RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Flight Simulator Software >> Ikarus AeroFly Pro and Aerofly Pro Deluxe >> RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max Page: <<   < prev  4 5 [6] 7 8 9 10 11 12 13   next >   >>
Login
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 2/21/2005 4:29:59 PM
LeeU
Status: offline
Hey Doc,
Is there any way to get a OMP 47" Yak for AFP D? I have the Giant Yak and I have the 47" Yak on the way so I would love to be able to fly both in AFP D. Thanks LeeU
(in reply to Doc. insane)
       Post #: 126
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 2/21/2005 7:35:04 PM
Doc. insane
Status: offline
LeeU, I'll try to make the big Yak fly the same as the small one. What engine are you using?
_____________________________
Maarten De Moor aka Doc. insane
-> http://www.docinsane.com <-
(in reply to LeeU)
       Post #: 127
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 2/21/2005 8:02:57 PM
LeeU
Status: offline
Doc,
The big Yak flys awsome now, as far as the small Yak I will be using a OS 46 FX with Ultrathrust muffler which is good for another 1500 rpm over a stock 46. the specs for the 47" Yak from OMP's web page are:
Wingspan: 47"
Wing Area: 752 sq in
Length: 46.5"
Approx. Weight: 4 lbs
Engine: .40 - .46 2-strk,
.52 - .70 4-strk
Thanks Lee
       Post #: 128
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 2/22/2005 11:39:51 AM
Doc. insane
Status: offline
okay I'll send you the settings later today. (no time right now :-( very bussy
(in reply to LeeU)
       Post #: 129
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 2/22/2005 4:55:20 PM
Doc. insane
Status: offline
I changed this: CG: -4cm deflection: rolls: 45° elev, rudder: 60° propwash: rudder: 100, elev:65, rolls: 35 engine max power: 1.2 kw fuselageweight: 1.6 kilo
this is the big OMPYak! 2 meter version. I suppose this fly's a bit like the small one. good luck
       Post #: 130
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 2/23/2005 5:26:28 AM
seasterling
Status: offline
Doc, where is the CG on your extra? Thanks.
       Post #: 131
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 2/23/2005 3:50:54 PM
Doc. insane
Status: offline
Cg is at 3cm
(in reply to seasterling)
       Post #: 132
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 2/24/2005 4:03:24 AM
mfrance
Status: offline
I would like to create my own aircraft for AFPD. Does anyone know what software would I need to do that. Also, I've noticed there are file types of .tmt .tmd .tmg and .tgo. Can someone tell me what each file type is for or point me in the direction of AFPD info for building aircraft.
Thanks ahead of time for any help!
P.S. I'm looking to build a Tensor 4D!
       Post #: 133
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 2/25/2005 1:46:59 AM
alvarogn
Status: offline
Hello Maarten,
Thank you for all the valuable information in this forum. It has helped me get rid of some of the video game feel of the sim and start improving my flight skills. (Though I yet have to prove this in the real world once the snow goes away ).
I read that you have a PDF that helps learn 3D maneuvers, and I still have a lot to learn (I am still the chasing airplane stage ). Could you please share a copy with me? My e-mail is alvarogn@yahoo.com
(in reply to mfrance)
       Post #: 134
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 2/25/2005 7:46:26 AM
Grotesquebass
Status: offline
maarten could u send me that pdf as well...............email is grotesquebass@aol.com
< Message edited by Grotesquebass -- 2/25/2005 7:47:45 AM >
"I've got a fever and the only prescription is more cowbell"
(in reply to alvarogn)
       Post #: 135
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 2/25/2005 9:15:09 PM
Doc. insane
Status: offline
mfrance, take look here, you'll find lots of info and emailaddresses to people who make this planes. http://www.rc-sim.de/index_en.htm
(in reply to Grotesquebass)
       Post #: 136
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 2/28/2005 1:08:31 PM
mjemery
Status: offline
Tx settings in the sim vs. settings on your Tx: If you have different settings for your Tx in the simulator than what you have dialed in on your real transmitter (e.g. Rudder expo is 40% in sim but is 80% on your Tx), what takes precedence? If I want to setup a plane like some of the suggestions here, do I do that in my transmitter or in the simulator itself? Thanks!
       Post #: 137
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 2/28/2005 9:55:57 PM
seasterling
Status: offline
Hey Maarten, have you flown the VTOC Extra 330S off the IPACS site? I really like flying that plane but was wondering how realistic it is. Seems pretty easy to fly. Also, what do you set your sim speed to? I've noticed users on the forums saying that around 120 is more realistic. Thanks.
(in reply to mjemery)
       Post #: 138
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 2/28/2005 10:01:47 PM
Ian.W
Status: offline
maarteen. have you done a setup for the wild hare edge 540T?????? ive skinned it, now i just need it fo fly better
Ian Watson
Team Flightpower
       Post #: 139
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 2/28/2005 10:18:18 PM
Doc. insane
Status: offline
mjemery, I leave expo in the sim itself at zero, I use my tx for all my settings.
seasterling, I leave simspeed at 100, seems pretty realistic to me. I'll try the new extra tomorrow and I'll let you know my settings.
edible engine, where do I find this edge? Thanks
(in reply to Ian.W)
       Post #: 140
RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max - 3/1/2005 6:14:20 PM
Ian.W
Status: offline
Maarten
Edge: http://aeroflypro.com/ipw-web/bulletin/bb/viewtopic.php?t=7
thanks
Ian
Ian Watson
Team Flightpower
