rajul
Joined: 6/18/2002 From: Missouri City, TX, USA Status: offline
Gungadin, I went back to Doc's site and found that the white plane occurs in the Imac Votec, but not in the 3D Votec . Here's the problem - all the .bmp and .obj files are missing in the Imac version! What you need to do is to also download the 3D Votec. Copy all the .bmp and .obj files from the 3D Votec folder and paste them into the folder of the Imac Votec. You should be fine after this. I've listed the files you need to copy/paste below: glas.bmp thumb.bmp votec322.obj votec-elevator.bmp votec-fu.bmp votec-fu-mm.bmp votec-gear.bmp votec-parts.bmp votec-wl.bmp votec-wr.bmp
_____________________________
Mike Marks RCU Moderator Aerofly Support Representative http://www.aerofly.com/index.html
