Stuka Jon N
FL, USA Status: offline
Capt. G The 3W-50 performs well in this plane. Speed is good looks to me much higher then scale. Some difficulty with the rear induction. Large hole in firewall. Then choke going to the outside. Used a Sonic Pitts style muffler. This partially blocks access to the needle valves. You can reach them with difficulty. I changed the chin block into a removeable hatch so I could get in from the bottom. But the look is great. No carb hanging out the side,. You can only see the side of the muffler and the pipes out the bottom See side of muff. in photo #1 John N
