Can too much power be detrimental?
Tower Hobbies
Logged in as Guest
  Printable Version
Touchstart Remote Controlled Autostart Engine .61 ASP COLLECTORS !!!!!!!!!!!!!!
Seller:  vidal_felipe
Details:   $499.00   |  7/14/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> Can too much power be detrimental?
Page: [1]
Login
Can too much power be detrimental? - 12/17/2001 3:06:32 AM
Bozwth
Status: offline
I am putting a Super Tigre G90 on a small Aeromaster. I was told by the person that I bought it from that I should put at least a 60 on it. I flew another biplane of comparable size with a 60 and it just didn't have the verticle climb that I want in mine. The engine is the same weight and size as the G60, so weight and balence shouldn't be an issue. I'm planning on using a three bladed prop and checked for sufficient prop clearance, so that shouldn't be a problem. Are there going to be any problems that will prevent me from having a good flying airplane with this engine/airframe combination when it's completed such as too much torque or "P" factor?
       Post #: 1
OK - 12/17/2001 4:17:28 AM
Hobbsy
Status: offline
It should be fine with the G90 on it. Since the G90 is a torquey engine are you going to run a 13x8 three blade on it or a 14x7 three blade?
_____________________________
"I have gone faster backwards, upside down and on fire than most people have gone at all" Don Garlits
(in reply to Bozwth)
       Post #: 2
prop size - 12/17/2001 5:52:53 AM
Bozwth
Status: offline
I went to the Super T web site and it recommended a 12X8 or a 13X6 so I dropped 1 inch for the 3 blade and picked out a 12X6. Not enough?
Thanks for the reply, Robert
       Post #: 3
2 much power - 12/17/2001 6:57:39 PM
MMallory
Status: offline
bozwth,
Keep in mind when you add more power than recommended, you must reinforce the airframe, fly using the throttle (so you don't overspeed the airframe) and watch for making the plane too heavy.
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.234RCU1
