RE: RealFlight G3 Basics - Newbies apply here
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Flight Simulator Software >> RE: RealFlight G3 Basics - Newbies apply here Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: RealFlight G3 Basics - Newbies apply here - 2/4/2005 1:26:41 PM
chasrb
Status: offline
I understand your, RFG3, need to provide a secure method to thwart copyright infringement, but to not allow the joystick ability to fly the sim is a problem for a number of users.
It seems that if you force the end user to config the RFG3 with the G3 TX serial and the serial from the code and then verify that it is a legal copy - proper registration and all, then the code shoulod allow for the ability to use the joystick if needed, to fly.
Also why can you not built an USB interface cable with the hardware lock built in it and then provide adapter cable to the different Tx connectors?
Just ideas...
Chasman
_____________________________
Chasman
(in reply to chasrb)
       Post #: 51
RE: RealFlight G3 Basics - Newbies apply here - 2/5/2005 4:09:18 PM
cfossa
Status: offline
Chasman,
I have also found a problem with add-on 1&2. When I intall either of them, it messes up my G3 and I have to uninstall/re-install. Add-ons 3-5 installed w/o any problems but I can not get 1&2 to work correctly.
Carl
       Post #: 52
RE: RealFlight G3 Basics - Newbies apply here - 2/6/2005 7:32:42 AM
mikenlapaz
Status: offline
jaafit
Could you look at Post #49 particularly questions 1 & 3. Thanks
''A government big enough to give you everything you want, is big enough to take away everything you have.'' Thomas Jefferso
(in reply to cfossa)
       Post #: 53
RE: RealFlight G3 Basics - Newbies apply here - 2/10/2005 8:00:09 AM
knight1
Status: offline
I just recieved G3 and unistalled the older realflight sim's and installed G3 with all the add on's 1-5 and it works pretty darn well with full everything on graphics.
The only thing that I see wrong with the physics is on some not all scenery files is while flying if you fly above the trees about 5 to 8 feet the aircraft crashes.
The one question I did have is, can I play in multyiplayer mode online or in local network mode with my G3 to someone who has G2?
thanks,
Mark
-Mark-
(in reply to mikenlapaz)
       Post #: 54
RE: RealFlight G3 Basics - Newbies apply here - 2/10/2005 5:49:47 PM
jaafit
Status: offline
quote:
ORIGINAL: knight1
What version do you have? This problem was fixed in the helicopter update.
thanks,
Mark
No, the multiplayer in G3 is only for flying with other G3 users.
(in reply to knight1)
       Post #: 55
RE: RealFlight G3 Basics - Newbies apply here - 2/10/2005 8:39:28 PM
knight1
Status: offline
jaafit, The version I have is 3.00.366 with the heli update.
thank's
-Mark-
(in reply to jaafit)
       Post #: 56
RE: RealFlight G3 Basics - Newbies apply here - 2/11/2005 12:31:18 AM
jaafit
Status: offline
In that case, you are probably flying at a G2 airport. Those airports have 2-dimensional trees, so colliding with them in 3D can sometimes seem a little off. We favored a more conservative approach in our collision detection, which hopefully trains pilots to stay far away from those trees!
       Post #: 57
RE: RealFlight G3 Basics - Newbies apply here - 2/11/2005 12:36:44 AM
Gatorboy08
Status: offline
hey jaafit, i sent a pm back to you
Tucker High school, GA Go TIGERS!!!!
       Post #: 58
RE: RealFlight G3 Basics - Newbies apply here - 2/11/2005 11:04:40 PM
jaafit
Status: offline
I've just been informed that our next update will also improve the collision detection with the G2-style trees. The update is still in a beta form, but you can try it here.
       Post #: 59
RE: RealFlight G3 Basics - Newbies apply here - 2/17/2005 12:32:39 PM
chasrb
Status: offline
I tried to add in the Addon 1 and 2 again last night, I even backed up the RF executable, but alas it still crapped out after installing the Addon 1 and 2. I was going to NOT install the 1.1 upgrade that is selected by default on Addon 1, but I went ahead and did install it. I did not capture the error message box, maybe I'll do that tonight.
Is there a chance that you guys at Knife could do a fresh install on XP Pro of G3 and then add in the Addon 1 and 2 then tell me the steps you took to successfully install them? I know this should not be this difficult to install an Addon.
Thx
Chasman
Chasman
       Post #: 60
RE: RealFlight G3 Basics - Newbies apply here - 2/17/2005 6:28:32 PM
jaafit
Status: offline
Wow, that' s probably more trouble than you wanted to go through to get Add-Ons! I think I can help. Yes, we did install Add-Ons 1 and 2 on XP Pro and found no problems running G3. What I suspect is that you have an older version of the Add-Ons 1 and 2 disks.
In that case, you have two options. One is to wait for our next update, which will fix G3's compatibility with those particular versions. I'm not sure when that will be publically available.
The other option is to contact technical support and get them to replace your old Add-Ons disk with new copies. But before you contact them, it would be worth while to make sure you really do have the older version. Did either disk ask you for your "Company" along with your name and serial number? If it did ask for your "Company", then you have an older version because the newer versions do not. And what was the error message you saw?
       Post #: 61
RE: RealFlight G3 Basics - Newbies apply here - 2/18/2005 6:15:21 PM
USNRol
Status: offline
Just so you both know, I apparently have the older versions of add-ons 1+2 and I'm having exactly the same difficulties. Mine want's to install realflight version 1.1 and then add-on 1 and I have to delete the files the install creates (Only a couple files actually get built and stuck into the G3 directory tree) in order to get G3 to run again. I have been putting off figuring this out since G3 is still so new....glad I stumbled onto this thread.
USNRol
       Post #: 62
RE: RealFlight G3 Basics - Newbies apply here - 2/20/2005 7:06:43 PM
k.fuchs
Status: offline
Is The USB InterLink Plus necessery to run RealFlight G3 ?
       Post #: 63
RE: RealFlight G3 Basics - Newbies apply here - 2/20/2005 9:13:37 PM
jaafit
Status: offline
quote:
ORIGINAL: k.fuchs
Yes, G3 comes with an Interlink controller, and that controller must be connected or G3 will not run.
(in reply to k.fuchs)
       Post #: 64
RE: RealFlight G3 Basics - Newbies apply here - 3/1/2005 8:34:08 AM
Morpheus56692
Status: offline
I've been playin G2 for awhile. I purchased G3 and now I'd like to network these two together for a little pylon racing. Can you network (LAN) G2 with G3 together? And if not, can you network (LAN) G3 and G3 together?
       Post #: 65
RE: RealFlight G3 Basics - Newbies apply here - 3/1/2005 6:02:24 PM
jaafit
