hattend
CA, USA Status: offline
[QUOTE]Originally posted by mschoen I was thinking about the slimline pitts muffler but couldn't get the picture in my mind and didn't want to buy them unless I was fairly confident they would work. So I presume you're going to run them up and out the real exhaust ports right? I'd love to know how it goes for you. I might just take that route rather than having custom mufflers made up. [/QUOTE] Yeah, I'll run one like shown in the picture and run the other "upwards" towards the top of the cylinder (Turn the muffler 180 degrees). It isn't scale....they will both be pointing out the "outboard" side of the nacelle on each wing. (the engines will be mounted sideways) The only thing I'm not sure of is one set of pipes will be longer than the other set, so I hope I don't get some weird engine run problem from the slight difference in back-pressure (if any) I was going to go the Pitts muffler route but I don't want all that exhaust blowing down onto (and into) the main landing gear well. We'll see. I'm not anywhere near that point. I haven't even measured to see if the engine/muffler combo will fit. Don
