RE: Hanger 9 P-40 Warhawk 60
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
P-40 Warhawk .60 w/Retracts
  • Read Full Review
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> ARF or RTF >> RE: Hanger 9 P-40 Warhawk 60
    Page: <<   < prev  5 6 7 8 9 10 11 12 13 [14]
    Login
    RE: Hanger 9 P-40 Warhawk 60 - 5/31/2007 10:02:38 PM
    BOLT
    Status: offline
    I'm about to begin builiding my Hangar - 9 P-40. I plan to install a set of C.J.M. retracts for it. A firend of mine told me that in order for the retracts to work properly (ours is a grass field) the retracts must be installed at a 110 degree foward or the plane will tip-toe on take off. After inspecting the modifications needed for the C.J.M. retracts it's impossible to tilt foward the landing gear beyond 90 degrees. I checked the retacts that come with the model and they are at 90 degrees which means that this plane will not take off from our grass field. Any comments on this issue will be appreciated. I'm not going to start building until I resolve this issue, it's sad to crash-land such a nice airplane on take off because of this potential problem with it.
    _____________________________
    Blessed is the man who has a hobby for he has two worlds in which to live.
    (in reply to ICE_MAN)
           Post #: 326
    RE: Hanger 9 P-40 Warhawk 60 - 6/1/2007 5:30:20 AM
    Wine Country Flyer
    Status: offline
    Go back to page 13 and and check out the post that gives a link to a guy on RC Groups. This guy did a great review. I followed his lead and added NO nose weight, plus did not have to cut the cowl all to hell. Move the CG back 1/4 inch from recommened and she'll fly off grass with no problem. Mine does.
    Hope this helps. John
    You can make anything fly-just put enough motor on it !
    (in reply to BOLT)
           Post #: 327
    RE: Hanger 9 P-40 Warhawk 60 - 6/1/2007 1:47:09 PM
    BOLT
    Status: offline
    John:
    Thanks for your propmpt response. I will move the C.G. back as you recommend. I already installed one of my C.J.M. retracts on the left wing , now I'll go with te right wing panel. This will be the only major modification to this plane so I hope everything else will be straight foward. I'll try to post some pictures.
    Bolt
    (in reply to Wine Country Flyer)
           Post #: 328
    RE: Hanger 9 P-40 Warhawk 60 - 6/2/2007 5:04:07 AM
    Wine Country Flyer
    Status: offline
    Yep-It's pretty straight forward. Nothing out of the ordinary. If you follow that review on RC Groups you'll have a great flying plane. And a good looking cowl, too. Here's a pic of mine about to touch down. This is my home field, with astro turf, but I have flown it a few times off grass. Post pics when ya can.
    Later-John
    Click to see fullsize image.
    Click for fullsize
    (in reply to BOLT)
           Post #: 329
    RE: Hanger 9 P-40 Warhawk 60 - 2/5/2008 2:39:32 PM
    KLF1292
    Status: offline
    Will a Saito 1.25 fit in this plane? Should be able to swing a larger 3-bladed prop for thrust (and scale looks) but also will still slow down well when landing.
           Post #: 330
    RE: Hanger 9 P-40 Warhawk 60 - 3/24/2008 10:04:22 PM
    Jinxx
    Status: offline
    Yes, it will fit. I had a Saito 150 in mine until I recently wrecked the plane in a collision with a telephone wire. The engine is fine but I'm getting a new plane and will be going with a Saito 100 and the Keleo "scale" exhaust this time.
    I forgot to mention, I was using the stock exhaust with the Saito 150. Because the exhaust exits from the back of the head at an angle, I had to make a small notch in the bottom of the firewall in order for it to fit more snugly. Otherwise, the spinner/prop would have been too far forward. Also, I used a remote glow plug to make it easier to reach.
    One more thing, it balanced perfectly with servos etc in their stock locations but I had to zip-tie the battery to the former right behind the servo tray.
    < Message edited by Jinxx -- 3/24/2008 10:20:20 PM >
    (in reply to KLF1292)
           Post #: 331
  • Read Full Review
  • See User Ratings
  • Jump to:
    Google
    SITE MAP!   : :   FORUM RULES
    Kaango.com Classifieds
    0.734RCU1
