Merlin Man
Joined: 2/18/2004 From: Coffs Harbour, , AUSTRALIA Status: offline
I believe that the basic airframe of this Mustang was designed here in Australia by the late John Miles. I think he based this model very much on the David Platt P51. It is identical in Size for a start. The moulds etc. were bought by CJ . Peter Oz on this forum has a nice version of the original Miles P51 and he might be able to shed more light on it's origins. As for "Scaleness " ( is that a word ?) ,if it is the same as the Platt, then it has just a few minor issues. I built the Platt kit a few years ago and in the process compared with overlays etc.the Platt plan with others but mostly the B.Taylor plan . The differences I noted were minor with the Taylor plan being most like the many 3 views I studied. I have had a good look at the photos above of Smchale's great model and , without measuring ,it appears the same as the Platt. This means that it is too deep in the fuse under the Tailplane seat ( about 1" has an airfoil that is not quite " full enough" in the 1/2 cord region, and the lower cowl is slightly to deep in the chin area (.Less than 1/2" )As well, the P51 has a slight "arch"downward where the fin meets the fuse that seems absent from this model. The angle of the fin is slightly too shallow too. However, having said all of that, I still think that this model is above average in the looks department and ,IMO is much better than either the Topflight or Pica kits. Hope this helps. Cheers, Merlin Man.
