What are you using for a fuel tank?
Tower Hobbies
Logged in as Guest
  Printable Version
K&B .40 R/C Ball Bearing
Seller:  area51jmitch
Details:   $75.00   |  8/28/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> What are you using for a fuel tank?
Page: [1]
Login
What are you using for a fuel tank? - 12/19/2001 10:10:42 AM
JohnVH
Status: offline
I have a YS.45FS and it sure pumps up that tank, the one I had leaked out the screw on cap for the fuel connection. Went to a different one now, need to test it.
Just wondering what works best. Also, what plug and fuel % is best in these?
_____________________________
---AIR VH---*FURY FLYER* www.3DFoamy.com
       Post #: 1
YS Engines - 12/19/2001 11:32:59 AM
mglavin
Status: offline
John
YS Engines like 20%nitro/20% synthetic oil for sport use...
OS #8 plug or a Enya #3 plug works well.
Use a fuel tank that is of the seamless variety, so as to prevent a rupture. Sullivan offers these as well as others...
Tettra available from Central Hobbies offer's a tank inteneded for pressurized systems.
Michael Glavin
RCU Community Moderator
Hitec * Multiplex Field Representative
(in reply to JohnVH)
       Post #: 2
What are you using for a fuel tank? - 12/19/2001 6:58:47 PM
JohnVH
Status: offline
OK, thanks
       Post #: 3
Quality - 12/20/2001 3:35:09 AM
Hobbsy
Status: offline
I use Sullivan's because all their other products are of high quality. When I'm building a project I change most of the hardware, control rods and wheels to Sullivan.
"I have gone faster backwards, upside down and on fire than most people have gone at all" Don Garlits
       Post #: 4
YS tanks - 12/20/2001 3:49:24 AM
ChuckAuger
Status: offline
Some people recommend wrapping the tank with strapping tape to keep it from swelling under pressure.
And while the four stroke YS engines run well on 20/20, it might be a little high on nitro for a 45 2 stroke, especially if you are gonna run a pipe..are you gonna run a pipe?? If so you will need a cold plug for 20% nitro, IMHO.
Breaking the Speed of Sound, Straight Down!
       Post #: 5
What are you using for a fuel tank? - 12/20/2001 4:43:02 AM
djlyon
Status: offline
I wrap the tank in strapping tape. I have a pipe on mine and run anything from 5% to 15% and use an OS#8 plug. This engine on a pipe with 15% can be/is hard on plugs. I can't recall seeing any difference in performance between the 5 and 15% fuel with a 10/9 APC prop.
I never met an engine I didn't like.
Of the things I've lost I miss my mind the most.
       Post #: 6
What are you using for a fuel tank? - 12/20/2001 4:56:23 AM
sideshow
Status: offline
I use the Tettra tank that is available from Central, like Michael said. I have used it for almost a year on my YS 91 with no leakage at all. Sometimes I forget to release the pressure when done flying and I get a nice fuel bath when I open the vent the next day. Good luck.
Bob
       Post #: 7
What are you using for a fuel tank? - 12/20/2001 6:28:05 AM
JohnVH
Status: offline
Yes, it is a two stroke, I have been running just a cheap fox long in it, and some 15%x20% byrons in it. Looking to see what others had.
       Post #: 8
Fuel Tank... - 12/22/2001 5:37:35 AM
Snaggs
Status: offline
John,
I have the YS-63 FS and I'm using a Sullivan tank as well. I wrapped it with clear packing tape since I've heard of them splitting. I run the Wildcat 4 fuel. The label says YS 20/20 on it.
I've hear excellent things about the Wildcat fuel. I've run it in there since the engine was new and I've had no problems with it.
Sideshow: I'm glad to see I'm not the only one to hose the place down by pulling the wrong line and from the pressure in the tank!
I have mine in a Ultimate and have the fill and pressure lines come out the bottom of the cowl. One is longer than the other so I can remember which one is which. I figured it'd be easier to remember if I related the tube lengths to the tubes in the tank. In the tank, the pressure is up top and the pick-up/klunk line is on the bottom. I made the pick-up line hang down lower, thinking it's lower in the tank. I still grab the wrong one by not paying attention, but I always have a way to figure how which line is which.
-Snaggs
       Post #: 9
What are you using for a fuel tank? - 12/22/2001 8:57:05 PM
sideshow
Status: offline
Try this: Use two colors. I use pink (p) for pressure and blue for the fill. But when I forget to depressurize at the field....fuel all over the place.
       Post #: 10
What are you using for a fuel tank? - 12/23/2001 6:26:15 AM
JohnVH
Status: offline
Thats a good idea, I too shot fuel everywhere the first time, I was impressed, to empty the tank I just hook it to the fuel on the plane and it shoots the fuel out all on its own
       Post #: 11
Fuel Tanks........ - 12/24/2001 3:32:15 PM
Jackjet
Status: offline
To Everyone,
depending on the airplane-Jet or prop-I sometimes use soda bottles and regular r/c hobby tanks-have used everything from shampoo bottles to spray cans-btw-did you know that a sprite soda bottle makes a very good air tank for air powered retracts ?
Jackjet
Jack Jet Williams
Hesperia,Ca
       Post #: 12
Fuel Tanks - 1/5/2002 4:58:10 AM
Steve Collins
Status: offline
I have used every brand mentioned here so far and they all work. However, I have found that the best tanks, by far, are the Hayes tanks. These were previously marketed as Kraft tanks. I have never had one of these fail or leak a drop, even when used with a pressurized Y.S. system.
In the ducted fan jet world, many wrap their tanks with carbon fiber cord and hold it in place with CA to prevent bulging.
       Post #: 13
AIR TANKS? - 1/5/2002 11:36:27 AM
RCRC
Status: offline
A lot of good ideas here. And pop bottles do make good fuel tanks.
But - I have seen pop bottles used for retract air tanks explode BIG time! And I mean total destruction of the airframe of giant scale aircraft!
Just ask some of the TOC fellows that found this out the hard way a few years back!
< Message edited by RCRC -- Jan 5 2002 6:40AM >
       Post #: 14
Re: AIR TANKS? - 1/5/2002 9:01:57 PM
Jackjet
Status: offline
[QUOTE]Originally posted by RCRC
[/QUOTE]
Hi RCRC,
I have'nt have one explode on me yet-I put 280psi in a sprite plastic bottle and it blew the lid off-but for normal use- I use 125psi and that seems to work just fine for me.Plus I can cycle the gear 15 times on just 1 air charge.
Jackjet
Jack Jet Williams
Hesperia,Ca
