suzonka -> RE: types of fuels claims on o%nitro?? (1/4/2006 12:06:54 PM)
quote:
ORIGINAL: preivers Recently, MVVS quickies were adapted to the US nitro craze. Result: They now run much shy of their potential when used in FAI events, where no nitro is allowed, unless the compression ratio is raised again. Generalities: A good engine does not need nitro, if the compression ratio is adjusted accordingly. There is ample proof of that in FAI racing. In a less good engine, bad design can blanketed by nitro, sometimes lots of it are needed. In two strokes, nitro helps to make carb setup uncritical, due to the wider combustion limits of nitro. In four strokes, nitro helps a lot to get the engine ironed out over the whole rpm range. More power can be had from a good engine at nitro over 20%, if the CR is adapted wisely. ===============================================================Thanks for your information ,you really did your foot work and gave the most logical explanation above
