pe reivers
Joined: 1/23/2002 From: Arcen, , NETHERLANDS Status: offline
Recently, MVVS quickies were adapted to the US nitro craze. Result: They now run much shy of their potential when used in FAI events, where no nitro is allowed, unless the compression ratio is raised again. Generalities: A good engine does not need nitro, if the compression ratio is adjusted accordingly. There is ample proof of that in FAI racing. In a less than good engine, bad design can be blanketed by nitro, sometimes lots of it is needed. In two strokes, nitro helps to make carb setup uncritical, due to the wider combustion limits of nitro. In four strokes, nitro helps a lot to get the engine ironed out over the whole rpm range. More power can be had from a good engine at nitro over 20%, if the CR is adapted wisely. (grammar edit)
< Message edited by preivers -- 1/4/2006 1:43:42 PM >
_____________________________
Pe, MVVS, MTW, Mejzlik. www.mvvs.nl There is sanctuary in analisys.
