Tired Old Man
Joined: 2/25/2002 From: Central, CA, USA Status: offline
Tom's hardware for the 28% planes is excellent. Most of it is the same stuff you would go out and purchase yourself. Some of it is better than what you would purchase yourself, because you wouldn't have thought of it. The only changes I chose to make was to substitute some allen dead cap screws for the phillips head. Get the hardware kit. It'll save you time and money. I used to use the Duralite batteries, but the Duralite charger gets so hot it worries me, especially if you are charging more than one Duralite at a time. I have since switched to Fromeco, and in doing so I have saved quite a bit of money and received higher quality products. That includes the Fromeco charger. The customer support obtainable through Fromeco is unheard of with Duralite, and is very similar to the support given by the Fawcetts. That says a lot about a manufacturer/distributor. As far as battery capacity is concerned, I have flown for two days straight, 5 to 6 flights a day, on one charge with a 4,400mAh Li-on and 5-JR 8611 digitals. It was still good to go when I finished the second day. Needless to say, you won't need a 4,400mAh battery to fly, but something in the |
