and I was just wondering if these components for the Tensor 4D would be alright:
    -Outrunner Park 370 Brushless 1080KV
    -Hitec HS-55 Flight pack
    -20 amp brushless ESC
    -10x4.7 APC
    -Not sure what brand of battery pack but it is a Li-Po 640 mA 3cell
    -Celectra 1-3 cell charger
    _____________________________
    Just Fly.
    (in reply to harrymcwilliams)
           Post #: 478
    RE: NEW: Tensor 4D - Building & Flying! - 11/29/2005 1:36:42 AM
    B. Bishop
    Status: offline
    What would you say to the red Z06?
    Just Fly.
    (in reply to B. Bishop)
           Post #: 479
    RE: NEW: Tensor 4D - Building & Flying! - 2/8/2006 11:54:01 AM
    betolorca
    Status: offline
    The best Prop for me is the APC 10x3.8.
    I fly with my Tensor EVERY day !!!
    Best to you all,
    Beto (from Brazil)
           Post #: 480
    RE: NEW: Tensor 4D - Building & Flying! - 5/5/2006 8:16:50 PM
    poulsbobill
    Status: offline
    Anyone have any up close pics of their aileron mods? I have seen the adendum, but not sure how to do it. Pics anyone?
    Bill
    (in reply to Jason W M)
           Post #: 481
    RE: NEW: Tensor 4D - Building & Flying! - 5/5/2006 10:00:04 PM
    bhole74
    Status: offline
    This works really well. Cut a notch in top and bottom aileron and insert 1/32" strip of ply with small hole approx. 3/8" behind trailing edge. I have heard of some using a piece of a zip-tie instead of ply. Very smooth.
    Click to see fullsize image.
    Click for fullsize
    Click for fullsize
    Had I known that flight was going to cost me $100 per second, I wouldn't have flown 30 seconds!
    (in reply to poulsbobill)
           Post #: 482
    RE: NEW: Tensor 4D - Building & Flying! - 5/6/2006 2:29:25 AM
    poulsbobill
    Status: offline
    Thank you very much!!!!!!! One more question?
    Can i build her first and then attach the servos later? The instructions have you do it in the middle of the build as you know...any reason i cant do it later? I am going to take hardware off a different plane and would like to do it after she's built. Thoughts??
    Bill
    (in reply to bhole74)
           Post #: 483
    RE: NEW: Tensor 4D - Building & Flying! - 5/6/2006 3:24:36 AM
    bhole74
    Status: offline
    I put all my hardware on last thing, keeps me from accidentally glueing something that shouldn't be glued.
           Post #: 484
    RE: NEW: Tensor 4D - Building & Flying! - 5/6/2006 5:06:31 AM
    poulsbobill
    Status: offline
    Thank You!!!! Sounds good. Any other build suggestions? or flying?
    Bill
           Post #: 485
    RE: NEW: Tensor 4D - Building & Flying! - 5/6/2006 11:27:56 AM
    himagain
    Status: offline
    quote:
    ORIGINAL: poulsbobill
    Bill
    I have one after my Tensor Exploded in mid air.... On inspection of he right wing wreckage, the wing failed because the carbon rods joints had faailed. Make sure you put plenty of glue round the rods where they meet the foam as they tend to push through
           Post #: 486
    RE: NEW: Tensor 4D - Building & Flying! - 5/12/2006 10:07:10 PM
    poulsbobill
    Status: offline
    I figured it out!!
    < Message edited by poulsbobill -- 5/13/2006 2:29:16 AM >
           Post #: 487
    Tensor 4D ARF
  • See User Ratings
  • Jump to:
