RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Flight Simulator Software >> Ikarus AeroFly Pro and Aerofly Pro Deluxe >> RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 1/19/2005 8:06 PM
Trisquire
Score: 100
Last Login: 11/21/2009
Status: online
Hi Maarten,
I'm enjoying your forum. I check it daily for new replies.
I know you've been flying for about three years. Could you tell me a little about your training methods? How long did it take you to learn torque rolls or rolling harriers? Did you use Aerofly every evening? One hour a day for several months?
I've seen your Shocky videos. You are clearly as good at real planes as you are on the simulator. How smoothly was your transition to real models? Was it fairly seamless or was there a transition period?
Regards,
Tom
Hide Signatures
(in reply to Doc. insane)
       Post #: 76
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 1/19/2005 9:13 PM
Doc. insane
Score: 100
Last Login: 4/19/2007
Status: offline
Tom,
I've flown two years with trainers, CAP232, Hype 3D . Then I bought aerofly pro. I could hover and torqueroll after a year, but If I had more money it would have been a lot sooner.
I learned rolling harrier on aerofly pro. I also learned to fly very smooth and sharp on aerofly pro, because the models are perfectly build and have the best engine and fastest servo's I could dream of. I learned alot of things on aerofly pro whoch I couldn't learn in real because I didn't had the planes and stuff. The first 9 months I had aerofly pro there was marked 120 hours flight time on my TX , then I lost my tx in a fire. Now I have again 20 hours I think. So after 140 hours of flying in one year and 4 months on aerofly pro you can do some stuff with the planes
_____________________________
Maarten De Moor aka Doc. insane
-> http://www.docinsane.com <-
Hide Signatures
(in reply to Trisquire)
       Post #: 77
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 1/20/2005 2:20 AM
whackinski
Score: 100
Last Login: 4/20/2009
Status: offline
Maaten, sorry about your fire I hope nobody was hurt.
I have been flying every night with my AFP/D and I found many great downloads. I am interested in designing my own planes and scenery can you tell me where to learn how to edit or build scenery and which software package may be needed to create planes and scenery? Do you know where to download this stuff?
also I tried loading your shockflyer settings and have been tweaking them to fit my own shocky. I have been having a hard time getting a sustained hover. can you post a more detailed list of your shock flyer settings? I haven't flown a real plane since getting AFP however I can hover my shocky better in real life. Although I do believe overall the simulator will make me a better pilot.
Thanks for all the great info Maarten
Whack
Dont worry your going to WHACK IT!
Hide Signatures
       Post #: 78
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 1/20/2005 2:23 PM
3Don
Score: 100
Last Login: 11/16/2009
Status: offline
quote:
ORIGINAL: pallen_001
Maarten
Could you please e-mail me the pdf stuff you had on learning manuvers?
(pallen_001@msn.com)
Thanks for all your help to us 3D newbies.
Pete
If u cant please send this info also here: kerzass@omni.lt
Hide Signatures
(in reply to pallen_001)
       Post #: 79
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 1/20/2005 5:54 PM
JoeAirPort
Score: 115
Status: offline
Maarten,
It's good to know that you worked very hard to get so good. I thought maybe you were born that good...kidding. Seriously it's good to know that we can practice and learn some of the cool things that you've showed us. I can tell you that because of you I've learned some things I thought I could never do. Of course it took me many hours of crashing but it's getting better. I am about 3/4 of the way to doing that torque rolling circle. I just have to get it to go in a good circle right now. Again, thanks for creating the cool tricks that we can all learn from and get better. Somebody's gotta keep the level up there, and that's you my friend!!!
Later,
Joe
quote:
ORIGINAL: Doc. insane
Tom,
Joe AP
Hide Signatures
       Post #: 80
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 1/20/2005 8:58 PM
Trisquire
Score: 100
Status: online
Maarten, Thanks for the help.
Regards,
Tom
Hide Signatures
(in reply to JoeAirPort)
       Post #: 81
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 1/20/2005 9:00 PM
bwd
Score: 100
Last Login: 11/17/2009
Status: offline
Hi Maarten.Having problems setting up the flaps can't get them to operate as flaps.They work like ailerons.when using the flap select switch.The radio is jr on ppm(fm).nothing seem seems to helpI have every wing function parameter on thr Transmitter,still doesn't ha-ppen.The sim will recogonize the flap channel,maybe it's me.Have any ideas.Thank you.BWD
Hide Signatures
       Post #: 82
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 1/21/2005 4:01 PM
Doc. insane
Score: 100
Status: offline
Thanks Joe
Whack, Do you use the same expo settings as me in your tx? If this doesn't help, maybe you should put your CG a little bit backwards.
BWD,
Just assign the flaps to your dissired channel and then there shouldn't be a problem. If they still work as aillerons reverse one of your flaps.
Hide Signatures
(in reply to bwd)
       Post #: 83
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 1/27/2005 6:29 PM
Shawnlh
Score: 100
Last Login: 3/5/2009
Status: offline
Hi Doc, if you have time, could you tell me what a good set up for this plane would be,
http://aeroflypro.com/ipw-web/bulletin/bb/viewtopic.php?t=83
I use this plane because the only plane I have is a twist with a saito .72, and I want to simulate the small .40 size aircraft as best I can. Thanks for your time
Hide Signatures
(in reply to STLPilot)
       Post #: 84
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 1/30/2005 10:39 AM
Doc. insane
Score: 100
Status: offline
Shawnlh, I'll test this right away.
Listen up guys! Most of you will have noticed that the extra330s in aerofly pro deluxe tends to fly a loop if you fly uplines at full power and you also have to apply a lot of downelevator when you fly on your back. I've been testing a bit and these are my new settings: Wing incidence: 0° stab incidence: 0° engine downthrust: 0.5° right thrust 0° max power: 10Kw She flies more realistic with these settings. Just trimm her for level flight at FUll power and then she should be flying nice uplines and downlines. She flies better inverted too.
greetz
Maarten
Hide Signatures
(in reply to Shawnlh)
       Post #: 85
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 1/30/2005 12:30 PM
Doc. insane
Score: 100
Status: offline
Shawnlh, I've tested this plane a bit, I only increased the propwash of the rudder to 60 instead of 50 and I decreased power a bit to make it more realistic.
Hide Signatures
       Post #: 86
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 1/30/2005 12:33 PM
Doc. insane
Score: 100
Status: offline
I also mixed rudder- elevator 8% and rudder-ailleron 5% to make her ( the extra 330s ) fly perfect.
Hide Signatures
       Post #: 87
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 1/30/2005 12:45 PM
whackinski
Score: 100
Status: offline
What's up Maarten? I went indoor flying a few days ago unsing my shockflyer edge. I bought a new LittleScreamer CD ROM motor wow what a thrill. Here's a shot of the Little Screamer and a modification to the landing gear.
Whack
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 88
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 1/30/2005 2:52 PM
RobT
Score: 100
Last Login: 9/28/2009
Status: offline
I have been trying to get the Extra 330S to fly close to my 40% Carden 330S. I have already changed the wing and stab incidence to 0.0 as per the model. I set the right thrust to 2.0 (my real one has 2.5, but AFPD won't accept 2.5 only 2 or 3)
DA says the 150 has 16.5 hp, so I set AFPD to that number, but it seems a bit too much.
But Prop . . . I like a 32 10 (as is standard) but I don't know if the prop settings are for 2 or 3 blade and there is no way to change that . . . and that makes a HUGE difference in real life.
Is there any way we can play with this? By the graphic I assume it is a three blade only, so I set the prop to a 28.5 12 which is the best mej for this engine . . . any idea's?
Rob
< Message edited by RobT -- 1/30/2005 9:56 PM >
Hide Signatures
(in reply to whackinski)
       Post #: 89
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 1/30/2005 9:42 PM
Doc. insane
Score: 100
Status: offline
Robt, the parameters in aerofly pro are different. You can't use the real life settings in aerofly pro.
Hide Signatures
(in reply to RobT)
       Post #: 90
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 1/30/2005 10:39 PM
MSP1957
Score: 100
Last Login: 11/18/2009
Status: offline
Maarten,
My wife an I just watched the 330s video, AWESOME! You have the gift. Must get back to my AFPD
Michael
GO BLUE!
MICHIGAN WOLVERINES
Hide Signatures
       Post #: 91
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 1/31/2005 4:19 PM
Yak Man
Score: 100
Last Login: 5/19/2009
Status: offline
Currently own aerofly Pro and was thinking about upgrading to Aerofly Delux, I am currently getting about 60 FPS with my computer.
What would Aerofly Delux do to to FPS and how much better are the 3-D flight Charteristics or physics between pro & Delux?
Not really intrested in the all the bells & whistles, just in if the phyics are that much better.
"I started with Nothing and I have most of it left."
Doug - "Prop-Wash makes Me HOWL!"
Hide Signatures
       Post #: 92
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 1/31/2005 4:32 PM
Doc. insane
Score: 100
Status: offline
jds158,
The flyingcharteristics are a lot better. Especially for imac flying after a little bit of tuning. You have the feeling the planes are bigger too. In my opinion you should try it out. really you won't regret it. Don't worry about the fps. It will stay the same normally.
Hide Signatures
(in reply to Yak Man)
       Post #: 93
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 2/3/2005 5:39 PM
caliber24
Score: 100
Last Login: 3/16/2005
Status: offline
Hi, I'm a french guy so excuse my english. I've got my AFPD since yesterday, and i've been using it for about 9-10 hours. I love it. But I love your videos too !!! Could I also have your pdf to learn some 3d maneuvers ? Here's my email:
cyjoe1@yahoo.fr
Thanks a lot, and go on with this forum, it's plenty of good ideas and advices !!
Hide Signatures
       Post #: 94
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 2/3/2005 6:06 PM
Ian.W
Score: 105
Last Login: 2/8/2008
Status: offline
caliber. excellent english, not a fault in it
Maarrten. How mych expo do you use on your REAL shockflyer?
Ian Watson
Team Flightpower
Hide Signatures
(in reply to caliber24)
       Post #: 95
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 2/5/2005 5:40 PM
Doc. insane
Score: 100
Status: offline
Caliber224, sent!
edible engine, 15% on rolls 30% on elevator and rudder.
Hide Signatures
(in reply to Ian.W)
       Post #: 96
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 2/6/2005 6:55 PM
caliber302003
Score: 100
Last Login: 10/19/2008
Status: offline
Hey Maarrten
ive looked all over to find the patch for aerofly pro so i can download some planes but cant find it or the ones i do find say its patched but its not. do you have a link for the patch?
Hide Signatures
       Post #: 97
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 2/7/2005 7:21 PM
Doc. insane
Score: 100
Status: offline
Caliber, you can download alot of planes here : http://www.rc-sim.de/index_en.htm or you can look at the www.aeroflypro.com forums for some planes.
Hide Signatures
(in reply to caliber302003)
       Post #: 98
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 2/8/2005 8:05 AM
Jim Gilbert
Score: 100
Last Login: 12/4/2007
Status: offline
Hey Maarten, I recently traded in my AFP for the Deluxe and I enjoy it except when I get the plane all trimmed out, sometimes it changes while I'm still flying. If I stop and come back it is WAY off or if I change models really bad. I start to fly harrier rolls and then I start to fly poorly and realize somehow it's gotten way out of trim!
PS I fly with my Futaba 9C If you or anyone knows how I can correct this I would appreciate it!!
Thanks Jim
Hide Signatures
       Post #: 99
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 2/8/2005 9:57 AM
Doc. insane
Score: 100
Status: offline
It's certainly caused by your transmitter. I personnaly fly a mx 22from Graupner and I've never had this problem before. Maybe you should directly ask Torsten Hans the headprogrammer of aerofly pro about this problem.
Hide Signatures
(in reply to Jim Gilbert)
       Post #: 100
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
2.156RCU1
