Gas Questions??????
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Gas Questions??????
Page: [1]
Login
Gas Questions?????? - 1/1/2005 11:57:43 PM
welchfd15
Status: offline
Can Anyone tell me how long the shelf life is on gas? Any suggestions on brand I have a superstar select .40la o.s. engine The manual said to use 10 percent
       Post #: 1
RE: Gas Questions?????? - 1/2/2005 1:52:25 AM
rctrax
Status: offline
are you talking gas or glow fuel? the latter will keep indefinatly if kept in a sealed container in a cool dry place away from sunlight
(in reply to welchfd15)
       Post #: 2
RE: Gas Questions?????? - 1/2/2005 2:45:35 AM
Ernie Misner
Status: offline
Yeah, you mean glow fuel. 10% or 15% should be fine for your bushing engine. I would run fuel that is from a major supplier that clearly lists the contents, especially oil content and type. I would run a synthetic, castor mix, keep that LA from running too lean, and it should give you great service.
Ernie
(in reply to rctrax)
       Post #: 3
RE: Gas Questions?????? - 1/2/2005 3:08:09 AM
GotCoffee66
Status: offline
I have an .40 LA for 3 years now. Run a cheap 15%nitro and 20% castor thru it. I use the same fuel in my T-maxx and rustler. My gas is almost two years old and works great, just make sure you put the lid on tight as the fuel will evaporate
_____________________________
Ray
(in reply to Ernie Misner)
       Post #: 4
RE: Gas Questions?????? - 1/2/2005 3:17:22 PM
rctrax
Status: offline
will also draw water from the atmosphetre if left open. always keep it closed tight even between fillings at the field.
(in reply to GotCoffee66)
       Post #: 5
RE: Gas Questions?????? - 2/14/2005 1:44:36 PM
speedster 1919
Status: offline
That is a bushing engine. 5 - 10 % nitro is fine and pure castor or a blend will be fine, 20 % oil content. Don't use all synthetic.
Hey Buddy -That was the most spectacular crash I've ever seen , That rolling cart wheel with parts slinging out was cool...
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.391RCU1
