JPMacG
PA, USA Status: offline
I vote for the DVM as well. Fluke is great, but the name commands a premium. Other brands such as Tektronix and Wavetek are also very good. Sometimes you can find a good deal on eBay. Look up the brand and model on the manufacturer's web site to be sure what it is before you bid. You want one with good DC voltage accuracy for checking batteries. It's easy to convert the DVM to a loaded DVM using resistors and bananna plugs - use the kind of plug that stacks, then you can plug your airplane connector leads into the DVM on top of the resistor plugs. You can get an RC charge plug with bananna plugs that will plug in right on top, for example from RadicalRC. Choose resistors to give you 250 mA, 500 mA, 1A or whatever you want. Resistors cost pennies.
< Message edited by JPMacG -- Jan 13 2002 6:14AM >
