Smallest gas engine in the smallest plane that can handle it???    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Premier Pilot 1/4 scale full body pilot
Seller:  Ren DiLeo
Details:   $129.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> Smallest gas engine in the smallest plane that can handle it???
Page: [1]
Login
Smallest gas engine in the smallest plane that can hand... - 12/24/2004 11:55 PM
Ken Bryant
Score: 100
Last Login: 1/15/2012
Status: offline
OK, I really like gasser models. I want to build the smallest gasoline powered plane I can.
Question #1 What is the smallest gasoline engine made today? This has to be a viable powerplant.
Question #2 What airframe size for that engine?
I want a good power to wieght ratio too. Doesn't have to be balistic vertical but it does need to be good.
FWIW, I am presently flying a 28% With a DA 50 this is my level of experence.
_____________________________
Ken
Hide Signatures
       Post #: 1
RE: Smallest gas engine in the smallest plane that can ... - 12/25/2004 12:01 AM
drandles
Score: 100
Last Login: 5/28/2007
Status: offline
Smallest one I found in current production is the FPE 1.3 (First Place Engines). I have one for sale here in the marketplace. I used to have a gas conversion kit that I used to convert a Super Tiger 90 to gas. Sold that years ago.
There may be smaller ones.
drandles
I meant to do that,
Hide Signatures
(in reply to Ken Bryant)
       Post #: 2
RE: Smallest gas engine in the smallest plane that can ... - 1/7/2005 8:29 PM
RickVB
Score: 105
Last Login: 8/14/2012
Status: offline
I'm intersted in this too. What is the smallest Gasoline engine, NOT by displacement, but rather in propshaft center to top of plug boot height? (Face it, that's the measurement that makes the most difference by far.)
Rick Vera-Burgos
Novi, Michigan
Hide Signatures
(in reply to drandles)
       Post #: 3
RE: Smallest gas engine in the smallest plane that can... - 1/7/2005 9:38 PM
Kmot
Score: 168
Last Login: 6/19/2013
Status: offline
Campagnucci cars makes a .40 gasoline/ignition engine for the car models. I suppose you could convert one to prop:
http://www.mecoa.com/compagnucci/
~Tom~
Hide Signatures
(in reply to RickVB)
       Post #: 4
RE: Smallest gas engine in the smallest plane that can... - 1/9/2005 6:05 AM
BUCKETOBOLTS
Score: 100
Last Login: 6/20/2013
Status: offline
I read a while ago about a fella that flew a U-Can-Do 60 with a RCS 140. He had nothing but praise for the engine and plane. I have a RCS 180 but the smallest thing I have had it on was an Aeroworks profile.
Hide Signatures
(in reply to Kmot)
       Post #: 5
RE: Smallest gas engine in the smallest plane that can ... - 1/2/2010 1:44 AM
Tommygun
Score: 130
Status: offline
Seeing that this was last entertained 5 years ago, what is the current answer? We have to have a smaller gas engine by now, right?
The original Tommygun
Hide Signatures
(in reply to BUCKETOBOLTS)
       Post #: 6
RE: Smallest gas engine in the smallest plane that can ... - 1/2/2010 3:18 AM
Zippi
Score: 139
Status: offline
quote:
ORIGINAL: Ken Bryant
Ken,
Here is a pretty small gasser at 15cc.
http://www.kmp.ca/product_info.php?cPath=40&products_id=226&osCsid=8d60387fd53c61f5bdb377e267d79182
Click to see fullsize image.
Click for fullsize
"It Ain''''t Lookin Good"
http://www.evansvillercclub.net
Hide Signatures
       Post #: 7
RE: Smallest gas engine in the smallest plane that can ... - 1/2/2010 6:24 AM
opjose
Score: 284
Status: offline
quote:
ORIGINAL: RickVB
Heh, I'm more concerned about propshaft clearance.
I recently picked up an Evolution G26 for a 1.20 Ultimate BiPlane, only to find that the carb interfers with propshaft clearance... in other words I would have to hack up the cowl to make things fit.
Cylinder height is less important to me as I don't mind a BIT of the head protruding through the cowl on a side mount, but I'd prefer not to have to hack a cowl apart to make an engine fit.
Sometimes I think that RC Airplane GAS engine manufacters don't give that much thought into producing engines ( except for maybe the RCVS engines ) that fit into our planes.
< Message edited by opjose -- 1/2/2010 10:14 AM >
Don''t worry, be happy and fly something!
Hide Signatures
       Post #: 8
RE: Smallest gas engine in the smallest plane that can ... - 1/2/2010 8:43 AM
Tommygun
Score: 130
Status: offline
I guess Saito is now making smaller gasoline engines, including one that's coming out soon, the FG-14B. It's a .83 displacement motor! http://www.horizonhobby.com/Products/Default.aspx?ProdID=SAIEG14B#quickSpecs
The only thing that bites is the ignition is not self contained, and requires a seperate onboard battery pack.
Hide Signatures
(in reply to opjose)
       Post #: 9
RE: Smallest gas engine in the smallest plane that can ... - 1/3/2010 2:52 PM
hubbajer
Score: 116
Last Login: 3/12/2013
Status: offline
FWIW; I personally have a GP 60 size Cub flying a BME .90 Supertigre gas engine It is a perfect combination. I believe I'm running a 14x6 prop . This little engine is fantastic. My friend also has one. We have flown them for over 2 years with no problems whatsoever.
I also have a First place 2.4, and have owned a First place 1.3 -both excelent engines. The secret to these small engines is to put them on the proper size plane.
Hide Signatures
(in reply to Tommygun)
       Post #: 10
RE: Smallest gas engine in the smallest plane that can ... - 1/3/2010 6:14 PM
flygilmore
Score: 131
Last Login: 5/16/2013
Status: offline
The FPE 1.3 is nothing more than an Echo weedeater block that has had the timing changed etc and the case trimed down. Many folks over in the engine conversion forum are doing the same thing plus some!!
I didn''''t choose Mojo, Mojo chose me PRO BRO #1963
Hide Signatures
(in reply to hubbajer)
       Post #: 11
RE: Smallest gas engine in the smallest plane that can ... - 1/3/2010 7:07 PM
Avaiojet
Score: 111
Last Login: 6/14/2013
Status: offline
Thanks for the info.
I'll follow this Thread with great interest.
I will, at some point, build an 80" Widgeon. This model has round 8" cowlings. Gas could work if the engine spins a large enough prop.
I also have, on the drawing board as I speak, the Bamboo Bomber at 84". Gas could work for this model also.
I guess I like big cowlings.
Keep the info coming.
Charles
Charles, owner, CFC Graphics, Vinyl graphics "Model Airplane Graphics from a Model Airplane Builder." 58 years of modeling.
Hide Signatures
(in reply to flygilmore)
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.031RCU1
