RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Flight Simulator Software >> Ikarus AeroFly Pro and Aerofly Pro Deluxe >> RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max Page: <<   < prev  4 5 6 7 8 9 10 11 12 [13]
Login
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 3/11/2008 5:00 PM
rajul
Score: 100
Last Login: 3/20/2010
Status: offline
Hi rcflyer, in the aircraft edit menu, go to objects->fuselage->cg editor
In the CG editor there are 3 boxes with values when you access the fuse area. The three values in the cg editor are the cg position with respect to an arbitary reference point. The first value moves the cg forward (positive values) and backwards (negative values), the second to the left (+) and right (-) and the third value up(+) and down (-).
_____________________________
Mike Marks
RCU Moderator
Aerofly Support Representative http://www.aerofly.com/index.html
Hide Signatures
(in reply to RCFlyer55)
       Post #: 301
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 3/12/2008 11:16 PM
RCFlyer55
Score: 100
Last Login: 1/25/2010
Status: offline
Mike, thanks it worked out great. Now the Giles is a 3D monster.
Hide Signatures
(in reply to rajul)
       Post #: 302
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 3/21/2008 3:22 PM
RCFlyer55
Score: 100
Status: offline
I just downloaded the indoor "seeparksaal" and I can see the plane when I run it but the rest of the screen is black. I have this with another scene "vettre" too but all the others I've downloaded work fine. Any suggestions?
Hide Signatures
       Post #: 303
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 3/21/2008 4:03 PM
rajul
Score: 100
Status: offline
Hi rcflyer, can you give me the link to that download? Thx
Mike Marks
RCU Moderator
Hide Signatures
       Post #: 304
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 3/21/2008 4:13 PM
RCFlyer55
Score: 100
Status: offline
here you go it's the first one on the page.
http://www.roebeli.ch/
Hide Signatures
(in reply to rajul)
       Post #: 305
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 3/21/2008 5:13 PM
rajul
Score: 100
Status: offline
Hi rcflyer, I downloaded and flew in the scenery without issues. What type of 3D graphics card are you using? Have you updated the card driver?
Mike Marks
RCU Moderator
Hide Signatures
       Post #: 306
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 3/21/2008 6:19 PM
RCFlyer55
Score: 100
Status: offline
I just downloaded the new drives but those 2 scenes still don't work.
I have an ATI All-In-Wonder 2006 card.
Don't know if it matters but the version of AFPD I have is 1.8.21 and I did not download the Patch Version 1.11.07.09
because I didn't know if I have a 3D-card with OpenGL 2.0 driver support.
< Message edited by RCFlyer55 -- 3/21/2008 6:27 PM >
Hide Signatures
(in reply to rajul)
       Post #: 307
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 3/21/2008 6:31 PM
rajul
Score: 100
Status: offline
Hi rcflyer, please take a look at the recommended openGL-compatible 3D video cards here http://www.aerofly.com/www/requirements.html The card you are using is not recommended and this will cause problems as you have experienced. On the patch, if you do not have any addons, then patch 1.8.0.25 will be suitable.
Mike Marks
RCU Moderator
Hide Signatures
       Post #: 308
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 3/21/2008 6:52 PM
RCFlyer55
Score: 100
Status: offline
This is what it stated on the site
ATI XPert / ATI All In Wonder / ATI Rage (this accounts only for the old 7xxx series. The 9xxx series is highly recommended!)
The card I have is (2006 Edition) is newer then the 9xxx series and has 256 mb
I haven't bought any addons but I do have planes and scenery that I have downloaded from other sites. Everything works fine except for those 2 scenes. I would hate to download the patch and find things not working.
< Message edited by RCFlyer55 -- 3/21/2008 8:15 PM >
Hide Signatures
(in reply to rajul)
       Post #: 309
RE: Setting Up AFP(D) To The Max - 4/16/2008 6:25 PM
riverrun
Score: 100
Last Login: 12/8/2009
Status: offline
Question on AFPD. Somehow in configuring the simulator, the selected rotating model on the main panel now has dark grey on the upper wing and tail and the fuselage. Reloading has not solved the problem. A downloaded model (diabolo) did not show the same coloration. The system config is this.
AMD Athlon 64 X2 4800, 2 GB Memory, ATI Radeon X1900GT, Sound Blaster Audigy2 ZS, Windows XP.
Aerofly version 1.11.7.9 with addons 1,2,3. Disk 1 and 2 are version 1.11.7.1
And there is that BOUNCING when the Fly or Reset is selected.
Hide Signatures
(in reply to STLPilot)
       Post #: 310
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 4/17/2008 1:04 AM
rajul
Score: 100
Status: offline
Hi riverrrun, please visit the ATI website and donwload/install the latest driver for your video card. You might also want to update the driver for your sound card.
Mike Marks
RCU Moderator
Hide Signatures
(in reply to riverrun)
       Post #: 311
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 4/18/2008 3:45 PM
riverrun
Score: 100
Status: offline
Thank you Maarten, the sound was ok, and the video was ok when I installed AFPD but after
I posted to you, errors were coming up. Upon receiving your answer I deleted and installed and it is now correct.
1. BUT what about the HOPPING when the sim starts? Can this be corrected by an option setting?
2. Global scaling is needed. If I change wingspan and LOA, will engine size be changed? I would like to scale down
come of the full size models to match the Aztec.
3. What about minimum (idle) engine speed?
4. On the side of the Antonov AN-2 there is a girl with no knickers and "Ahacmacust" painted on the side.
What is the translation? This is from Addon3.
Hide Signatures
(in reply to rajul)
       Post #: 312
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 4/18/2008 3:56 PM
rajul
Score: 100
Status: offline
Hi riverrrun, my answers are in brackets below:
[This can't be corrected and will be addressed in the next version. It is not an issue in most cases]
[There is no automatic scaling. You may change the engine power in the model edit menu]
[You can set the idle speed in the model edit menu]
[Sorry, I have no idea. Perhaps some one can chip in]
Mike Marks
RCU Moderator
Hide Signatures
       Post #: 313
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 5/3/2008 7:58 PM
riverrun
Score: 100
Status: offline
This time around, I am sure that the sound card and computer are working o.k. I have tested audio in 5.1, Real Flight in two speaker, but Aerofly Pro Deluxe works on center channel only. Cannot find any options to make it anything but on or off. You will probably say, put it back the way it was, which is working without center channel. THEN, I got two channel sound, but it was an incorrect hookup!
Hide Signatures
       Post #: 314
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 5/4/2008 1:32 AM
riverrun
Score: 100
Status: offline
Found the answer. This Aerofly is so unique (primitive? ha!) that it only likes a two speaker arrangement. The 5.1 defaults to center speaker and though the sound is not as full there is still some doppler effect.
Hide Signatures
       Post #: 315
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 1/30/2010 4:18 AM
tavis newman
Score: 100
Last Login: 2/11/2010
Status: offline
I have always hated one thing about AFPD. When hovering and you give it throttle and back off the spool down of the prop takes way too long and continues to pull the plane up for 2 seconds as it spools down. HOW DO I FIX THIS? I noticed the Yaks don't do it.......
Hide Signatures
       Post #: 316
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 2/1/2010 12:34 AM
rajul
Score: 100
Status: offline
Tavis, which particular model are you referring to?
Mike Marks
RCU Moderator
Hide Signatures
(in reply to tavis newman)
       Post #: 317
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.875RCU1
