Tired Old Man
Joined: 2/25/2002 From: Central, CA, USA Status: offline
I'm certain that I'll be taunted for providing you with a reply, but the 28% planes arrive in one very large box, which is wrapped up in a somewhat larger box, so I suppose the correct answer would be two boxes. But since one is inside the other, it has the appearance of one very large box. The planes larger that 28% arrive in a minimum of 2 separate boxes inside two larger boxes, but still maintaining the appearance of only two boxes. I do hope that the answer provided to your question was within permissable accuracy tolerances. Should you choose to be accurate, you should state that Silversurfer has a job, but desires another, preferably as a sales rep for a manufacturer of high quality R/C products, as a writer, or RPV pilot. Now that's truth in advertising
_____________________________
If you can''t fix it with a hammer, you have an electrical problem.
