New Fuel Technology
Tower Hobbies
Logged in as Guest
  Printable Version
Area 51cc Gas Engine - RTF
Seller:  Milton
Details:   $399.95   |  6/30/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> New Fuel Technology
Page: [1]
Login
New Fuel Technology - 12/29/2004 3:36:01 AM
scole
Status: offline
It all started when i was looking to "brew" my own fuel for low prices. I had 6-7 5 gallon bottles of Tequilla that i found in my "cellar", and i decided that was going to be my main ingredient. In the end i found that 74-76% works great. Now for the oil part, i have been trying liquid nitrogen, Jack Daniels, and everclear. Using the JD is just a waste, everclear does a good job, but you need about 30-34% to get a good oil coat. I have found the liquid nitrogen works awesome, i use between 3-6% liquid nitrogen and 94-97% tequilla, the engine runs really well on that mix and the engine is super cool. The liquid nitrogen gets expensive pretty fast even with 3-6%. So i tried maple syrup, YAHTZEE!!!11!!!!!!!1!! We have the magic combo here!!!!!!!!!!!!11111 I "brewed" up 74% Tequilla, and 26% maple syrup, it ran just like my Omega 10%, but it lacked in throttle transition, so i experimented and tried 2% honey. That 2% of honey really gives it that extra kick. So my final blend was 74% Tequilla, 24% maple syrup, and 2% honey for that extra kick. If you are looking for a cheap way to "brew" your own fuel then this is it!
< Message edited by scole -- 12/29/2004 3:42:52 AM >
       Post #: 1
RE: New Fuel Technology - 12/29/2004 3:57:14 AM
Mudsurfer1234
Status: offline
sorry, but i really do think you were sippin a little too much Tequilla when you started this thread cuz no way dude, just no way
_____________________________
Scott Shoemaker
(in reply to scole)
       Post #: 2
RE: New Fuel Technology - 12/29/2004 5:46:58 AM
LavaRocks
Status: offline
i've been using a similar mix for years, it really is terrific. i'm surprised its been kept a secret for this long!
Charles "Short Shorts" Teeter
(in reply to Mudsurfer1234)
       Post #: 3
RE: New Fuel Technology - 12/29/2004 8:10:08 AM
lomcevek1
Status: offline
It really does work. In the cold weather up here you need to add a little bit of glycol or it will lean out.
PB 146
(in reply to LavaRocks)
       Post #: 4
RE: New Fuel Technology - 12/29/2004 4:30:37 PM
scole
Status: offline
LAVA ROCKS!!1 I though you were up in Alaska hunting wolverines???? Are you just home for the holidays? I can't lay claim to this mix, it was all Lava Rocks.
(in reply to lomcevek1)
       Post #: 5
RE: New Fuel Technology - 12/29/2004 5:04:55 PM
lenz rc
Status: offline
I going to have to try some of that brew? Can I still drive home with it in the back seat . Or will it be considered it a open container to the local cops?
(in reply to scole)
       Post #: 6
RE: New Fuel Technology - 12/29/2004 9:49:40 PM
rcam
Status: offline
That is exactly the mix I use for a cold, sore throat, etc.... If your feeling poorly, down a couple of glasses and it will make you feel lots better....
rcam
(in reply to lenz rc)
       Post #: 7
RE: New Fuel Technology - 12/30/2004 1:56:10 AM
crazystix
Status: offline
Also good for acne! I like your mix, but tequila is too expensive, so I use Glass cleaner. $2.00 a gal at Pep Boys!
Paul Swany Rules!
(in reply to rcam)
       Post #: 8
RE: New Fuel Technology - 12/30/2004 10:03:39 PM
Fuelman
Status: offline
Stephan,
I told you not to tell anybody my formulations.
Just remember that with honey is for two strokes and without is for heli's and four strokes
Fuelman
Cooper Fuels LLC
(in reply to crazystix)
       Post #: 9
RE: New Fuel Technology - 1/4/2005 3:56:24 PM
bako
Status: offline
once i wanted to piss alittle. i pissen in fuel container, then added abot 5-50% honey and my engine started. it has bit less idle, than saito 20/20 fuel, but it's cheap. u pay only for honey, and main ingredient is from your /***
(in reply to Fuelman)
       Post #: 10
RE: New Fuel Technology - 1/4/2005 8:04:17 PM
scole
Status: offline
Now your just lying.
(in reply to bako)
       Post #: 11
RE: New Fuel Technology - 1/4/2005 9:57:26 PM
Jimmbbo
Status: offline
quote:
ORIGINAL: scole
Also heard it is a cheap Viagara replacement...
Have you flogged your crew today?
(in reply to scole)
       Post #: 12
RE: New Fuel Technology - 1/7/2005 11:32:35 AM
bako
Status: offline
ok now i'm not lying. I usen medicine 98% spitrus. 80%spirtus, 20% castor. it looses about 20% of power. it works well for trainer applications. u can add nitro, and everything will be all right, but ven without nitro it can fly. just bit hard starting, but if have el starter no propblem there.
(in reply to Jimmbbo)
       Post #: 13
RE: New Fuel Technology - 3/16/2005 8:40:59 AM
hitman45
Status: offline
Is this thread just a whole bunch of bull s-h-i-t? or is it for real? Me personally will probably not try it (unless I have a crappy worn engine that is worth as much as a packet of chips) Then I might try it. I can understand that the Tequilla may work but using honey and syrup as a oil? Man the least you could say that would of made alittle sense is by saying you mixed cooking oil in the mix. I think that would be a better mix. Hey now that I have brought that up...would Extra Virgin or Conola cooking oil work well to lube our little engine?
That would be pretty funny
(in reply to bako)
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
