ddedicate
CA, USA Status: offline
Hello Maarteen, How do I setup the AFP Deluxe with my existing Futaba 6HX? It seem likes when I move the throttle or the rudder stick, it response to BOTH the throttle + rudder movement at the same time. It just doesn't wanted to be indepedent - you know - the throttle or the rudder by itself! I've tried with the Hitec Laser 6 - it worked perfectly without hickup. And can I use those "special' function on the Tx, i.e.: the "hold throttle", or "idle up". Thanks again Maarteen.
