Weedeater Featherlite Conversion    Gallery
Logged in as Guest
    Search This Thread
Printable Version
90 Dgree Muffler Adapters
Seller:  RC Specialties
Details:   $19.95   |  6/6/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> Weedeater Featherlite Conversion
Page: [1] 2 3   next >   >>
Login
Weedeater Featherlite Conversion - 12/30/2004 2:38 AM
susquach
Score: 100
Last Login: 6/23/2010
Status: offline
Summer's over...it's time to convert the lawn equipment to more productive purposes! Wuz wondering if anyone has converted a Weedeater Featherlite 1500? Just looking at the leafblower, it looks like a fairly easy job.....a lot of munching on the aluminum mounting assembly. Kind of have some misgivings about the prop its capable of turning. Any words of wisdom??
Hide Signatures
       Post #: 1
RE: Weedeater Featherlite Conversion - 12/30/2004 5:41 AM
w8ye
Score: 318
Last Login: 6/19/2013
Status: online
They have rather small ports and are not the most powerful gas engine around. The hub and back plate required is the same one used with the Homelite. I converted a 21 cc trimmer. I put a much larger Homelite 25 stock caarb on it and still, it was nowhere near as powerful as the Homey 25. You want to shoot for around 7,000 rpm. Try a 14-8 and see what you get. It's been a while with mine and I sold it some time ago.
Enjoy,
Jim
_____________________________
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to susquach)
       Post #: 2
RE: Weedeater Featherlite Conversion - 12/30/2004 6:05 AM
susquach
Score: 100
Status: offline
Thanks for the info. Yeah...got the feeling this little guy is going to have to go into a carefully selected plane....still, marginal power in a lightly loaded plane is way more fun than marginal power in a stooopid leafblower.
Hide Signatures
(in reply to w8ye)
       Post #: 3
RE: Weedeater Featherlite Conversion - 12/30/2004 7:30 PM
Antique
Score: 557
Last Login: 3/21/2012
Status: offline
I bought a rreconditioned Featherlite from Lawnstation a few years ago to try...Put a hub and glowplug adapter on it with a WT499 carb from a glow G23...Ran ok, was not overly impressed with it so it's still in a drawer somewhere...Anybody wants it without the carb, send me $20 and your address....
RC Ignition
Hide Signatures
       Post #: 4
RE: Weedeater Featherlite Conversion - 12/30/2004 10:19 PM
Volfy
Score: 100
Last Login: 1/30/2009
Status: offline
Ralph, does the hub go with it? If so, I'll take it!
Let me know and I'll send you a $20 MO today.
Si vis pacem, para bellum.
Hide Signatures
(in reply to Antique)
       Post #: 5
RE: Weedeater Featherlite Conversion - 12/30/2004 10:31 PM
Antique
Score: 557
Status: offline
It does, send me your address, I'll send it tomorrow...
RC Ignition
Hide Signatures
(in reply to Volfy)
       Post #: 6
RE: Weedeater Featherlite Conversion - 1/1/2005 3:16 AM
farley9n
Score: 100
Last Login: 6/2/2011
Status: offline
Hi!
Just a note to advise you that all Featherlites are not created equal. If you can get one with a bolt on muffler that clyinder will also have larger transfer, intake, and exhaust ports. More power but same light weight! Maybe not as much as a couple other 25cc conversion engines but still very light.............Bob
Bob
Hide Signatures
       Post #: 7
RE: Weedeater Featherlite Conversion - 1/2/2005 1:38 AM
oslim
Score: 100
Last Login: 5/8/2009
Status: offline
to farley9n: Can you remember the model designation(s) for the weedeaters with bolt-on mufflers? Were these part of the featherlight series? I really like the low weight of the weedeater engines even if they don't develope max power. BTW, stopped in Sears recently & they are selling a new model of Weedeater Featherlite 25 trimmer with less plastic shrouding and 2-bolt back cover instead of 4-bolts. Weight increased to 8.8 lb & box implies 50-states emissions calibration (includes California). Don't know if this will make it more tempermental or harder to start???
Hide Signatures
(in reply to farley9n)
       Post #: 8
RE: Weedeater Featherlite Conversion - 1/2/2005 7:54 PM
farley9n
Score: 100
Status: offline
To OSLIM
I have no idea of the model numbers but I can send you some pictures of two that I have sold and one that I still have if that would help. ............Bob
Bob
Hide Signatures
(in reply to oslim)
       Post #: 9
RE: Weedeater Featherlite Conversion - 1/3/2005 2:24 PM
oslim
Score: 100
Status: offline
To farley9n: Yes , would appreciate pictures. Please send to gustaviseng@aol.com.
Thank you
Hide Signatures
       Post #: 10
RE: Weedeater Featherlite Conversion - 1/4/2005 5:37 AM
pcjohnson_ohio
Score: 100
Last Login: 6/7/2013
Status: offline
My first conversion was a Featherlite Blower, just finished this weekend
$70 from Lowes
Really easy to do. Ran for 30 minutes as a blower. Pulled everything off the motor. Trimmed off excess aluminium with a RotoZip. Trimmed and balanced flywheel. Added a hub. Trim crankcase backplate on bandsaw. Made a motor mount out of HDPE cutting board. Cut the plastic throttle arm off carb and added a control arm. Cut a couple of 1/2" holes in muffler to open up exhaust. Mounted on a test stand. Wired kill switch. Used tank from blower. Started right up with $20 Tower starter
Couple of things, though. I'm using a carb off of a Featherlite string trimmer (the pics show two different carbs) because I couldn't turn the needle valves and I couldn't find my Dremel to slot them. Plus there is no idle stop (not a problem once mounted in a plane with a servo to control the idle.)
Also, this is a long shaft model, so the hub needs a 5/16" straight hole (instead of threaded)
The muffler is bolted on (unlike earlier models) but it has a 4 hole backplate which makes mounting easy (unlike later Featherlite Extreme models)
BTW the Lowes ad says 18cc, the box says 23 cc, and the engine plate says 25cc, so who knows
Turns 7400 rpm with a Zinger 15x8, Idles all day, surprisingly smooth, transitions nicely, hand starts with one flick when warm, have about 1 hour run time
Total weight is 3 1/2 lbs.
Going to try a APC 14x8 in am
Overall, I'm pleased for $80 and 2-3 hours invested for first gas engine. It's going in a 72" 1000 sq. in SPAD, projected weight 10#
Pete Johnson
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by pcjohnson_ohio -- 1/4/2005 12:51 PM >
Hide Signatures
       Post #: 11
RE: Weedeater Featherlite Conversion - 1/4/2005 6:37 AM
w8ye
Score: 318
Status: online
Where's all the snow?
Jim
Original AMA #31261
Hide Signatures
(in reply to pcjohnson_ohio)
       Post #: 12
RE: Weedeater Featherlite Conversion - 1/4/2005 12:49 PM
pcjohnson_ohio
Score: 100
Status: offline
50 degrees and Sunny on New Years Day, Snow don't stick
Hide Signatures
(in reply to w8ye)
       Post #: 13
RE: Weedeater Featherlite Conversion - 1/4/2005 3:26 PM
oslim
Score: 100
Status: offline
To pcjohnson_ohio: Neat job! What material did you use for the hub spacer? Did you add serrations or friction material to prop or flywheel contact surfaces? Thank you for pictures . Say hello to your dog.
Hide Signatures
       Post #: 14
RE: Weedeater Featherlite Conversion - 1/4/2005 10:38 PM
pcjohnson_ohio
Score: 100
Status: offline
The hub is plastic pipe cap filled with JB weld
The center tube came with the blower
See diagram
Seems quite solid, runs true, have 2 hours on engine
I can't vouch for long term durability but the 5/16" shaft carries the load
There is a washer between prop and hub that has both sides dimpled with drill bit tip
Turns 8000 on 14x8 APC, idles at 2000
BTW covering one of the two muffler holes cuts the noise without cutting rpms much
One 1/2" hole may be optimal
Pete Johnson
Click for fullsize
< Message edited by pcjohnson_ohio -- 1/4/2005 10:40 PM >
Hide Signatures
(in reply to oslim)
       Post #: 15
RE: Weedeater Featherlite Conversion - 1/6/2005 6:10 AM
dirtypool
Score: 100
Last Login: 3/2/2013
Status: offline
I just had one given to me (weed eater featherlite) but I have to disassemble to see which one I got.
I will probably put it on a Big Pink or on my Sr Telemaster.
Who sells the prop hubs?
Hide Signatures
       Post #: 16
RE: Weedeater Featherlite Conversion - 1/7/2005 2:49 AM
bbbrown
Score: 100
Last Login: 1/12/2008
Status: offline
I have a Weedeater Featherlite 25cc on a Balsa USA Stingray 120. It has OVER 80, 10 minute or more, flights on this engine. Enough power to fly the stingray and do all the usual maneuvers. It has the stock carb with a velosity stack and CH ignition. 6800 rpm with a 16x8 prop. Next project is a 36cc Poulan chainsaw conversion.
BBBrown
Hide Signatures
(in reply to dirtypool)
       Post #: 17
RE: Weedeater Featherlite Conversion - 1/7/2005 8:21 AM
dirtypool
Score: 100
Status: offline
Well, the ID plate says 25cc but I havent torn it down to a bare engine yet. Is the tag on the powerhead usually correct?
Thanks.
Rob
Hide Signatures
(in reply to bbbrown)
       Post #: 18
RE: Weedeater Featherlite Conversion - 1/7/2005 10:16 AM
mikenlapaz
Score: 100
Last Login: 2/26/2013
Status: offline
I tried a VHMW prop hub and retired it, with limited use. While changing props I noticed more than once a white powder. I could not get the prop tight enough to keep from it slipping and abrading the VHMW. THEN a close inspection revealed stress cracks radial from the center! I'll stick with aluminum from now on. Not worth the risk.
Lacking a method to neatly roughen the a bearing surface, I use drywall sanding screen. It is tough.
trying to tax into prosperity is like a man standing in a bucket and trying to lift himself up by the handle W. Churchill
Hide Signatures
       Post #: 19
RE: Weedeater Featherlite Conversion - 1/7/2005 4:40 PM
Prop Nut
Score: 100
Last Login: 5/12/2012
Status: offline
Coverted a Featherlight 1500 last summer, love it. Really easy to convert and runs great. I turn a 15x8 at 7000-7100 RPM. Its on my Balsa USA Eindecker 80". We (fellow club members) bought 6 of these directly from Poulan's factory reconditioned store at the factory for 37.00 (9.00 for shipping UPS) and one of our members made the coversion parts for us in his machine shop. Very very easy to convert and use. They do say 16cc on the box, but the engine houseing says 25cc and we mic'ed them at 24.9 or so. These are the ones with bolt on mufflers. If anyone is interested I can look up the phone number to thier store (Or anyone can for that matter).
Click for fullsize
Scope? Listerine? Or Prop Wash?
Hide Signatures
(in reply to mikenlapaz)
       Post #: 20
RE: Weedeater Featherlite Conversion - 1/7/2005 11:29 PM
oslim
Score: 100
Status: offline
To Prop Nut: Searched Google under "Poulon Reconditioned Store, Factory, Trimmer, & Blower. Did not find factory store. **** has reconditioned Poulons but at higher price & shipping than you found. Would appreciate if you could find address or phone number, or better key words to search with. Thank you.
< Message edited by hobbsy -- 1/10/2005 5:12 AM >
Hide Signatures
(in reply to Prop Nut)
       Post #: 21
RE: Weedeater Featherlite Conversion - 1/8/2005 1:49 AM
Prop Nut
Score: 100
Status: offline
The number is 870-845-6614, I purchased mine in July of 2004. Dont know if the price is still the same, they where closed a few minutes ago when I called the number. There is another outlet store (not the factory store) at Lawnstation.com that has a posted price of 49.99 plus shipping. All these are reconditioned. The feather light says 18cc but all of the ones we have purchased have turned out to be 25cc. Hope this helps. (Your right, I did a search to and found everything but this number)
Hide Signatures
(in reply to oslim)
       Post #: 22
RE: Weedeater Featherlite Conversion - 1/8/2005 1:51 AM
Prop Nut
Score: 100
Status: offline
By the way Oslim, if you would like to see them fly this summer, come on over to Greenville (just north of GrandRapids) and fly with us. We have six of these things mounted on various planes.
Hide Signatures
       Post #: 23
RE: Weedeater Featherlite Conversion - 1/8/2005 6:37 AM
dirtypool
Score: 100
Status: offline
I guess it is a 25cc.
Muffler bolts on, 4 screws in the backplate, output shaft is very short with the key cast into the flywheel (wide)
How do you put a prop on something like that?
Lots of work to do on that case. Do you know if CH makes an ignition for this one? Looks like it will be really light.
California emissions on the carb.
Another weedie to mess with.
Hide Signatures
       Post #: 24
RE: Weedeater Featherlite Conversion - 1/8/2005 7:35 AM
Prop Nut
Score: 100
Status: offline
A buddy of mine made the prop spacer so I am not sure what size to tell you to look for. I can find out tommorow and let you know. The spacer is not threaded just slides over the shaft. I have heard of people putting CDI on this one but why bother? Its very light as it is. As for the work on the casing....took me about 5 minutes with my edge sander and it was done. Be careful not to take to much of the ignition bracket off. One of our guys did and weakened it too much.
Hide Signatures
       Post #: 25
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Conversions >> Weedeater Featherlite Conversion
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.375RCU1
