aerofly pro
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Flight Simulator Software >> Ikarus AeroFly Pro and Aerofly Pro Deluxe >> aerofly pro
Page: [1]
Login
aerofly pro - 12/19/2004 3:48:26 PM
firemedic305
Status: offline
I just installed a new Aerofly pro and the update patch and when I try to run the progran I get is This program has performed an illegal operation and will shut down. running win 98
       Post #: 1
RE: aerofly pro - 12/19/2004 4:38:32 PM
STLPilot
Status: offline
Try reinstalling it. Run the uninstall utility.
Read this too:
There has been a lot of confusion lately on how to correctly install AeroFly Professional, the Expansion Pack as well as this Update. Please follow the following order to properly install AeroFly. Failing to do so will result in a corrupted installation and a complete uninstall might be necessary.
First install the blue and yellow CD which is the main Aerofly Professional software. It has a version number of V1.2.x printed on it.
Next install the Expansion Pack CD if you have it. The Expansion Pack must be loaded before you install any patches or updates or you will have to go through the uninstall process.
At last you need to install this update.
Uninstalling AeroFly Professional
Go into the windows control panel Add or Remove Programs and remove any Aerofly Professional programs.
Next you need to go into the Windows Explorer and delete the IPACS folder which is located by default on your local disc C under Program Files.
To get into Windows Explorer you right click on the Windows Start button and choose Explorer All Users. Choose the local disc C if there is a plus sign next to it make it a minus sign. Next scroll down to where you see a folder called Program Files, if there is a plus sign next to it make it a minus sign. Next scroll down and find the folder called IPACS right click on it and delete it.
_____________________________
Here At The Wall
(in reply to firemedic305)
       Post #: 2
RE: aerofly pro - 12/20/2004 3:53:22 AM
firemedic305
Status: offline
ok did that and checked each step trying it and it worked untill I added the patch update. started all over again with out update patch. now it starts and can go through the setup but error whin I go to fly.
(in reply to STLPilot)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.250RCU1
