E*nealio
Joined: 7/12/2003 From: Austin, TX, USA Status: offline
I"m still having prop issues. I went with the recommened setup, The 1080 kv outrunner, 860mah 10c constant 15c burst pack(Thunder Power). I have everything set right on my pheonix 10 and heck im using 2 tiny HEs 2003 servos and one Futaba 3108. The problem is i cant reach full throttle without it cutting, I have yet to go get my friends watt thing that plugs into your batter and speed contoller that tells you amps, so im not completely sure at these assumed amps. I want to run a 10 by 4.7 prop, i couldnt, then a 9 by 4.7, and still couldnt, then a 9 by 3.8 prop!!! WHAT THE HECK!!! I thought is wasnt supposed to draw that many amps, people say they are using 10 by 4.7 props and they work just fine. Im not flying at full throttle at all but when im hovering low, i want to get out of there(in a confined space with a lot of trees, so when i gun it in a bad situation, i get 5 feet up and it quits, luckily i reset the throttle by going back to low and back up to half and saving the plane!!! But i still want the assurance that it wont cut on me. For instance today, a calm 2-3 mph breeze(barely detectable wind, nothing moving). I go take off, hover around 1/2 throttle for a minute, i roll out and go into a inverted flight up to a hammerhead, i increase the throttle for the hammerhead and it cuts.........I dont get it. Is it that im running apc props instead of GWS props??? are gws props lighter and draw less amps? Im getting to the point that i really dread trying anything new, that i cant get out of......Any ideas on what the problem might be????
_____________________________
Is it supposed to make that noise?
