dlucas48
TX, USA Status: offline
Still trying to get a CONSISTENT run. I now have the perry vp-30 pump mounted per instructions. The adjustment screw is out 4-5 turns, as it came from the factory. This looks like a lot, at first I thought it was vibrating out, but it stays there. This gave a rich run as it was supposed to. My N.V. is now open 3/4 turn or so. Is this close to what you guys are seeing? Engine has a new liner, ring, head gasket. (Don't ask) A-5 plug, 15% nitro, 18% oil (80 syn/20 castor). 18-6W APC prop on a Chief Katana. Total fuel system changeout and checkout, from the clunk forward. Engine carefully broke-in. 1st flight set a tad rich, went well. 2nd, it seemed to start missing, and finally died. Still had more fuel left than the first flight ended with. Glo-plug lit ok afterwards. Man, this used to be one of my most reliable engines, and has been nothing but a battle since I put it in this plane. No logical reason-tank is placed correctly. My question, then is, should I increase pump pressure by screwing the adj. screw on the pump in? I'm gonna lose this nice plane on one of these dead sticks, one day. Help! I've read all the Katana and OS 1.60 posts, but no one that i saw mentioned how far out they were running the adj. screw.
