J_R
Video is still voodoo. Video authouring (writing the video to media) is not the same as video editing(modifiying the captured video). Some programs are great at one but, not at the other. I have been fooling around with several different software packages. Rendering can be a real problem. The trick is to capture your video in the format (resolution) that will be used on the media you choose. If the rendering has to be recoded (transcoded) it can take hours to do the conversion. I have been using Roxio Media Creator 7 lately and it is the Swiss Army knife of these programs. It not only captures and edits video, but has software to edit stills and make a slide show, and back up data. I can now move a one hour video from my digital video cam to a dvd in less than two hours, and that includes some minor editing. It can capture digital video directly to an mpeg-2 file, instead of an avi file and then converting it. The same process, using the same program, but using the wrong capture resolution can take 8 hours and the final production does not play smoothly. In other words, capturing for a web stream is not the same for creating a dvd which is playable on a TV and neither are the same as what you can put on a dvd and play on your computer that won't play on a TV. When you couple Roxio up with a capture card, like a TV card ($50 up), you can convert analog video to ditgital by hooking up a VCR or analog camcorder. Using a sound card, it will convert your LPs and cassette tapes to digital sound. It can also convert CDs to mp3s. If you want a freebe to try your hand with this stuff, Windows Movie Maker is priced right and will produce stuff for streaming, playback on your computer, or VCDs (not DVDs).
