RE: Fliton Extra 330 Freestyle Who's Got One?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> RE: Fliton Extra 330 Freestyle Who's Got One? Page: <<   < prev  81 82 83 84 85 86 87 88 [89] 90   next >   >>
Login
RE: Fliton Extra 330 Freestyle Who's Got One? - 12/16/2009 5:32 AM
kgeb
Score: 111
Last Login: 2/7/2013
Status: offline
Did you use the stock pull pull rudder hardware?
How close to the tail did you mount the elevator servos? Also how did you reinforce the fuse where you cut out for the servos? Did you beef up the landing gear area?
Hide Signatures
(in reply to ohnoucdat)
       Post #: 2201
RE: Fliton Extra 330 Freestyle Who's Got One? - 12/16/2009 5:40 AM
ohnoucdat
Score: 105
Last Login: 2/18/2013
Status: offline
No can't remember what I used actually, but it wasn't the stuff that came with plane. I threw out most all the hardware, some of it was very questionable to say the least. I have the servos about an inch in front of tail. Pm me with addy and I'll send you pics of set up if you like
Hide Signatures
(in reply to kgeb)
       Post #: 2202
RE: Fliton Extra 330 Freestyle Who's Got One? - 12/16/2009 5:45 AM
kgeb
Score: 111
Status: offline
Any other mods you would do, now that you have flown it for a while?
Hide Signatures
       Post #: 2203
RE: Fliton Extra 330 Freestyle Who's Got One? - 12/16/2009 6:29 AM
ohnoucdat
Score: 105
Status: offline
here ya go, hope this helps
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to kgeb)
       Post #: 2204
RE: Fliton Extra 330 Freestyle Who's Got One? - 1/1/2010 6:02 PM
kgeb
Score: 111
Status: offline
How did you mount your canopy? Looks like the instructions suggest gluing it. Sure would be hard to work on the rudder servo! Any pictures of a removable canopy would be great.
Hide Signatures
       Post #: 2205
RE: Fliton Extra 330 Freestyle Who's Got One? - 1/1/2010 6:58 PM
trpastor
Score: 145
Last Login: 4/15/2011
Status: offline
I put some screws with self made silicone washers on it. 3 on each side.
Hide Signatures
(in reply to kgeb)
       Post #: 2206
RE: Fliton Extra 330 Freestyle Who's Got One? - 1/1/2010 7:04 PM
kgeb
Score: 111
Status: offline
I know they made the canopy this way to save weight, but is that a cheesy thing or what?. Did you dye or paint the canopy first?
Hide Signatures
(in reply to trpastor)
       Post #: 2207
RE: Fliton Extra 330 Freestyle Who's Got One? - 1/1/2010 7:52 PM
trpastor
Score: 145
Status: offline
no, I liked it clear, but yeah, that's cheesey. some guys made their own canopy hatch combo. You can find it I think in this thread. Another guy had put some silicone glue in the front end of the canopy securing it down, and letting it cure, so that it formed a rubberized front end. Said it helped it stay more flush.
I found the screws to be enough.
Hide Signatures
(in reply to kgeb)
       Post #: 2208
RE: Fliton Extra 330 Freestyle Who's Got One? - 1/1/2010 7:57 PM
trpastor
Score: 145
Status: offline
Hide Signatures
(in reply to kgeb)
       Post #: 2209
RE: Fliton Extra 330 Freestyle Who's Got One? - 1/1/2010 10:13 PM
trpastor
Score: 145
Status: offline
stupid timeouts
Hide Signatures
       Post #: 2210
RE: Fliton Extra 330 Freestyle Who's Got One? - 1/1/2010 10:22 PM
victorzamora
Score: 134
Last Login: 5/12/2013
Status: offline
Those are my favorites!! I wish RCU would just disable that feature.
_____________________________
Tact is for people not witty enough to use sarcasm.
Hide Signatures
       Post #: 2211
RE: Fliton Extra 330 Freestyle Who's Got One? - 1/10/2010 5:45 AM
kgeb
Score: 111
Status: offline
with the saito 91 and ds821 servos through out looks like 6lb 15 oz all up weight Thats about a lbs more than advertised weight Anyone else know there all up weight? What is a good CG to start with, book says 4.8-5.1"?
Hide Signatures
(in reply to victorzamora)
       Post #: 2212
RE: Fliton Extra 330 Freestyle Who's Got One? - 1/10/2010 7:31 AM
trpastor
Score: 145
Status: offline
WHOA! That's way too much. I don't know what could have happened to the plane, but mine was 5 15 with no spinner, but everything else.
What kind of battery etc etc are you using? Is your tank full?
Hide Signatures
(in reply to kgeb)
       Post #: 2213
RE: Fliton Extra 330 Freestyle Who's Got One? - 1/10/2010 3:15 PM
kgeb
Score: 111
Status: offline
I am running a 5 cell NiCd batt., alum spinner, and test weight was with (2) ds821s in the back for the elevator du-bro pull-pull rudder linkage, du-bro 10 oz fuel tank and a apc 15x4w prop. I am going to try a 1800ma 2s lipo and regulator, (2) hs-5085s in the tail and a plastic spinner. That may get me about 4-5oz off. I have some carbon fiber control rod, but all the rods are so short, i don't think it would be worth the effort I did fuel coat most of the plane, but that was only 1 oz epoxy and 1 oz alcohol and i am sure all the alcohol evaporated.
I know I am at the large end of the engine scale, so I didnt expect the advertised 93 oz but a lbs over does seem to be a bit much.
Hide Signatures
       Post #: 2214
RE: Fliton Extra 330 Freestyle Who's Got One? - 1/17/2010 1:12 AM
Wowbagger
Score: 100
Last Login: 4/19/2010
Status: offline
Mine's 6 1/4 lbs with a Saito 100. I use only one elevator servo - I made a staple to join the elevator halves - and a standard size 4 cell 2000mah NiMH. It has no repairs and no additions.
Jus' lemme fly!
Hide Signatures
(in reply to kgeb)
       Post #: 2215
RE: Fliton Extra 330 Freestyle Who's Got One? - 1/17/2010 7:23 AM
trpastor
Score: 145
Status: offline
Yeah, I was running a satio 100. You weighed it without fuel, right?
I did have 1 elevator servo. I used the pushrod method they recommended. I think I had a micro for the throttle. What MAH is your batterY? Somethign isn't right there. I had an apc and everything else you mentioned sounds about the same except ofr spinner, fuel, battery, so that's why I'm asking about those last 2 again
Hide Signatures
(in reply to Wowbagger)
       Post #: 2216
RE: Fliton Extra 330 Freestyle Who's Got One? - 1/17/2010 7:35 AM
kgeb
Score: 111
Status: offline
I have finished the 330. Total weight was 6 12oz. I have a 1700mah Nicd batt.6volt. Saito 91 apc 15x4w prop, plastic 2 1/2 dubro spinner, dubro 10oz fuel tank (empty),mini servo on throttle, ds821s on ailerons, hs645mg on rudder, single ds821 on elevator with push stock push stick. I could use a lipo battery and regulator but that will only shave an oz or so.
I must have some Chinese balsa/lead.
Hide Signatures
       Post #: 2217
RE: Fliton Extra 330 Freestyle Who's Got One? - 1/17/2010 7:58 AM
trpastor
Score: 145
Status: offline
Yeah, that's odd. Either the supplier changed or you got a heavy one. Sorry to report that, but I hadn't heard of one coming in that heavy, and like I said, mine was about 5-15 without a spinner. I think I had about the same battery. I didn't have a 645mg, but that's probably only an oz heavier than the ds821 (what i had)
can you think of any other things you may have added to it that would have added weight?
Hide Signatures
(in reply to kgeb)
       Post #: 2218
RE: Fliton Extra 330 Freestyle Who's Got One? - 1/17/2010 8:03 AM
kgeb
Score: 111
Status: offline
I weighed this thing with a set of digital fish scales I even thought they may be wrong, checked them with a known test weight, and they were very close. My saito is an older one, but I don't know of any changes in them.
Hide Signatures
       Post #: 2219
RE: Fliton Extra 330 Freestyle Who's Got One? - 1/17/2010 8:18 AM
trpastor
Score: 145
Status: offline
oh, no, I mean the fliton airframe. I have an aeroworks 60-90 extra, that I had to pull 11 ounces out of to get it down to 6.38lbs. Other guys are "reporting" theirs was 6.4 with pants and no mods. I don't see how, but mabye they got light ones??
Hide Signatures
(in reply to kgeb)
       Post #: 2220
RE: Fliton Extra 330 Freestyle Who's Got One? - 1/17/2010 8:21 AM
kgeb
Score: 111
Status: offline
mine is the fliton 330 extra freestyle
Hide Signatures
       Post #: 2221
RE: Fliton Extra 330 Freestyle Who's Got One? - 1/17/2010 12:41 PM
Kostas1
Score: 330
Last Login: 5/14/2013
Status: offline
quote:
ORIGINAL: kgeb
Anyactualpictures?
<==**Check my gallery for more pictures**
Club Saito member #706
Hide Signatures
(in reply to kgeb)
       Post #: 2222
RE: Fliton Extra 330 Freestyle Who's Got One? - 1/17/2010 6:27 PM
trpastor
Score: 145
Status: offline
know, I know yours was the fliton, but I'm just saying I had another airframe that people were reporting all different weights. I had mostly seen right around 6lbs with the fliton, but maybe you got a heavier one
Hide Signatures
(in reply to Kostas1)
       Post #: 2223
RE: Fliton Extra 330 Freestyle Who's Got One? - 5/10/2010 9:40 PM
Nitro-Tom
Score: 120
Last Login: 5/15/2013
Status: offline
Darn it!
This past weekend I crashed the Fliton Extra 330s Freestyle......
This time it's for good, fuse was busted up bad, one wing desintegrated inside, etc....
This was my absolute favorite plane so far, and I have 4 more that currently fly....just no where near as well as the Extra did.
Anyone know where to get another one, New In Box?
Click for fullsize
Nitro - Tom
General R/C Addict
Hide Signatures
       Post #: 2224
RE: Fliton Extra 330 Freestyle Who's Got One? - 5/10/2010 10:23 PM
tIANci
Score: 116
Last Login: 9/16/2011
Status: offline
I got one NIB but its for keeps. You can try Singapore Hobby Supplies. They may have a couple. Try this:
Its nice to be important, but its more important to be nice ...
Revver Brotherhood No. 232
Hide Signatures
(in reply to Nitro-Tom)
       Post #: 2225
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.539RCU1
