RE: Fliton Extra 330 Freestyle Who's Got One?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> RE: Fliton Extra 330 Freestyle Who's Got One?
Page: <<   < prev  81 82 83 84 85 86 [87] 88 89 90   next >   >>
Login
RE: Fliton Extra 330 Freestyle Who's Got One? - 2/28/2009 3:33 AM
STG
Score: 102
Last Login: 7/13/2010
Status: offline
I have mine mounted inverted and have the low end as lean as possible. The down side to this is that on waterfalls I have had the motor quit with rapid increase & decrease in throttle.
_____________________________
Good Flying to you!
See Blog for RCU Video's
Hide Signatures
(in reply to badfish)
       Post #: 2151
RE: Fliton Extra 330 Freestyle Who's Got One? - 2/28/2009 3:59 PM
badfish
Score: 100
Last Login: 4/15/2013
Status: offline
key is finding a happy spot. I would definately put up with a little shaking over having a dead stick. another thing I do is listen for the rpm drop when removing the glow stick. the richer it is the more your rpms will drop.
steve
Hide Signatures
(in reply to STG)
       Post #: 2152
RE: Fliton Extra 330 Freestyle Who's Got One? - 2/28/2009 7:27 PM
STG
Score: 102
Status: offline
quote:
ORIGINAL: badfish
steve
Yep, that is why I have it set so lean on the low end. Set up inverted and set lean, there is still a noticeable drop in RPM when glow is removed. As long as I don’t go full open/close/open/close/open real fast (as in fast waterfall—this FL is capable of wicked fast WF’s ) then I don’t have a problem.
Good Flying to you!
Hide Signatures
       Post #: 2153
RE: Fliton Extra 330 Freestyle Who's Got One? - 3/1/2009 1:21 AM
trpastor
Score: 145
Last Login: 4/15/2011
Status: offline
Well guys, It looks like my fliton days are over. I was doing some tinkering on it trying to get things worked out when I realized the plane is pretty much trashed. I was trying to start it the other day and was having those engine problems. Well, it backfired, rolled back and chipped the prop on the stand.
Apparently when it did this it broke the engine box free of the fire wall AND the firewall is cracked at the top, clear across.
Overall I have been very disappointed with this plane. It flew great the few times I got to fly it, but it was a huge pain to build, and fell apart not even in the air. How very disappointing that I will not get to see what it can do
Hide Signatures
(in reply to STG)
       Post #: 2154
RE: Fliton Extra 330 Freestyle Who's Got One? - 3/1/2009 1:22 AM
trpastor
Score: 145
Status: offline
Hey Jemini
Is the aeroworks almost as fun to fly? Better built? Easier build? Is the saito 100 too much for it?
I'm done with this POS, and need to move onto something else.
Tim
< Message edited by trpastor -- 3/1/2009 1:24 AM >
Hide Signatures
(in reply to trpastor)
       Post #: 2155
RE: Fliton Extra 330 Freestyle Who's Got One? - 3/1/2009 1:31 AM
Jimeni
Score: 110
Last Login: 1/22/2013
Status: offline
The Aeroworks edge is fine. I think if I had the money though, I would try the 60 to 90 Yak or Extra 260. You already have all the stuff. But you will not be dissapointed in the edge either. The Fliton does fly a bit better than the AW Edge, but from what I'm seeing, it will have nothing on the Extra or Yak.
On your Fliton. Its wood, epoxy will fix it. It cant be that bad. If its just cracked, but still in place, put a piece of light ply, or thin balsa strip over the crack, and epoxy away. Add some tri stock to the engine box.
It was a glitch, a technical malfunction! Why wont anybody believe me?
Hide Signatures
       Post #: 2156
RE: Fliton Extra 330 Freestyle Who's Got One? - 3/1/2009 1:41 AM
trpastor
Score: 145
Status: offline
Thanks Jemini
Did you have any issues with the aeroworks (breaking parts, weird fits etc, etc etc) that the fliton has?
I'm just so sick of not even flying this thing and having to fix things every time out. Anyone want this before I bring an axe down on it?
Hide Signatures
(in reply to Jimeni)
       Post #: 2157
RE: Fliton Extra 330 Freestyle Who's Got One? - 3/1/2009 4:04 AM
Jimeni
Score: 110
Status: offline
Nope. The edge is a very straight forward build, with excellent parts, hardware, and instructions. The new Extra, and Yak are quick builds. You'll be flying in about 6 to 8 hours. Aeroworks, as an added bonus, has about the best customer service you can get. Not to mentiobn all the pretty ladies showing you the models
Hide Signatures
       Post #: 2158
RE: Fliton Extra 330 Freestyle Who's Got One? - 3/1/2009 5:20 AM
victorzamora
Score: 134
Last Login: 5/12/2013
Status: offline
I have the AW Extra 60-90 and I had the Fliton Edge. I like the AW Extra more than the Fliton once it's in the air. I like the AW WAYYY more than the fliton between box and air. I think that the AW flies much better than the Fliton
Tact is for people not witty enough to use sarcasm.
Hide Signatures
       Post #: 2159
RE: Fliton Extra 330 Freestyle Who's Got One? - 3/1/2009 9:56 PM
trpastor
Score: 145
Status: offline
Hey Guys
Here's some shots. You can see the tabs broke on the bottom. ANd the engine box broke away on both sides on the bottom.
The top of the firewall (that the engine box is attached to) is giving, back and forth. Like it's soft.
What do you think repair would entail on this?
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to victorzamora)
       Post #: 2160
RE: Fliton Extra 330 Freestyle Who's Got One? - 3/1/2009 9:57 PM
trpastor
Score: 145
Status: offline
In case I decide not to fix it, anyone want to buy parts?
I have wing set -
fusealage - needs work : )
Hatch
canopy
landing gear
make offers
I'll keep engine and electronics and use on something else
Hide Signatures
       Post #: 2161
RE: Fliton Extra 330 Freestyle Who's Got One? - 3/1/2009 10:07 PM
Jimeni
Score: 110
Status: offline
I would cut the motor box completely loose, leaving remaining tabs intact. Clean off old epoxy edges, and get everything to a nice fit. Epoxy it on with more tristock where the tabs are broken, and probably several other spots. Fix crack as stated previously. From the pictures, I would say 1 to 1/2 hours work tops, it does not look that bad. When your done, it will be stronger than ever. Your plane has alot of life left. You already have it, use it up. Then you can take your time deciding on the replacement.
< Message edited by Jimeni -- 3/1/2009 10:08 PM >
Hide Signatures
       Post #: 2162
RE: Fliton Extra 330 Freestyle Who's Got One? - 3/1/2009 10:19 PM
trpastor
Score: 145
Status: offline
Do you mean cut the motor box free of the firewall, or just on the bottom 2 tabs?
I was thinking I'd have to cut it off and put a new piece of ply over the whole firewall for reinforcement. But how to you get the motorbox secure to the firewall again without having any tabs? Is the tri stock and epoxy enough? I'm not been overly impressed with expoxy, but maybe i"ve been using it wrong
Hide Signatures
       Post #: 2163
RE: Fliton Extra 330 Freestyle Who's Got One? - 3/1/2009 11:35 PM
Jimeni
Score: 110
Status: offline
Remove the whole box from the fuselage and clean up old epoxy edges so you can get a clean, flush fit. Dont remove the remaining tabs. You can re epoxy the broken ones on for alignment if you want, but you will be able to tell where to place the box. Unless you put something through the tabs once they are through the bulkhead, they dont add that much strength anyways, they are mainly for alignment. Put a coat of epoxy down before you position the tristock, once in place, coat the tristock also. Tristock with epoxy in a corner is extremely strong. A flat end blade for your exacto will make removal easier. Just work it throught the gaps to seperate things. Heating up the wood and epoxy with a heat gun or blow dryer will help get through it big time. Remember, the motor box comes from the factory with about 25% of the tristock it needs, in my opinion.
Hide Signatures
       Post #: 2164
RE: Fliton Extra 330 Freestyle Who's Got One? - 3/1/2009 11:44 PM
trpastor
Score: 145
Status: offline
Ok, so when I go to put it back on only the tri stock and epoxy would be holding it on? Should i put a thin piece of ply on the bulkhead before I reattach the enginebox to strenghten the whole thing?
Hide Signatures
       Post #: 2165
RE: Fliton Extra 330 Freestyle Who's Got One? - 3/2/2009 12:15 AM
Jimeni
Score: 110
Status: offline
Yes, thats all that was holding it on anyways. The notches on the tabs help a little but not alot, more for engine box positioning. I would put a strip of thin ply on the crack, or just stop drill the crack on each end (keeps the crack from growing), and put epoxy on it, both sides. Put up a picture of the crack, there may be another way.
< Message edited by Jimeni -- 3/2/2009 12:17 AM >
Hide Signatures
       Post #: 2166
RE: Fliton Extra 330 Freestyle Who's Got One? - 3/6/2009 8:34 PM
trpastor
Score: 145
Status: offline
Hey guys, my experienced builder friend helped me get it bandaged up to fly
ONE last PROBLEM... The weather is getting BEAUTIFUL for flying, BUT, I just found out my radio (spektrum Dx6i) has a recall for the pentiontiontotnoentoneontenot...meter (whatever the hell it is). And mine is exhibiting the problem. So I sent it in. Which leave me with my Dx5e.
This is a very manual radio. No expo. Has 1 dualrate (ele, ail, rudd same swtich). SOOO I'm dialing down the mechanical throws to very safe landing posistions. What do you think I should set the ele and ail to for landing (low rate)?
TIm
Hide Signatures
       Post #: 2167
RE: Fliton Extra 330 Freestyle Who's Got One? - 3/6/2009 9:12 PM
Yogy
Score: 100
Last Login: 2/6/2011
Status: offline
got my electric conversion flying it was nice !!! i`ll try to get pics and a video soon guys
Hide Signatures
       Post #: 2168
RE: Fliton Extra 330 Freestyle Who's Got One? - 3/12/2009 1:43 AM
Blazer1
Score: 105
Last Login: 3/6/2011
Status: offline
Recently I have had a chance to fly my Extra 330 Freestyle a lot,....... man I love this plane!!!! I am finally getting the bugs worked out of it and enjoying it for the great flying plane that it is. I am powering it with a Saito 82 and either a 14x6 APC or 14x6 MAS scimitar prop, have not decided which I like better. The Satio 82 is barely enough motor to hover but other than pull out is a nice fit for this plane. I have a Satio 100 that I will probably put on the Extra 330 Freestyle later this summer just to see the difference. I am by no means a 3D pilot but this plane really makes me look good! All the guys at the field have commented on how much better I am getting, truth is this plane makes me look good!! I see that many shops have the Extra 330 freestyle back in stock, maybe Fliton has not gave up on this plane yet?
Hide Signatures
(in reply to Yogy)
       Post #: 2169
RE: Fliton Extra 330 Freestyle Who's Got One? - 3/13/2009 4:44 AM
LuisCastillo
Score: 100
Last Login: 10/17/2010
Status: offline
Hi guys! im want to make my extra to electric, but i want some sugestions for the motor, esc and battery type.. some one can help me?
Thanks!
Aeromodelismo R/C Uruapan
Team Mundo Hobby
Hide Signatures
       Post #: 2170
RE: Fliton Extra 330 Freestyle Who's Got One? - 3/13/2009 5:38 AM
tIANci
Score: 116
Last Login: 9/16/2011
Status: offline
Luis ... try this:
Motor - AXI 4130/16 (many tried this combo and its good for 6S), you can also look into a Hyperion 4025-12 for 5S on a 16x10 or 16x12 or the Hackers
ESC - any 80A ESC, you can try the Turnigy if you do not wish to splurge, if not get a CC85HV
Batt - Rhino 20C 6S 3,700 for good 3D performance or Rhino 5S packs for good aerobatic performance
Prop - 16x10 E
Its nice to be important, but its more important to be nice ...
Revver Brotherhood No. 232
Hide Signatures
(in reply to LuisCastillo)
       Post #: 2171
RE: Fliton Extra 330 Freestyle Who's Got One? - 4/18/2009 6:28 AM
trpastor
Score: 145
Status: offline
Hey guys - for those of you still on the thread here - I ended up wrecking mine in a moment of bad judgement. Lost it in silohette on a day I was feeling sick.
Point being, I have a few parts if anyone want to pick some up.
I have a RIGHT wing in very good shape (went down on the left). I have the tail section. So if you want an extra rudder and elevator surface. I have landing gear, and canopy. Sadly, that is all
If you want to make an offer on any of it, I would be happy to sell it and have it go to use.
Figure someone might think it's a good idea to have a few extra pieces on hand for hangar rash or other.
pm me
Tim
Hide Signatures
(in reply to tIANci)
       Post #: 2172
RE: Fliton Extra 330 Freestyle Who's Got One? - 4/18/2009 7:20 AM
Jimeni
Score: 110
Status: offline
Bummer. I put mine in today also. I got a little luckier. All I need is a left wing. Bent the gear too bad to straighten, but I already have the replacement gear, just have not put them on yet. Flew about 5 flights after I realized I was wore out, bad idea. So if anybody has a left wing, I would be interested.
Hide Signatures
       Post #: 2173
RE: Fliton Extra 330 Freestyle Who's Got One? - 4/18/2009 3:54 PM
trpastor
Score: 145
Status: offline
Yeah, I learned from it though. I had heard it suggested to keep the plane lower to the ground on my approaches so I didn't have to bleed off as much speed. I really don't have a problem with coming down and bleeding off the speed, plus it gives you the advantage of knowing what direction the plan is pointed. If it's level the whole time there is less visual indicators as to whether it's going away or coming towards.
Being sick it flipped on me visually, and I was too "off" that day to know what it was doing and it was only 15 feet or so off the ground.
well, you live and learn.
I picked up the extra from Aero-Works. Just got it 2 days ago - looks really nicely crafted. I wrecked the fliton about a month ago - so I didn't get to fly it much. FLew great. I hope this AW flies as well
Hide Signatures
       Post #: 2174
RE: Fliton Extra 330 Freestyle Who's Got One? - 4/18/2009 4:22 PM
Jimeni
Score: 110
Status: offline
I dumb thumbed in a rolling harrier 4 foot off the ground. This plane does the best slow roll rolling harriers, except when your tired.
Hide Signatures
       Post #: 2175
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.984RCU1
