dlucas48
TX, USA Status: offline
Been a bit breezy today-not right for possible deadsticks. I will spend the time to work on the cowl, by blocking and opening. When I say it was reliable, I mean that it kept running till I stopped it. I could tell it was leaning out as the fuel level dropped, but with a 20 oz tank I flew for 12-13 minutes and had a good 1/4 tank left, therefore not leaning out as much as it might have. I tried everything before getting the pump, because I knew it would add more unknowns to the mix. I had two clunks hooked up in parallel all the way up to the carb and a check valve in the muffler-to-tank line. It was an improvement, and did fine on my Lanier Edge. That cowling and the one on the Katana seemed to have the same cut-outs, but that was subjective, obviously. The planes are pretty close in weight and drag, the main difference must tbe the cooling ability of the cowls. I do think it is overheating now. I also bought a Sullivan stopper w/1 large and 2 reg size tubes. I was going to run the large line to the carb and also keep the check valve on the muffler line, but the more I read, the pump seemed the way to go. Thanks to all for the help, and I will update asap.
