downunder-RCU
Joined: 12/27/2001 From: Adelaide, South Australia Status: offline
DerFly...with a brew like that you must be an Aussie too Shell A has 3% acetone already added to it...BP Racing fuel doesn't. For that reason I prefer the Shell A except I can't buy it other than in their drums. BP methanol (which I get from a local Ampol distributor, just to confuse things) has it in bulk so I can refill my drum. As for the turbine oils, yes, I've heard about it being carcinogenic but so are tomatoes! As an aircraft engine fitter I was immersed in the stuff for many years, breathed the fumes from jet engines using total loss oil systems and nun off us was effer effectid buy it Seriously though I think this is only a recent development because none of the cans of oil were labelled as being carcinogenic as it seems they are now (avoiding possible litigation?). As to how it performs, I found that my engine was running about 10C hotter than with all castor. For this reason I'd never use any of the inferior synthetics.
