RE: Funtana90 video (Kyle)
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Funtana S 3D .60-.90 ARF
  • 5 Active Classified Ad(s)
  • Read Full Review
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> 3D Flying! >> RE: Funtana90 video (Kyle)
    Page: <<   < prev  5 6 7 8 9 10 11 12 [13] 14   next >   >>
    Login
    RE: Funtana90 video (Kyle) - 3/28/2005 11:12:35 PM
    Kyle300S
    Status: offline
    Thanks guys.
    If you have ever seen the video of me flying in the snow, it is done with a Funtana 40 that i recovered. It does rock in a harrier much more than the funtana 90, but it can be stopped without mixing. My CG is at 5.5in on the 40 size funtana.
    Yes, you will have to come down some time! It would be great fun!
    this is my radio set up...
    -TX: Hitec Eclipse 7
    -Expo:Ailerons- 25% Elevator- 30% Rudder- 10%
    -Mixing: Spoilerons for the tumble.
    -No dule rates
    Its not anything too special, but it gets the job done..
    _____________________________
    Kyle Woyshnis
    www.kyle.macapple.com
    (in reply to heliboy)
           Post #: 301
    RE: Funtana90 video (Kyle) - 3/29/2005 2:24:51 PM
    Kyle300S
    Status: offline
    quote:
    ORIGINAL: heliboy
    I sure would like to see you fly? I live in British Columbia, your not to far way from here. I will try the get down that way this summer.
    I have e-mailed you from your web site, keeps coming back.
    Heliboy..
    I never got your e-mail?
    Kyle Woyshnis
           Post #: 302
    RE: Funtana90 video (Kyle) - 3/29/2005 5:44:54 PM
    Tuomas Tanska
    Status: offline
    Hello Kyle and everyone
    I have a Funtana S140 Seba version from sebart.it and I have flown it a few times and slowly getting into it. A friend shot some video, so if you are interested..
    F S140 video 2
    F S140 video 1
    Click to see fullsize image.
    Click for fullsize
    Tuomas Tanska
    -F3A enthusiast-
    (in reply to Kyle300S)
           Post #: 303
    RE: Funtana90 video (Kyle) - 3/29/2005 6:20:22 PM
    islandflyer
    Status: offline
    quote:
    Tuomas Tanska Date 3/30/2005 3:44:54 AM
    F S140 video 2
    F S140 video 1
    I tied to watch it......takes too long to download.
    Herve Lejeune
    PAU
    (in reply to Tuomas Tanska)
           Post #: 304
    RE: Funtana90 video (Kyle) - 3/29/2005 6:37:00 PM
    TManiaci
    Status: offline
    Tuomas,
    That's a beautiful plane, I love it. It sure has POWER for verticle. Nice flying and smoke too. .
    Give us your setup (motor, servos, etc).
    Where is this sold? Is it a good kit?
    TMan
           Post #: 305
    RE: Funtana90 video (Kyle) - 3/29/2005 7:17:39 PM
    Tuomas Tanska
    Status: offline
    My plane data can be found on my homepage, follow This and click "3D". I have some pics uploaded too so you can see the construction.
    I do like the kit and I definitely like the looks. I don't know US retailer, but Sebart is the manufacturers site. My choise was 140 Limited and it easily does its job, doesnt it? I still have lots to adjust to get it perform better. I find it is nose heavy, maybe needs some more aileron movement and a few other things to do. The videos are from the first two test flight sessions. It is still early spring here
    I know, big files but better quality. I hope you aren't dissapointed after long time downloading..
    Tuomas Tanska
    -F3A enthusiast-
    (in reply to TManiaci)
           Post #: 306
    RE: Funtana90 video (Kyle) - 3/29/2005 7:49:38 PM
    STG
    Status: online
    Very nice. What fuel prop & RPM with the 1.4L?
    Good Flying to you!
    See Blog for RCU Video's
           Post #: 307
    RE: Funtana90 video (Kyle) - 3/29/2005 10:51:55 PM
    Kyle300S
    Status: offline
    Nice!! I would really like to have one of those planes! looks great!
    Kyle Woyshnis
    (in reply to STG)
           Post #: 308
    RE: Funtana90 video (Kyle) - 3/30/2005 6:12:20 AM
    heliboy
    Status: offline
    Kyle,
    my CG is a 6.2 inches back from the leading edge. Would that make the wing rock more? and doing hover more difficult if the CG is back to far? I'm also more expo on ever control too, I try to cut down the expo? every bit of advice would much be . Theres know one around there that tries 3D flying, I'm all alone.
    www.flickr.com/photos/38913008@N00/
           Post #: 309
    RE: Funtana90 video (Kyle) - 3/30/2005 8:06:18 AM
    Tuomas Tanska
    Status: offline
    quote:
    ORIGINAL: GPSpacewalker
    I use my own mix: 10% Aerosave, 10% Klozy and 30% nitro. I use the same stuff with 140DZ in pattern. L with 17x8 APC peak revs was 9200RPM on full throttle and I think it is a bit too much. But with this plane I hardly ever need full throttle, the acceleration is impressive enough anyway. I can fly straight down like it had a hand brake on with the 8" pitch.
    About the CG..
    I think a tail heavy plane is easier to hover and to elevator around without wing rockin. However at some stage you will get the plane oversteer and lift the nose on horizontal position. This makes the plane difficult to land and to fly aerobatics with. Try to find your compromise.
    The problem is inconstant speed and power which make the angle of alpha and the need of pull (or push) vary. These changes together with incorrect timing on any surface will encourage the wobble. Try to maintain constant speed when pulling in to higher alpha and play with the elevator just to keep it in the same position. Then adjust the altitude with the throttle.. I always have the same thing going on with a new plane, 'the feel' is unique for every design, throttle response, CG and so on. Practise and then try, do not rush into adjustments before you know the previous setting in the good and the bad.
    And when you know how not to rock the wing you can start to abuse the knowlege and make it to rock really dangerously and flip the plane around..
    I hope this makes sense. This is how I think of it
    < Message edited by Tuomas Tanska -- 3/30/2005 8:08:56 AM >
    Tuomas Tanska
    -F3A enthusiast-
    (in reply to STG)
           Post #: 310
    RE: Funtana90 video (Kyle) - 3/30/2005 2:20:40 PM
    Kyle300S
    Status: offline
    quote:
    ORIGINAL: heliboy
    Kyle,
    is that the 40 size or 90 size? If that is the 40 size, then you are way tail heavy and its probably just really touchy.
    if it is the 90 size, then you are a little nose heavy. my CG on the 90 size is 7.5 inches.
    Kyle Woyshnis
           Post #: 311
    RE: Funtana90 video (Kyle) - 3/30/2005 2:35:21 PM
    STG
    Status: online
    Kyle, do you have your fuel tank behind the wing tube on your F90?
    Good Flying to you!
           Post #: 312
    RE: Funtana90 video (Kyle) - 3/31/2005 3:43:37 AM
    Kyle300S
    Status: offline
    I have it in font of my wing tube.
    Kyle Woyshnis
    (in reply to STG)
           Post #: 313
    RE: Funtana90 video (Kyle) - 3/31/2005 3:55:50 AM
    STG
    Status: online
    What size is it? How far in front is it & do you think your CG changes much from full to empty?
    Good Flying to you!
           Post #: 314
    RE: Funtana90 video (Kyle) - 3/31/2005 6:36:16 AM
    Kyle300S
    Status: offline
    It is the stock tank, I'm not sure what size that it. I have it laying on the bottom of the fuse in that area in front of the tube. I notice a slight change in CG from full to empty. But it's not enough to really change the way it flies that much.
    Kyle Woyshnis
    (in reply to STG)
