RE: X Calibur
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Scratch Building, Aircraft Design, 3D/CAD >> RE: X Calibur
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: X Calibur - 1/31/2005 8:52:24 PM
bbt
Status: offline
Slade,
the PDF files are ready. How do I get them to you?
BBT
(in reply to SilverEagleBW)
       Post #: 26
RE: X Calibur - 1/31/2005 9:38:51 PM
bbt
Status: offline
OK, I've sent the files to Terry
BBT
(in reply to bbt)
       Post #: 27
RE: X Calibur - 1/31/2005 10:48:14 PM
triangle
Status: offline
Thanks guys this is excellent. Can someone recommend a company that cuts all the stuff laser preferrably, looking foward to building one for my zdz 60.... another thing, if you are going to produce the canopy and cowling, would you sell me 2 pairs??
< Message edited by triangle -- 1/31/2005 10:54:54 PM >
(in reply to bbt)
       Post #: 28
RE: X Calibur - 2/1/2005 11:46:02 PM
Stiks
Status: offline
Slade
Just a question regarding the second wing, is it constant cord or constant thickness aerofoil? Cause the way I'm looking at the plan sheet it seems to be a constant thickness wing. What am I missing??
cheers
Stiks
_____________________________
Tree 1 .... Worldstar 0
(in reply to triangle)
       Post #: 29
RE: X Calibur - 2/2/2005 2:03:59 AM
Looper
Status: offline
Hi, everyone. Now that Paul has finished the plans, let's keep the thread going. Maybe if we find a cutter we can get a better deal on mutiple kits rather than have each of us go our separate way. Also, I would like to see a build form started. This would be a big help to all of us and a way of showing Paul our gratitude for his generous work on a superior plan. Thanks, Paul!........Looper
< Message edited by Looper -- 2/2/2005 2:06:09 AM >
(in reply to Stiks)
       Post #: 30
RE: X Calibur - 2/2/2005 2:29:52 AM
SilverEagleBW
Status: offline
Thanks Looper,,,,,,,
Stiks,the second wing is a constant chord/thickness wing just like the wing on a Funtana 90,uses the NACA 0014 airfoil.
Triangle,a ZDZ 60 is a little much for this plane,but heck,go for it,just make sure you gusset the heck out of the plane up front.One thing i would do is to totally sheet the airlerons if i where to use a ZDZ 60,interplane struts on the tail,and change the wing tube from a one inch to a 1/ 1/4 inch tube.Then buy some very strong metal gear servos,,,,remember fly this plane slow,not designed for speed.again,flutter kills!
More planes will be coming,,,,
Oh,the canopy and cowl,,i got to make a vacuum to vacuum form the canopy and cowl,gonna warn you right now,my stuff will be far from perfect cause i never vacuum formed much before,i'll figure it out though.Wonder if i sent some stuff to those guys that make fiberglass cowls and stuff if they could make a cowl and wheel pants for this plane,maybe i will email the and see.
< Message edited by Slade_LoD -- 2/2/2005 2:33:59 AM >
(in reply to Looper)
       Post #: 31
RE: X Calibur - 2/2/2005 2:50:15 AM
canadagoose
Status: offline
Paul, Jim Conachen of http://www.conachenaircraft.com/ might be someone to look into for producing glass cowls and wheel pants for your KatanaX design. Think a Webra 120 Speed is too small for this design? I've read that this engine should be able give a 12# plane unlimited vertical.
http://www.tjlewis1.rchomepage.com
       Post #: 32
RE: X Calibur - 2/2/2005 4:05:42 AM
triangle
Status: offline
don't worry about it slade, y made the plans bigger, w/acad, now the wingspan is 84". I'm in the process of adjusting all the dimensions on the plans to the original, do you think i can keep those original dimensions as in stringers, former thicknes etc and be able to take it to 84" or should i go up to the next size??? let me know bout the cowl and canopy.
thx
(in reply to canadagoose)
       Post #: 33
RE: X Calibur - 2/2/2005 3:08:09 PM
SilverEagleBW
Status: offline
Terry,That engine has 3.2 hp,weighs 1 1/2 pounds,will do the job without a doubt.Got to lighten the tail end up some so you don't have to add alot of weight to the nose.Lighten the tail feathers as i discribed above,then remove former FT-2 and replace it with two strips of 1/8 x 1 inch balsa running from F-3 to F-5 ,then cut lightning holes if formers C-1,T-1,T-2,that will help..I am guessing the plane will weigh around 6 to 7 pounds framed up,you might be somewhere around 9 to 10 pounds ready to fly.I need to get one built to see where these numbers actually are.
Maybe i should do a 'Lite' version of this plane using 1/8 balsa for the sides and a few other things i have in mind for it.See what i can do today on that and send you the plan changes.
       Post #: 34
RE: X Calibur - 2/2/2005 3:24:02 PM
SilverEagleBW
Status: offline
Triangle,,,,,change the wing tube to 1 1/4 inches x 36 inches long,be carefull of that lenth to make sure you hit rib #W-5 just right,3/32 sheer webs.Use 1/4x1/2 main spars on the wing,sheet the airlerons.Change the former F-1 to 1/4 lite ply,change the longerons on the fuse from 1/4 sq.balsa to 1/4 spruce and also change the front deck 1/4 sq spruce to 3/8 sq. spruce.The total width of the leading edge should be 1/2 inch.The rear spar,upgrade to 3/8 balsa and the aileron leading edge to 1/2 balsa.might have to do some fudging on the aileron leading edge to fit.Get some foam and hotwire the turtledeck and sheet it with 3/32.make sure the turtledeck is hollow or you might end up tail heavy,keep it around 3/8 thick.The rest u can use the same size stock as on the plans.I will make you the canopy,just going to need some time for that,i do have alot of other plans i have to get out.On the cowl,it has to be made of fiberglass,i can't work with that stuff,allergic to the resins,which SUX!
I will add an 84 inch version to the list of plans to do here,when i am done i will send them to Terry,,,,
< Message edited by Slade_LoD -- 2/2/2005 3:25:45 PM >
       Post #: 35
RE: X Calibur - 2/2/2005 4:13:09 PM
triangle
Status: offline
THANKS SLADE
       Post #: 36
RE: X Calibur - 2/2/2005 5:03:21 PM
SilverEagleBW
Status: offline
Y/W Triangle.
Terry,working on those changes now,get a new set of plans to you sometime today.
       Post #: 37
RE: X Calibur - 2/2/2005 6:20:08 PM
triangle
Status: offline
sweet guys, i'm gonna work on the material list as soon as i get them, any word on the kit cutting companies???
       Post #: 38
RE: X Calibur - 2/2/2005 7:57:53 PM
bbt
Status: offline
Slade,
I understand that you are using the NACA0014 for the wing. Due to the constant chord/thickness wing, the Katana-X is showing something like a NACA0007 at the root and a NACA0018 at the tip of the wing with a constant thickness of 2 inches.
I am not an expert in this domain but I have two questions about this:
- Is a 7% root thickness compatible with the expected flight characteristics of the plane at low speed?
- Would it be a better choice to go for something thicker at the root (12% or 14%) and increase the thickness at the tip to match the constant thickness criteria?
In addition, could it be possible to provide a wing section drawing at W5 level?
BBT
       Post #: 39
RE: X Calibur - 2/2/2005 8:38:57 PM
SilverEagleBW
Status: offline
bbt,i started with the 0014 and increased the chord to 18% to give me the thickness at the tip,which is an 0018,then taperd it to the root to keep the constant thickness.Ok,now will this work at slow speeds?Take a look at the wing design of the Funtana 90,same deal..I'll post a cross section at W-5 here in a bit..
(in reply to bbt)
       Post #: 40
RE: X Calibur - 2/2/2005 10:08:54 PM
canadagoose
Status: offline
Having a thicker airfoil at the tip than at the root should effectively act like washout in having the wing stall at the root first, which is what you want.
