Playboy on floats
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Seaplanes >> Playboy on floats Page: [1]
Login
Playboy on floats - 1/4/2005 5:38:31 PM
dicknadine
Status: offline
trying something different. putting my 81" Playboy on floats, old style, homemade ones. since I have 5 miles of water in front of the house and sometimes in the house- during hurricanes. they are ready to cover and the see if they are big enough to support the plane. dick
Click to see fullsize image.
Click for fullsize
_____________________________
dick/rcflyer
       Post #: 1
RE: Playboy on floats - 1/4/2005 6:36:08 PM
seaplane
Status: offline
I did the same thing to my Cloud King last summer. My floats were 16" long, 2" wide, and 3" high. I did get it in the air , but it was difficult, not enough floatation. I'm presently making them 2" wider, which should do the trick. It was and still will be easy to tip over with cross winds due to the high dihederal. I'm sure your Playboy will be the same..............Seaplane
(in reply to dicknadine)
       Post #: 2
RE: Playboy on floats - 1/5/2005 5:25:38 AM
JohnBuckner
Status: offline
Old timers make wonderful quiet water flyers. Just a thought Dick you may want those floats a little further apart when you get crosswind on the water taxi t does not take much to blow it over. Here is my 'Kerswap' on three soda pop bottles. Last picure is just after sitting down in my buddys stock pond, First picture is a double post and no provision to get rid of it.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by JohnBuckner -- 1/5/2005 5:32:08 AM >
"Keep your controllines tight"
(in reply to seaplane)
       Post #: 3
RE: Playboy on floats - 1/5/2005 2:47:28 PM
dicknadine
Status: offline
will find out this afternoon,after I cover the floats. then the bathtub test. may be big enough or not. dick
dick/rcflyer
(in reply to JohnBuckner)
       Post #: 4
RE: Playboy on floats - 1/7/2005 4:25:06 PM
Goinstraightup
Status: offline
That's very interesting JohnBuckner on the Bottle floats! First I've seen that.
Jeff
       Post #: 5
RE: Playboy on floats - 1/7/2005 5:13:59 PM
dicknadine
Status: offline
bad and good news. small ones tooooo small, would not support the weight. so new foam ones with yard sticks for backbones in process, same size as the store molded plastic ones but 1/2 the weight, no matter how long you have been in the hobby-- there's always something new to try without getting discussed. dick
dick/rcflyer
       Post #: 6
RE: Playboy on floats - 1/12/2005 12:43:59 AM
Test005
Status: offline
Hi
What kind of engine do you guys run them Playboys with?
My friend is building a Playboy and we got him a Magnum .52 fourstroke, OK?
       Post #: 7
RE: Playboy on floats - 1/12/2005 2:04:39 AM
dicknadine
Status: offline
I am useing a good old Royal .28, plenty of power and over 100 flights on it, with 80" wing. floats are on hold till weather warms up a bit. dick
dick/rcflyer
(in reply to Test005)
       Post #: 8
RE: Playboy on floats - 1/12/2005 2:50:36 AM
JohnBuckner
Status: offline
Don,t ya just love the the hi tech experimenting Dick. Know what you mean, have not been in my hot tub for many years but its done yeoman service doing float test on a whole bunch of airplanes. Please, please post some more pictures when you get it going with the new floats.
Test, in my case it is not a Playboy but a Kerswap. A published design I think from around 1940 but could be a little off on that. Its powered with an old OS Max series .20 and spends 95% of its flight time at idle. 3Lbs. 1 ounce and 59inch wingspan. heres a photo of it on wheels doing what it does best, a high speed pass at idle smoking along around 13 mph.
John
Click for fullsize
       Post #: 9
RE: Playboy on floats - 1/12/2005 1:20:37 PM
evan-RCU
Status: offline
Nothing like an old timer on floats.... 105" Quaker 2000, 6lbs(with floats), Saito .56 for power...
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Revver #125, Pico Owners Club #3
R/C Anonymous. My name is Evan and I have not flown for 14 hours.
       Post #: 10
RE: Playboy on floats - 1/12/2005 3:29:18 PM
JohnBuckner
Status: offline
Thats quite a collection of Quakers even. Have always admired the one in you avitar. Yup your right "Nothing like an old timer on floats"
John
(in reply to evan-RCU)
       Post #: 11
RE: Playboy on floats - 1/12/2005 3:43:47 PM
dicknadine
Status: offline
you started something with your Qaker on floats-- now I will have to start designing a set of floats for my 14 foot Qaker, looks like they will be a couple of canoe's. whose design did you use, are they a kit or scratch? plans available? dick
dick/rcflyer
       Post #: 12
RE: Playboy on floats - 1/12/2005 6:23:11 PM
evan-RCU
Status: offline
My own design, the"that looks about right" method, sorry I didn't make plans...
       Post #: 13
Page:   [1]
Page: [1]
Jump to:
