RE: Matt Chapman cap 580 .40 size
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
Krill Katana RTF Full Composite 33% DA-100 - Greeves Pipes - JR 8711 - Hitec - A1 - RTF
Seller:  I Buy Houses
Details:   $3,850.00   |  3/16/2010   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> RE: Matt Chapman cap 580 .40 size
Page: <<   < prev  3 4 [5] 6 7 8 9 10 11 12   next >   >>
Login
RE: Matt Chapman cap 580 .40 size - 1/17/2005 7:14 AM
cadconversions
Score: 100
Last Login: 3/16/2010
Status: offline
Great idea on the longer axles. I'll be sure to do that since I fly almost exclusively at a grass field.
Looks like I'll have to open the bottom of the cowl for my motor head and glow plug. I'll either put a glow driver or remote glow on this plane since I'm mounting the .61FX inverted. Anyone have any recommendations on brand / type?
I also hooked up three lines on the tank. 2 w/ clunks and the 3rd is a vent line. One clunk (a hair shorter with a piece of brass tubing in the middle) will run to the carb. The second clunk line will go to a fuel dot and be used for filling and emptying the tank. The vent line will just vent. don't need a "T" to dump the glow since the inverted muffler will take care of that with out any issues.
How much flight time has anyone gotten on that small fuel tank? 250CC on a .61 should give me about how much flight time?
Thanks again guys.
Kevin
_____________________________
Kevin
Hide Signatures
(in reply to ifixairplanes)
       Post #: 101
RE: Matt Chapman cap 580 .40 size - 1/17/2005 9:39 AM
CaptainGlo
Score: 100
Last Login: 10/19/2008
Status: offline
Sean,
Do you have pics of the right side and bottom of the cowl? And also of the engine & muffler WITHOUT the cowl?
Would like to see how much of the cowl you had to cut off to fit the OS .70. Thanks very much.
...Think Safety First......Please Be Safe......Help Reduce Accidents....
Hide Signatures
(in reply to cadconversions)
       Post #: 102
RE: Matt Chapman cap 580 .40 size - 1/17/2005 6:56 PM
ifixairplanes
Score: 100
Last Login: 1/12/2009
Status: offline
No problem ezgoer. I'll get those shots posted for you as soon as I can take them.
Sean
"We request that model aviation not be innocently sucked into a black hole of regulation..."
Hide Signatures
(in reply to CaptainGlo)
       Post #: 103
RE: Matt Chapman cap 580 .40 size - 1/17/2005 9:17 PM
scaleMan
Score: 100
Last Login: 1/6/2010
Status: offline
I put a 61fx into this plane and if you mount the engine sideways with a pitts exhaust you can conceal the whole engine. I only have small holes for exhaust, glow plug and needle valve. It fits perfectly.
scaleman
Hide Signatures
       Post #: 104
RE: Matt Chapman cap 580 .40 size - 1/17/2005 9:31 PM
TOFAST4U2C
Score: 100
Last Login: 3/7/2010
Status: offline
Scaleman
Will it fly for long with out the overheating problem? I too have the same set up but all still in the box. Will start on it shortly and the cowl looks way to nice to be cutting big holes. Me thinks we will have to or its a overheating we will go.
Born to CRUISE, Forced to Work!
Hide Signatures
(in reply to scaleMan)
       Post #: 105
RE: Matt Chapman cap 580 .40 size - 1/17/2005 10:19 PM
ifixairplanes
Score: 100
Status: offline
Heres the pics:
Oooooohhhhh, I can see myself in the cowling...
Hide Signatures
(in reply to TOFAST4U2C)
       Post #: 106
RE: Matt Chapman cap 580 .40 size - 1/17/2005 11:39 PM
thedak
Score: 100
Last Login: 12/26/2006
Status: offline
Just bought a one of these and a Saito 82. Will post some pics when I am done.
Hide Signatures
       Post #: 107
RE: Matt Chapman cap 580 .40 size - 1/17/2005 11:49 PM
P-40LUVR
Score: 100
Last Login: 1/22/2007
Status: offline
What kind of muffler extention is that on the 70?
I have tried all kinds of hose and all have fell off my 91 4 stroke.
Hide Signatures
       Post #: 108
RE: Matt Chapman cap 580 .40 size - 1/18/2005 12:06 AM
scaleMan
Score: 100
Status: offline
"Will it fly for long with out the overheating problem? I too have the same set up but all still in the box. Will start on it shortly and the cowl looks way to nice to be cutting big holes. Me thinks we will have to or its a overheating we will go."
Have run 3 tanks and have not had any overheating... I have run this setup on many other airplanes and never had any problems.
scaleman
Hide Signatures
       Post #: 109
RE: Matt Chapman cap 580 .40 size - 1/18/2005 1:04 AM
ifixairplanes
Score: 100
Status: offline
quote:
ORIGINAL: P-40LUVR
Extension? Do you mean the elbow right after the engine or the exhaust deflector? The elbow right after the enigne came with my .70 and it threads into the engine head and into the muffler. The deflector I have is from GS Racing and I got it out of the RC car section of my LHS. My muffler has a lip on the tip of it so the zip ties dont slip off after I tighten them.
One suggestion I have heard for helping hold on exhaust deflectors is to add some JB weld around the tip of your muffler. Make enough so it makes a lip all the way around the tip of your muffler. That will keep the zip ties from slipping over the end of the tip and you from losing your deflector.
Sean
Hide Signatures
(in reply to P-40LUVR)
       Post #: 110
RE: Matt Chapman cap 580 .40 size - 1/18/2005 1:52 AM
CaptainGlo
Score: 100
Status: offline
Sean, Thanks for the pics. Digital cameras are a wonderful invention. What will we do without them?
Scaleman, let us know what the final weight is with the 61fx. And also how she flys with a 2 stroker. Thanks.
< Message edited by ezgoer -- 1/18/2005 1:55 AM >
Hide Signatures
       Post #: 111
RE: Matt Chapman cap 580 .40 size - 1/18/2005 3:53 AM
cadconversions
Score: 100
Status: offline
I've got my .61fx mounted inverted, almost all control linkages installed (having to redo the throttle since the stock setup is made for a side mount), landing gear on, pilot installed, and the cowl almost ready to go in.
Since I mounted the motor inverted, I'm planning on using a remote glow. Anyone know of a good place to put this and keep it out of the way?
Thanks guys.
Kevin
Kevin
Hide Signatures
       Post #: 112
RE: Matt Chapman cap 580 .40 size - 1/18/2005 3:53 PM
BlenderBender
Score: 100
Last Login: 9/9/2008
Status: offline
I mounted mine on the left side behind the cowling... they say the wind here is going to die tommrow... I feel a extreme case of flyitis coming on
John
"Better to have it and not need it that need it and not have it"
Hide Signatures
       Post #: 113
RE: Matt Chapman cap 580 .40 size - 1/18/2005 4:02 PM
cadconversions
Score: 100
Status: offline
Any suggestions for running the throttle? Where I'm mounting it inverted the stock position doesn't really work that well for the servo. The thottle needs to be on the lower right corner of the firebox (facing the plane) but the stock location is the right side. Where the grey guide tubes are already run I'm pretty well tied in to that one area. I'm trying a flex cable but not to happy with that right now. Should finish up today. Only have about 8 hours in it so far. Expect to finish with-in two more.
Kevin
Hide Signatures
(in reply to BlenderBender)
       Post #: 114
RE: Matt Chapman cap 580 .40 size - 1/18/2005 4:11 PM
BlenderBender
Score: 100
Status: offline
What engine mine is inverted also? On my Saito 100 I turned the carb around and it worked out good.
John
Hide Signatures
       Post #: 115
RE: Matt Chapman cap 580 .40 size - 1/18/2005 4:22 PM
cadconversions
Score: 100
Status: offline
It's a .61 FX. Can I turn the carb on it around?
Kevin
Hide Signatures
       Post #: 116
RE: Matt Chapman cap 580 .40 size - 1/18/2005 4:24 PM
cadconversions
Score: 100
Status: offline
Now, that I've said that, I don't think I can. I'll see what I can come up with.
Kevin
Hide Signatures
       Post #: 117
RE: Matt Chapman cap 580 .40 size - 1/18/2005 4:38 PM
Ace in the hole
Score: 100
Last Login: 2/28/2008
Status: offline
Hey John you don't look so well, I think you DO have that 24hr. flyitis coming on. You had better stay home tomorrow. -- I am really interested in finding out how she does with the 100 on it. What prop are you going to try it with?
Jeff
< Message edited by Ace in the hole -- 1/18/2005 4:39 PM >
Hide Signatures
       Post #: 118
RE: Matt Chapman cap 580 .40 size - 1/18/2005 4:52 PM
BlenderBender
Score: 100
Status: offline
I have a 15x6 and a 15X4... going to see which works best.....oh and I have a little ground clearence hahaha.
John
Hide Signatures
(in reply to Ace in the hole)
       Post #: 119
RE: Matt Chapman cap 580 .40 size - 1/18/2005 6:53 PM
dajensen
Score: 100
Last Login: 4/30/2008
Status: offline
Just finished mine up Monday afternoon. I am running an OS .70 Ultimate for a mill on her and an APC 14x4w prop. Total weight ready to fly is 6 Lbs 5oz. Still waiting for a break in the weather to put a maiden flght on it.
Even a BAD day at the field flying is better than a good day at work
AMA 803699
Hide Signatures
       Post #: 120
RE: Matt Chapman cap 580 .40 size - 1/20/2005 11:14 PM
BR289
Score: 100
Last Login: 3/17/2010
Status: offline
Would be interested in the weights that guys are coming out with on the finished plane....maybe the weight GP put on the specs was a typo? As you finish your plane, please post the finished weight...especially with the four strokes...Thanks guys
Hide Signatures
(in reply to dajensen)
       Post #: 121
RE: Matt Chapman cap 580 .40 size - 1/21/2005 2:36 AM
Ace in the hole
Score: 100
Status: offline
As I posted earlier, my finished- ready to fly weight is 6lbs. 10oz. with a saito 82 on it. I have not had it in the air yet due to bad weather but I sure am looking forward to it.
Hide Signatures
(in reply to BR289)
       Post #: 122
RE: Matt Chapman cap 580 .40 size - 1/21/2005 3:29 AM
ifixairplanes
Score: 100
Status: offline
I also have already posted 6lbs 13oz for mine. Thats with an OS .70 surpII. Anyone get a chance to fly theirs yet?
Sean
Hide Signatures
       Post #: 123
RE: Matt Chapman cap 580 .40 size - 1/21/2005 3:49 AM
RDMoore
Score: 100
Last Login: 9/24/2005
Status: offline
So do you think a OS 91FX is too much for this plane? I was thinking about putting the 91 in this plane. My other thought was too spend the cash for the Saito 82. What do you guys think.
Thanks.
Ryan
Sig Somethin' Extra
Great Plane Matt Chapman Cap 580
Hide Signatures
       Post #: 124
RE: Matt Chapman cap 580 .40 size - 1/21/2005 3:51 AM
RDMoore
Score: 100
Status: offline
Let us know how it flies with the 82 up front.
Sig Somethin' Extra
Hide Signatures
       Post #: 125
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.070RCU1
