types of fuels claims on o%nitro??
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> types of fuels claims on o%nitro??
Page: [1] 2   next >   >>
Login
types of fuels claims on o%nitro?? - 12/28/2004 5:16:58 PM
suzonka
Status: offline
what is the difference of no nitro like tower sells and your cool power that tower sells with the nitro 0% or 4% % content?Im looking for the lowest % that will still fly my sport modles and cubs and I dont get it how they say the performance is great even with the FAI 0% fuel without nitro? anyone have the answer?
       Post #: 1
RE: types of fuels claims on o%nitro?? - 12/28/2004 8:58:50 PM
jaka
Status: offline
Hi!
Well some engines will work just fine on 0% nitro. Like all Webra and MVVS engines.
This is the way they are made (their combustion chamber is smaller, which mean they have higher compression, that way they don't need lots of nitro).
Nitro in just small quantities like 5% will make most engines run more reliable (have better idle and response and is easier to needle).
Regards!
Jan K
Sweden
_____________________________
Jan Karlsson Airracing products
MVVS, Motul "Micro" all synthetic oil
(in reply to suzonka)
       Post #: 2
RE: types of fuels claims on o%nitro?? - 12/29/2004 3:38:49 AM
suzonka
Status: offline
Thanks Jaka ,I often wondered how they made good claims about 0%
(in reply to jaka)
       Post #: 3
RE: types of fuels claims on o%nitro?? - 12/29/2004 4:51:39 AM
JoeAirPort
Status: offline
Add Moki engines to the list. They run the best on 0% nitro.
Joe AP
       Post #: 4
RE: types of fuels claims on o%nitro?? - 12/29/2004 6:39:43 AM
suzonka
Status: offline
thanks again , so OS engines need some nitro
(in reply to JoeAirPort)
       Post #: 5
RE: types of fuels claims on o%nitro?? - 12/29/2004 1:54:19 PM
JoeAirPort
Status: offline
yep, 5-10% is fine
quote:
ORIGINAL: suzonka
Joe AP
       Post #: 6
RE: types of fuels claims on o%nitro?? - 12/29/2004 2:00:49 PM
Hobbsy
Status: offline
Add Fox engines to that list of 0% nitro engines.
I can't ride my Harley and fly at the same time, what a bummer.
       Post #: 7
RE: types of fuels claims on o%nitro?? - 12/29/2004 3:02:53 PM
downunder
Status: offline
Surprise, surprise All engines will run just fine on zero nitro, including OS.
(in reply to Hobbsy)
       Post #: 8
RE: types of fuels claims on o%nitro?? - 12/29/2004 3:42:22 PM
Hobbsy
Status: offline
Down, all I use in them is Fox 5% nitro fuel with 20% 50/50 lube.
(in reply to downunder)
       Post #: 9
RE: types of fuels claims on o%nitro?? - 12/29/2004 8:43:47 PM
suzonka
Status: offline
what is the right info, only some engines or all?
       Post #: 10
RE: types of fuels claims on o%nitro?? - 12/29/2004 8:50:16 PM
JoeAirPort
Status: offline
Some were actually designed to run on 0% nitro. Many are listed above and are European designed. Irvine is another one that needs very little niro.
Now take YS or Saito engines. Many people use 30% heli on some of those engines. That gets expensive. Try running a YS on 0% nitro and you will not be happy with the results. 20/20 is the norm on those engines.
quote:
ORIGINAL: suzonka
Joe AP
       Post #: 11
RE: types of fuels claims on o%nitro?? - 12/29/2004 8:52:59 PM
PhilNZ
Status: offline
Hi,
I disagree with this general statement ..
No " all " engines will not run ok with NO NITRO..
If you read the manufactures recommendations on what fuel you should run you will see that each manufacturer will state something like 0 % Nitro 20% Oil ( 30% castor / 70% Synthetic ) or all castor plus 80% methanol.
FAI fuel is 20% oil 80% Methanol ..
Some manufacturers may state 5% or up to 10 / 15 % Nitro it is usually on the manual that comes with the engine or on their website..
The best way to find out is ask your engine supplier or go to the OS forum @ RCUNIVERSE ask the people that make them as it will be them that replaces it if it bombs out under warranty and if you have been running the wrong fuel then your warranty maybe no good.
Regards
Phillip
quote:
ORIGINAL: downunder
       Post #: 12
RE: types of fuels claims on o%nitro?? - 12/29/2004 9:12:58 PM
Hobbsy
Status: offline
One thing is certain, they will not bomb out from using 0% or 5% nitro. They may run a couple of hundred rpm shy on top end but that is all.
(in reply to PhilNZ)
       Post #: 13
RE: types of fuels claims on o%nitro?? - 12/29/2004 9:29:04 PM
JoeAirPort
Status: offline
Now this is one statement that I'm sure is backed up by experience. How many engines do you have now? The last number I heard from you was around 140?
quote:
ORIGINAL: hobbsy
Joe AP
       Post #: 14
RE: types of fuels claims on o%nitro?? - 12/29/2004 9:58:55 PM
Hobbsy
Status: offline
Actually Joe, the last engine I bought is a Conley 120 and it is #120 and I think I have my Zenoah G45 sold so I'll be down to 119. I have spoken for the first Saito 2.20 my LHS gets, qualified by if and when, and I have a Fox .50 coming any day now. Taking about the 5% nitro and engines, it works just fine in my OS LA .46 and .65. Big Saitos run great on 5% nitro also, the little ones don't do as well. I accidently put 10% nitro fuel in my MDS 2.18 at W8YE's house summer before last and knew instantly something was wrong. It made real unhappy sounds.
       Post #: 15
