COX .049 plane engine Fuel
Tower Hobbies
Logged in as Guest
  Printable Version
Area 51cc Gas Engine - RTF
Seller:  Milton
Details:   $399.95   |  6/30/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> COX .049 plane engine Fuel
Page: [1] 2   next >   >>
Login
COX .049 plane engine Fuel - 12/19/2004 3:29:10 AM
ge01734
Status: offline
Hi,
I have a COX .049 engine in my airplane, but I've run out of fuel for the plane. I have other fuel that I use for my RC Car, which is Wildcat's 18% oil and 15% nitro. My question is it okay to use this fuel on my Cox .049 engine?
       Post #: 1
RE: COX .049 plane engine Fuel - 12/19/2004 9:59:44 AM
shoko1
Status: offline
Hi
Dont Use 100% Syntethic Oil To The Cox, Use 100% Castor or blend of the oils.
use 10-15% nitro and more than 16% Oil.
18% Oil And 15% Nitro Will Be Great... If its not 100% Syntethic Blend.
Good Luck, Excellent Engine.
(in reply to ge01734)
       Post #: 2
RE: COX .049 plane engine Fuel - 12/19/2004 6:21:10 PM
ge01734
Status: offline
Thanks Shoko1, really appreciate the help.
Have a merry XMAS.
(in reply to shoko1)
       Post #: 3
RE: COX .049 plane engine Fuel - 12/20/2004 1:34:42 AM
downunder
Status: online
Just in case you weren't aware of it, the reason you need castor in these engines is because of the way the conrod is attached to the piston. They don't use a wristpin but have a steel conrod permanently attached to the piston by a ball and socket arrangement which allows the piston to rotate as it's running. Castor stays inside this ball and socket while synthetics tend to get squeezed out.
       Post #: 4
RE: COX .049 plane engine Fuel - 12/20/2004 3:44:16 PM
shoko1
Status: offline
Thanks downunder... I Didnt Knew That.
(in reply to downunder)
       Post #: 5
RE: COX .049 plane engine Fuel - 12/21/2004 10:39:38 PM
Bax
Status: offline
Hmmm. The current specification on Cox engines is a fuel with at least 20% nitro. An excellent fuel for the 1/2-A and smaller Cox engines would be 22%-25% castor and 30% nitro with the rest methanol. They'll run excellently on this blend, giving you good power and longevity.
_____________________________
Bill Baxter, Manager Hobby Services/Futaba Service/North America
3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
Service Phone: 217 398-0007
Email: hobbyservices@hobbico.com
       Post #: 6
RE: COX .049 plane engine Fuel - 2/19/2005 6:20:15 PM
gfurr1
Status: offline
Interesting information.
Bill, do you know where to get a fuel with the percentages of Nitro and Castor that you suggest? I am especially interested in mail order. I understand the cost of shipping for gallon size containers but I don't have a choice here.
Glynn ..
Glynn
AMA30686
(in reply to Bax)
       Post #: 7
RE: COX .049 plane engine Fuel - 2/27/2006 3:42:29 PM
gocartdude
Status: offline
Hi
IS there someone who can tell me why we dont break in cox 0.049 engines and about castor ,can i make it bymyself at home?
(in reply to gfurr1)
       Post #: 8
RE: COX .049 plane engine Fuel - 3/2/2006 8:11:02 PM
MJD
Status: offline
Ditto that. I never had any joy with fuels below 15% nitro in Cox .049 engines (neglecting the Texaco as it doesn't apply to 99%+ of questions regarding Cox .049's). Below that you can tell they are just begging for more. Yes, you can get an .049 to run on 10% but the needle is more finicky and it just isn't content, so why bother for the few cc it takes per run? 20-25% makes them much happier. IIRC the Cox brand fuels are 22% castor? You'll be okay with a 20% oil, syn/cas blend if that's what you have available locally. Or pick up some 16-18% oil syn/cas blend and add castor to it to bring total oil up to about 22%. As everyone has said, don't run straight synthetic.
If/when you run an .020 or .010, run 25%-35% nitromethane, 25% minimum, same deal on oil. An .010 will barely keep running on 15% nitro.
MJD
(in reply to Bax)
       Post #: 9
RE: COX .049 plane engine Fuel - 3/19/2006 6:30:29 AM
loughbd
Status: offline
Cox made two fuels. "Blue can" and "Red can". The blue was the regular sport fuel and was 25% nitro. The red was their racing fuel and was 35% nitro. Both were 20% castor oil. Small engines give off their heat very quickly and heat is power. Cox engines, and most small engines, are most happy on high nitro fuels to keep the heat up. They will run on 10/15% but not up to their potential. As far as the ball and socket connecting rod, synthetic won't hurt the joint. They all loosen up eventually. Cox and K&K make a special little reset tool to solve that problem. You only have to do it once. Seems like the joint gets work hardened and doesn't loosen again.
I acquired about 15 gallons of Cox fuel (both kinds) awhile back. It's all in pint cans. runs great in the YS 4 cycles but it's a pain digging the little filler cap out of each can and pouring it into a gallon can.
(in reply to MJD)
       Post #: 10
RE: COX .049 plane engine Fuel - 3/22/2006 2:03:38 AM
car54
Status: offline
quote:
ORIGINAL: shoko1
Hi
100% synthetic blend? If it was 100% synthetic, it wouldnt be a blend, correct?
       Post #: 11
RE: COX .049 plane engine Fuel - 3/22/2006 2:38:17 PM
Jim Thomerson
Status: offline
Cox engines don't need much break in because of the precision with which they are made. They are in fact little jewels.
(in reply to car54)
       Post #: 12
RE: COX .049 plane engine Fuel - 3/22/2006 5:34:21 PM
gocartdude
Status: offline
ok guys breakin in cox means to run it rich for 2 tanks than lean it a little bit about the fuel i think its better to run 25%oil 80% castor 20%syn i have castor oil used for hair, is it good ?
(in reply to Jim Thomerson)
       Post #: 13
RE: COX .049 plane engine Fuel - 3/22/2006 8:36:32 PM
loughbd
Status: offline
Cox instruction sheets say to run the engine for ONE MINUTE rich annd then lean it out. 15% nitro is a little on the low side. Cox sport fuel (blue can) is 25% nitro and the racing fuel (red can) is 35% nitro. The little engines lose their heat very quickly and the high nitro keeps them hot. They run 100% better on high nitro fuel. 20% oil is perfectly fine. Itis the oil content of Cox fuels and it's all castor.
(in reply to gocartdude)
       Post #: 14
RE: COX .049 plane engine Fuel - 3/23/2006 1:29:07 AM
downunder
Status: online
quote:
ORIGINAL: Jim Thomerson
What Jim said. I read the other day where someone said they were made to a tolerance of 25 millionths of an inch which is pretty much what I'd heard years ago. They had to do this because they were pumping out engines in the thousands every day and they couldn't afford to have anyone hand fitting pistons to cylinders or giving a final hand lap as Enya used to do. So any .049 piston would fit perfectly in any.049 cylinder. This can't even be done today on the much vaunted CNC machining with much larger engines where fits aren't as critical. Because of this precision Cox said a one minute rich run was all that was needed to finish settling in all the parts.
       Post #: 15
RE: COX .049 plane engine Fuel - 3/23/2006 1:48:56 AM
loughbd
Status: offline
That's exactly what Cox said in all their paperwork and what the writers said about Cox engines
       Post #: 16
RE: COX .049 plane engine Fuel - 3/23/2006 1:51:53 AM
loughbd
Status: offline
quote:
ORIGINAL: downunder
That someone was me
       Post #: 17
